    MagicMirrorOS reload config without reboot
    10 Posts 4 Posters 3.1k Views 4 Watching
    • F Offline
      fischi87
      Hey Guys, i installed my magicmirror with the magicmirroros. How can i reload the config.js without a complete reboot. pm2 is not installed in the magicmirroros?
      i dont want always reboot the pi to see if my config works.
      thanks
      M karsten13K 2 Replies Last reply Reply Quote 0
        MMRIZE @fischi87
        F5.
        But some complex/heavy modules might not work .
          sdetweil @MMRIZE
          @MMRIZE or ctrl-r
          but neither reload the node_helpers
          • F Offline
            fischi87 @sdetweil
            i just have a connection with ssh.
              sdetweil @fischi87
              @fischi87 yes the two keystrokes only work on the mm web page
              I don’t know is mmos documents how to reload the container. we don’t support that here.
                MMRIZE @fischi87
                @fischi87
                You don’t have to “reboot”, connect MM then stop the “pm2” or whatever process manager you use.
                If you are using pm2, try this. I have not used it but may work for you.
                https://pm2.keymetrics.io/docs/usage/watch-and-restart/
                • F Offline
                  fischi87 @MMRIZE
                  @MMRIZE
                  like i wrote i installed the magicmirroros and there is no pm2. i dont know what start the magicmirror after boot in the os. somebody know what start the magicmirror software?
                    sdetweil @fischi87
                    @fischi87 mmos uses a docker container to run MagicMirror. the mm files are on the OS file system and mounted into the container
                    so you would need to restart the container
                    docker container restart ????id????
                    see
                    https://docs.docker.com/engine/reference/commandline/restart/
                    you would need to do
                    docker container ls
                    to list the containers to get it’s id to use in the restart command
                    • karsten13K Offline
                      karsten13 @fischi87
                      @fischi87
                      out of my head (untested):
                      cd ~/magicmirror/run
                      docker-compose up -d --force-recreate
                      • F Offline
                        fischi87 @sdetweil
                        this works thank you.
