    Failed to export buffer to dma_buf: No such file or directory
    8 Posts 2 Posters 5.2k Views 3 Watching
      Roncham @sdetweil
      @sdetweil said in Failed to export buffer to dma_buf: No such file or directory:
      uname -a
      When I tried your script it said I had Node 18…, but node -v shows 20 before I started. Then it dies after installing npm with the ‘primordials’ error.
      Can I purge the node cache without removing node? If so how?
      @raspberrypi:~ $ uname -a
      Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU/Linux
      @raspberrypi:~ $ file /bin/bash
      /bin/bash: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, BuildID[sha1]=12abba9f431c0bef9f0a2a47f29cc9175159347f, for GNU/Linux 3.2.0, stripped
        sdetweil @Roncham
        @Roncham send me the ~/install.log
        same userid at gmail
          Roncham @sdetweil
          I started over from scratch. Sorry to waste your time. Your script worked great.
          Thanks!
            sdetweil @Roncham
            @Roncham thanks for the feedback. which is image did you choose? 32 or 64 bit
              Roncham @sdetweil
              @sdetweil 64 bit desktop
                sdetweil @Roncham
                @Roncham weird. try this
                pm2 stop all
                export ELECTRON_DISABLE_GPU=1
                npm start
                wait and see if the errors occurs
                if not
                add the export line to the script that starts mm
                in front of the npm start
                if you used my install script, that is
                ~/MagicMirror/installers/mm.sh
                • M MMRIZE referenced this topic on
