    MMM-MyCalendar stopped working on MagicMirror 2.25
    10 Posts 3 Posters 813 Views 3 Watching
      svoe88
      Hello, everyone,
      I’ve encountered an issue with my MagicMirror setup and need help resolving it. I hope someone here can provide me with some advice or solutions.
      Problem Description:
      I’ve updated my MagicMirror software to version 2.25.0, and after the update, I’m receiving the following error when I attempt to start MagicMirror:
      magic@magic:~/MagicMirror $ npm start
      > magicmirror@2.25.0 start
      [26.10.2023 22:33.08.627] [LOG]   Starting MagicMirror: v2.25.0
      [26.10.2023 22:33.08.632] [LOG]   Loading config ...
      [26.10.2023 22:33.08.635] [DEBUG] config template file not exists, no envsubst
      [26.10.2023 22:33.08.639] [LOG]   Loading module helpers ...
      [26.10.2023 22:33.08.641] [LOG]   No helper found for module: alert.
      [26.10.2023 22:33.08.665] [LOG]   Initializing new module helper ...
      [26.10.2023 22:33.08.665] [LOG]   Module helper loaded: updatenotification
      [26.10.2023 22:33.08.666] [LOG]   No helper found for module: clock.
      [26.10.2023 22:33.08.832] [LOG]   Initializing new module helper ...
      [26.10.2023 22:33.08.833] [LOG]   Module helper loaded: calendar
      [26.10.2023 22:33.08.850] [ERROR] (node:4586) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
      Require stack:
      - /home/magic/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js
      - /home/magic/MagicMirror/modules/MMM-MyCalendar/node_helper.js
      - /home/magic/MagicMirror/js/app.js
      - /home/magic/MagicMirror/js/electron.js
      - /home/magic/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
          at node:internal/modules/cjs/loader:1084:15
          at Function.<anonymous> (node:electron/js2c/browser_init:2:117576)
          at Module._resolveFilename (/home/magic/MagicMirror/node_modules/module-alias/index.js:49:29)
          at node:internal/modules/cjs/loader:929:27
          at Function._load (node:electron/js2c/asar_bundle:2:13327)
          at Module.require (node:internal/modules/cjs/loader:1150:19)
          at require (node:internal/modules/cjs/helpers:110:18)
          at Object.<anonymous> (/home/magic/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js:11:15)
          at Module._compile (node:internal/modules/cjs/loader:1271:14)
          at Object..js (node:internal/modules/cjs/loader:1326:10)
          at Module.load (node:internal/modules/cjs/loader:1126:32)
          at node:internal/modules/cjs/loader:967:12
          at Object.<anonymous> (/home/magic/MagicMirror/modules/MMM-MyCalendar/node_helper.js:16:25)
      (Use `electron --trace-warnings ...` to show where the warning was created)
      [26.10.2023 22:33.08.851] [ERROR] (node:4586) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
      [4624:1026/223309.952248:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4624:1026/223309.954689:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4624:1026/223309.956392:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4624:1026/223309.957469:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4624:1026/223309.958667:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4624:1026/223309.960686:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4624:1026/223309.963488:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4624:1026/223309.969142:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4624:1026/223309.970385:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4624:1026/223309.971544:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4624:1026/223309.973025:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4624:1026/223309.974008:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4624:1026/223309.975862:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4624:1026/223309.977751:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      It appears that the error is related to the MMM-MyCalendar module
      Can anyone guide me on how to fix the error and get my MagicMirror working correctly again?
        svoe88 @sdetweil
        It works now
        For others it doesn’t work too then I copy this code into calendarutils.js
        cd ~/MagicMirror/modules/MMM-MyCalendar
        /* MagicMirror²
         * Node Helper: Calendar - CalendarFetcher
         * By Michael Teeuw https://michaelteeuw.nl
         * MIT Licensed.
        const CalendarUtils = require("./calendarutils");
        const Log = require("logger");
        const NodeHelper = require("node_helper");
        const ical = require("node-ical");
        /*const fetch = require("fetch");*/
        /*const digest = require("digest-fetch");*/
        const https = require("https");
         * @param {string} url The url of the calendar to fetch
         * @param {number} reloadInterval Time in ms the calendar is fetched again
         * @param {string[]} excludedEvents An array of words / phrases from event titles that will be excluded from being shown.
         * @param {number} maximumEntries The maximum number of events fetched.
         * @param {number} maximumNumberOfDays The maximum number of days an event should be in the future.
         * @param {object} auth The object containing options for authentication against the calendar.
         * @param {boolean} includePastEvents If true events from the past maximumNumberOfDays will be fetched too
         * @param {boolean} selfSignedCert If true, the server certificate is not verified against the list of supplied CAs.
