    Magic mirror does not start automatically when booting
    24 Posts 2 Posters 10.4k Views 2 Watching
      sdetweil @sil3ntstorm
      @sil3ntstorm my install/upgrade scripts
      that is the (bullseye) image I use as well…
      pi0w gets the legacy (buster) image
        sil3ntstorm @sdetweil
        @sdetweil So that I don’t do something wrong for the third time, I’d rather ask carefully: I re-flashed the SD card, now I have to do this first:
        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)”
        And then this: bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
        And there is already version 20.8 in there and no longer the defective 20.5.1?
        And then at the end turn off the two things for the screen saver and the autostart thing:
        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)”
        and
        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
        Have I understood everything correctly so far?
          @sil3ntstorm
          no
          only raspberry.sh
          it does all the others too.
            @sdetweil I did it, at the beginning it said version 20.8 and further down it says that 20.5.1 was installed, did something go wrong here?
              @sil3ntstorm what is going on.?! can u send me the ~/install.log via email
              my name userid at gmail please
                @sdetweil email has been sent
                  @sil3ntstorm thanks got it… will review
                    @sil3ntstorm is your mirror working now?
                      @sdetweil No, I re-flashed the SD card and could now reinstall the Magic Mirror software. Should I access my Pi and run this?
                      Or do I have to do something else beforehand so that the Magic Mirror software is installed correctly?
                        @sil3ntstorm said in Magic mirror does not start automatically when booting:
                        yes, just run that. it has all the latest fixes and has been tested on bookwork, bullseye and buster
                          @sdetweil That worked very well this time. Magic Mirror finally starts. Thank you very much for your script.
                          I would now like to know whether I can install my modules normally like before, or whether there are still difficulties with calendar modules (I have often read this week that calendar modules cause problems)?
                          I had these modules on it before and would install everything again, or should I leave some out because there are problems with the new MM update/version?
                          Edit: After I rebooted, Magic Mirror doesn’t start automatically, then I entered this command:
                          It then starts immediately, but after restarting the Pi starts without MM.
                            @sil3ntstorm yes the pm2 script has done trouble
                            do this
                            pm2 startup
                            it will output a command, copy paste that
                              Did I do it right? If so, it will appear as a message
                                @sil3ntstorm need all of the command everything that it outputs, you didn’t copy about 30 characters
                                then
                                pm2 start ~/MagicMirror/installers/pm2_MagicMirror.json
                                pm2 save
                                  Wooooooooooooow it works, thank you very much
                                  This worked after I typed this:
                                  sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
                                  then that:
                                  pm2 save
