    Magic mirror does not start automatically when booting
    24 Posts 2 Posters 9.4k Views 2 Watching
      sil3ntstorm
      Hello, I updated to the new MM version at the weekend and then I couldn’t get it to work anymore.
      That’s why I reinstalled everything, but my MM doesn’t automatically state when booting. I entered this command:
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
      but every time I get this message:
      What exactly am I doing wrong? I copied this command from here: https://github.com/sdetweil/MagicMirror_scripts
        sdetweil @sil3ntstorm
        @sil3ntstorm can u do this on a command prompt
        n
        and
        nvm
        do either respond?
          sil3ntstorm @sdetweil
          do you think so?
            @sil3ntstorm thanks… the ‘problem’ is that we have a mangled node configuration…
            we asked for node 20.8.0, but got 20.5.1 which is broken
              @sdetweil said in Magic mirror does not start automatically when booting:
              20.8.0
              Can I just install 20.8.0 over it or do I have to uninstall the other version? Do you perhaps have suitable instructions for this?
                @sil3ntstorm my scripts auto install 20.8.0
                the problem is your system installed 20.5.1 instead…
                we don’t know why yet, and don’t have a reliable fix.
                pm2 can’t run cause node is broken,
                so far the only fix is to rebuild your sd card …
                use my backup script to save your MM config , modules, …
                https://github.com/sdetweil/MagicMirror-backup-restore
                reflash the sd card, use my install script and then restore script…
                (note that you have to get the ~/MM_backup folder to safety… maybe on github …
                the fixes suggested by folks on the node distro group do not work.
                  I don’t need the backup because I just flashed the memory card and haven’t installed any modules yet.
                  If I re-flash the card now, what instructions should I follow so that version 20.8 is installed and not the defective 20.5.1 again?
                  Thanks for your help so far
                    @sil3ntstorm is it the 64 bit OS, or 32? 64 bit seems to be the biggest trouble spot…
                    I would use the 32 bit image
                    then run my install script as the first thing…
                    we had trouble with the preinstalled node 12 too…
                      I flashed this version.
                      Do you have a link for the installation script?
                      I only saw the link for the backup script
                        @sil3ntstorm my install/upgrade scripts
                        that is the (bullseye) image I use as well…
                        pi0w gets the legacy (buster) image