         * @class
        const CalendarFetcher = function (url, reloadInterval, excludedEvents, maximumEntries, maximumNumberOfDays, auth, includePastEvents, selfSignedCert) {
        	let reloadTimer = null;
        	let events = [];
        	let fetchFailedCallback = function () {};
        	let eventsReceivedCallback = function () {};
        	 * Initiates calendar fetch.
        	const fetchCalendar = () => {
        		clearTimeout(reloadTimer);
        		reloadTimer = null;
        		const nodeVersion = Number(process.version.match(/^v(\d+\.\d+)/)[1]);
        /*		let fetcher = null;*/
        		let httpsAgent = null;
        		let headers = {
        			"User-Agent": "Mozilla/5.0 (Node.js " + nodeVersion + ") MagicMirror/" + global.version
        		if (selfSignedCert) {
        			httpsAgent = new https.Agent({
        				rejectUnauthorized: false
        		if (auth) {
        			if (auth.method === "bearer") {
        				headers.Authorization = "Bearer " + auth.pass;
        /*			} else if (auth.method === "digest") {
        				fetcher = new digest(auth.user, auth.pass).fetch(url, { headers: headers, agent: httpsAgent });*/
        			} else {
        				headers.Authorization = "Basic " + Buffer.from(auth.user + ":" + auth.pass).toString("base64");
        /*		if (fetcher === null) {
        			fetcher = fetch(url, { headers: headers, agent: httpsAgent });
        			.then(NodeHelper.checkFetchStatus)
        			.then((response) => response.text())
        			.then((responseData) => {
        				let data = [];
        				try {
        					data = ical.parseICS(responseData);
        					Log.debug("parsed data=" + JSON.stringify(data));
        					events = CalendarUtils.filterEvents(data, {
        						excludedEvents,
        						includePastEvents,
        						maximumEntries,
        						maximumNumberOfDays
        				} catch (error) {
        					fetchFailedCallback(this, error);
        					scheduleTimer();
        					return;
        				this.broadcastEvents();
        				scheduleTimer();
        			.catch((error) => {
        				scheduleTimer();
        	 * Schedule the timer for the next update.
        	const scheduleTimer = function () {
        		reloadTimer = setTimeout(function () {
        			fetchCalendar();
        		}, reloadInterval);
        	/* public methods */
        	 * Initiate fetchCalendar();
        	this.startFetch = function () {
        		fetchCalendar();
        	 * Broadcast the existing events.
        	this.broadcastEvents = function () {
        		Log.info("Calendar-Fetcher: Broadcasting " + events.length + " events.");
        		eventsReceivedCallback(this);
        	 * Sets the on success callback
        	 * @param {Function} callback The on success callback.
        	this.onReceive = function (callback) {
        		eventsReceivedCallback = callback;
        	 * Sets the on error callback
        	 * @param {Function} callback The on error callback.
        	this.onError = function (callback) {
        		fetchFailedCallback = callback;
        	 * Returns the url of this fetcher.
        	 * @returns {string} The url of this fetcher.
        	this.url = function () {
        		return url;
        	 * Returns current available events for this fetcher.
        	 * @returns {object[]} The current available events for this fetcher.
        	this.events = function () {
        		return events;
        module.exports = CalendarFetcher;
          sdetweil @svoe88
          @svoe88 for MyCalendar
          always look to the module github first
          see https://github.com/jclarke0000/MMM-MyCalendar/issues/40
          this is a new optional feature where you can have a file of properties
          and apply them to the config.js, not having them hard coded
            svoe88 @sdetweil
            “My mirror is up now, but the calendar is just stuck loading.”
            [26.10.2023 23:03.29.952] [LOG]   Starting MagicMirror: v2.25.0
            [26.10.2023 23:03.29.957] [LOG]   Loading config ...
            [26.10.2023 23:03.29.960] [DEBUG] config template file not exists, no envsubst
            [26.10.2023 23:03.29.965] [LOG]   Loading module helpers ...
            [26.10.2023 23:03.29.967] [LOG]   No helper found for module: alert.
            [26.10.2023 23:03.29.993] [LOG]   Initializing new module helper ...
            [26.10.2023 23:03.29.993] [LOG]   Module helper loaded: updatenotification
            [26.10.2023 23:03.29.994] [LOG]   No helper found for module: clock.
            [26.10.2023 23:03.30.170] [LOG]   Initializing new module helper ...
            [26.10.2023 23:03.30.171] [LOG]   Module helper loaded: calendar
            [26.10.2023 23:03.30.184] [LOG]   Initializing new module helper ...
            [26.10.2023 23:03.30.185] [LOG]   Module helper loaded: MMM-MyCalendar
            [26.10.2023 23:03.30.185] [LOG]   All module helpers loaded.
            [26.10.2023 23:03.30.197] [LOG]   Starting server on port 8080 ...
            [26.10.2023 23:03.30.436] [LOG]   Server started ...
