Solved Magic mirror does not start automatically when booting
Hello, I updated to the new MM version at the weekend and then I couldn’t get it to work anymore.
That’s why I reinstalled everything, but my MM doesn’t automatically state when booting. I entered this command:bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
but every time I get this message:
What exactly am I doing wrong? I copied this command from here: https://github.com/sdetweil/MagicMirror_scripts
do you think so?
@sil3ntstorm thanks… the ‘problem’ is that we have a mangled node configuration…
we asked for node 20.8.0, but got 20.5.1 which is broken
@sdetweil said in Magic mirror does not start automatically when booting:
20.8.0
Can I just install 20.8.0 over it or do I have to uninstall the other version? Do you perhaps have suitable instructions for this?
@sil3ntstorm my scripts auto install 20.8.0
the problem is your system installed 20.5.1 instead…
we don’t know why yet, and don’t have a reliable fix.
pm2 can’t run cause node is broken,
so far the only fix is to rebuild your sd card …
use my backup script to save your MM config , modules, …
https://github.com/sdetweil/MagicMirror-backup-restorereflash the sd card, use my install script and then restore script…
(note that you have to get the ~/MM_backup folder to safety… maybe on github …the fixes suggested by folks on the node distro group do not work.
I don’t need the backup because I just flashed the memory card and haven’t installed any modules yet.
If I re-flash the card now, what instructions should I follow so that version 20.8 is installed and not the defective 20.5.1 again?Thanks for your help so far
@sil3ntstorm is it the 64 bit OS, or 32? 64 bit seems to be the biggest trouble spot…
I would use the 32 bit image
then run my install script as the first thing…
we had trouble with the preinstalled node 12 too…
I flashed this version.
Do you have a link for the installation script?
I only saw the link for the backup script -
@sil3ntstorm my install/upgrade scripts
that is the (bullseye) image I use as well…
pi0w gets the legacy (buster) image
