    Trying to update to version 2.25
    13 Posts 2 Posters 4.5k Views 2 Watching
      sdetweil @vandam3b
      @vandam3b how did you install mm?
      manual or with my script?
      see
      • V
        vandam3b
        Hi, I installed it manually.
          sdetweil @vandam3b
          @vandam3b rename the MagicMirror folder to some other name
          and then run my install script.
          I don’t know why your git config has this problem
          or maybe restore this file
          package-lock.json
          git checkout package-lock.json
          • V
            vandam3b
            I will give it a try. Thank you very much.
            V 1 Reply Last reply
            • V
              vandam3b @vandam3b
              @vandam3b
              Hi, I installed your scripts and now get this when I try to run MagicMirror with npm start.
              magicmirror@2.25.0 start
              sh: 1: ./node_modules/.bin/electron: not found
              Any help would be appreciated. Thank you.
                sdetweil @vandam3b
                @vandam3b what platform is this?
                can u send me the ~/install.log to my email
                same userid at gmail
                try this too
                npm install electron@26.2.4
                then if its sucessful
                npm start
                • V
                  vandam3b
                  Hi, I tried it but I still got the same error. I don’t know where to find the install.log. I appreciate your help and do not want to take any more of your time. I will just uninstall everything and then start from scratch. Thanks again.
                  S 2 Replies Last reply
                    sdetweil @vandam3b
                    @vandam3b use my install script after u flash the SD card again
                    see
                    https://github.com/sdetweil/MagicMirror_scripts/tree/master
                    • V
                      vandam3b
                      I will. Thanks
                        sdetweil @vandam3b
                        @vandam3b said in Trying to update to version 2.25:
                        thats why I am here… to help
                        • V
                          vandam3b
                          Hi, I just wanted to let you know. I used your script to reinstall and all went well. Thanks again.
                            sdetweil @vandam3b
                            @vandam3b cool, thanks for the feedback!