            [26.10.2023 23:03.30.437] [LOG]   Connecting socket for: updatenotification
            [26.10.2023 23:03.30.438] [LOG]   Starting module helper: updatenotification
            [26.10.2023 23:03.30.439] [LOG]   Connecting socket for: calendar
            [26.10.2023 23:03.30.439] [LOG]   Starting node helper for: calendar
            [26.10.2023 23:03.30.440] [LOG]   Connecting socket for: MMM-MyCalendar
            [26.10.2023 23:03.30.441] [LOG]   Starting node helper for: MMM-MyCalendar
            [26.10.2023 23:03.30.441] [LOG]   Sockets connected & modules started ...
            [26.10.2023 23:03.30.465] [LOG]   Launching application.
            [8619:1026/230331.393892:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
            [8619:1026/230331.394518:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
            [8619:1026/230331.395120:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
            [8619:1026/230331.395594:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
            [8619:1026/230331.396030:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
            [8619:1026/230331.396460:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
            [8619:1026/230331.396903:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
            [8619:1026/230331.398914:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
            [8619:1026/230331.399422:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
            [8619:1026/230331.399961:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
            [8619:1026/230331.401074:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
            [8619:1026/230331.401555:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
            [8619:1026/230331.402996:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
            [8619:1026/230331.403694:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
            [26.10.2023 23:03.32.519] [LOG]   Create new calendarfetcher for url: https://mitstudie.au.dk/calendar?icalkey=65872d73a3fdacbf72ef30a86e962830&lang=da&getLmsEvents=false - Interval: 3600000
            [26.10.2023 23:03.32.622] [LOG]   Create new calendarfetcher for url: https://mitstudie.au.dk/calendar?icalkey=65872d73a3fdacbf72ef30a86e962830&lang=da&getLmsEvents=false - Interval: 300000
            [26.10.2023 23:03.32.623] [ERROR] Whoops! There was an uncaught exception...
            [26.10.2023 23:03.32.625] [ERROR] ReferenceError: fetcher is not defined
                at fetchCalendar (/home/magic/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js:62:3)
                at CalendarFetcher.startFetch (/home/magic/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js:107:3)
                at Class.createFetcher (/home/magic/MagicMirror/modules/MMM-MyCalendar/node_helper.js:81:11)
                at Class.socketNotificationReceived (/home/magic/MagicMirror/modules/MMM-MyCalendar/node_helper.js:29:9)
                at Socket.<anonymous> (/home/magic/MagicMirror/js/node_helper.js:104:11)
                at Socket.emit (node:events:513:28)
                at Socket.emitUntyped (/home/magic/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
                at /home/magic/MagicMirror/node_modules/socket.io/dist/socket.js:704:39
                at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
            [26.10.2023 23:03.32.625] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [26.10.2023 23:03.32.626] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [26.10.2023 23:03.32.627] [INFO]  Checking git for module: MMM-MyCalendar
            [26.10.2023 23:03.32.654] [INFO]  Checking git for module: MagicMirror
            [26.10.2023 23:03.32.919] [INFO]  Calendar-Fetcher: Broadcasting 77 events from https://mitstudie.au.dk/calendar?icalkey=65872d73a3fdacbf72ef30a86e962830&lang=da&getLmsEvents=false.
            [8619:1026/230338.077679:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
            [8619:1026/230342.063208:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
            [8619:1026/230344.071380:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
            			module: "MMM-MyCalendar",
            			position: "top_left",	// This can be any of the regions. Best results in left or right regions.
            				colored: true,
            						url: ".........",
            						color: "#ffb350"
            But I’m still new to getting it all up and running
              svoe88 @sdetweil
                sdetweil @svoe88
                @svoe88 said in config template file not exists:
                didn’t do the patch right
                karsten13K S 2 Replies Last reply Reply Quote 0
                • karsten13K Offline
                  karsten13 @sdetweil
                  title of this thread has nothing to do with the problem
                    sdetweil @karsten13
                    @karsten13 I fixed the title
                      svoe88 @sdetweil
                      How do I get it done?
                        sdetweil @svoe88
                        @svoe88 you missed one of the changes in the workaround. the author needs to fix their module.
                          svoe88 @sdetweil
                          It works now
                          /* MagicMirror²
                           * MIT Licensed.
                           * @class
                          	let events = [];
                          		reloadTimer = null;
                          		let headers = {
                          		if (auth) {
                          			} else {
                          				let data = [];
                          				try {
                          						excludedEvents,
                          						includePastEvents,
                          						maximumEntries,
                          						maximumNumberOfDays
                          				} catch (error) {
                          					scheduleTimer();
                          					return;
                          				scheduleTimer();
                          			.catch((error) => {
                          				scheduleTimer();
                          			fetchCalendar();
                          		}, reloadInterval);
                          		fetchCalendar();
                          		return url;
                          		return events;
