    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 554.7k Views 58 Watching
    • Y Offline
      YourhighnessLeender @nuckinfutz
      @nuckinfutz Im not sure, tried to put it in the root of the Facial recognition module first, but for some reason it couldnt open the file there (permissons maybe?) So I changed the path in the config.js file to the files original location, (where the training script places it).
      I will post output from train.py and my config.js when I get home.
      Thoughts of mine:
      Is it possible that the web cam captures to low resolution compared to the test script? How do one go avout changing that?
      Some permissions problem? Root vs pi user?
      If I set the confidence threshold to a much higher number, wouldn’t it eventually recognise anyone as me? (I only have one user)
      Thanks for the help!
      • Y Offline
        @nuckinfutz
        Ok here is the output from train.py:
        pi@raspberrypi:~/MagicMirror/modules/MMM-Facial-Recognition-Tools-master/facetrainer $ sudo python train.py
        Which algorithm do you want to use?
        [1] LBPHF (recommended)
        [2] Fisherfaces
        [3] Eigenfaces
        --> 1
        Reading training images...
        Assign label 1 to Johannes
        Read 13 positive images and 400 negative images.
        13 images from subject Johannes
        Training model...
        Training data saved to training.xml
        Please add or update (if you added new people not just new images) ['Johannes'] inside config.js (mirror module) or config.py (model tester). You can change the names to whatever you want, just keep the same order and you'll be fine.
        Please add 1 as your choosen algorithm inside config.js (mirror module) or config.py (model tester).
        Here is my config.js:
        GNU nano 2.2.6                                      File: config.js
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
                port: 8080,
                language: 'sv',
                timeFormat: 24,
                units: 'metric',
                                module: 'MMM-Facial-Recognition',
                                // 1=LBPH | 2=Fisher | 3=Eigen
                                recognitionAlgorithm: 1,
                                // Threshold for the confidence of a recognized face before it's considered a
                                // positive match.  Confidence values below this threshold will be considered
                                // a positive match because the lower the confidence value, or distance, the
                                // more confident the algorithm is that the face was correctly detected.
                                lbphThreshold: 50,
                                fisherThreshold: 250,
                                eigenThreshold: 3000,
                                // force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
                                useUSBCam: true,
                                // Path to your training xml
                                trainingFile: '/home/pi/MagicMirror/modules/MMM-Facial-Recognition/training.xml',
                                // recognition intervall in seconds (smaller number = faster but CPU intens!)
                                interval: 1,
                                // Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a f$
                                logoutDelay: 5,
                                // Array with usernames (copy and paste from training script)
                                users: ['johannes'],
                                //Module set used for strangers and if no user is detected
                                defaultClass: "default",
                                //Set of modules which should be shown for every user
                                everyoneClass: "everyone"
        B N 2 Replies Last reply Reply Quote 0
          PointPubMedia
          @paviro Do you think it can be possible to have a “CURL” call when a user log in and log out ?
          P B 2 Replies Last reply Reply Quote 0
            bhepler Module Developer @YourhighnessLeender
            @YourhighnessLeender Check your capitalization. Your training script output was ‘Johannes’ and your config.js has ‘johannes’.
            Y 1 Reply Last reply Reply Quote 1
            • Y Offline
              YourhighnessLeender @bhepler
              @bhepler thanks! Tried that but still no luck. Started over from scratch, still undefined user. The. Lowercase was me testing if it made any difference.
              Cound it be that the webcam captures in too low res when running MM compare to the test script? And in that case, how can I check or change that?
              Im a noob with linux and the terminal.
              • N Offline
                nuckinfutz @YourhighnessLeender
                @YourhighnessLeender You spelled your name as Johannes in the training file and in config.js you spelled it johannes. config.js is a lower case J.
                Been there done that. lol…
                • N Offline
                  nuckinfutz @nuckinfutz
                  @nuckinfutz behelper beat me to it.
                    benkej
                    Hi guys,
                    I have the same problem, tried with picam and normal webcam too.
                    Capture working, train working, facerecognition_tester working, MMM-Facial-Recognition doesn’t work.
                    Anyone sitting in front of the mirror, I get the message in terminal “User undefined with confidence null logged in”
                    • N Offline
                      @YourhighnessLeender Webcam is fine. If it worked in training it will work in the module.
                      • Y Offline
                        @nuckinfutz that is whats so strange. It does work in training but not in the module. Did a new install of the module and new training.xml but no luck. Very very wierd.
                        Maybe I should buy a picam and try with that.
                        • Y Offline
                          YourhighnessLeender @benkej
                          @benkej question: did you change any of the capture settings in config.js? Like threshold etc? I was thinking of trying a different algorithm, did you try that?
                            benkej @YourhighnessLeender
                            @YourhighnessLeender only for trial but I changed everything back to the default. I’m using raspberry pi 3 model b, here is part of my config:
                                    lbphThreshold: 50,
                                    useUSBCam: true,
                                    trainingFile: 'modules/MMM-Facial-Recognition/training.xml',
                                    interval: 3,
                                    // Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a few seconds
                                    logoutDelay: 15,
                                    users: ["Jani"],
                            and part of console log:
                            [MMM-Facial-Recognition] Facerecognition started...
                            [MMM-Facial-Recognition] Loading training data...
                            [MMM-Facial-Recognition] ALGORITHM: LBPH
                            [MMM-Facial-Recognition] Training data loaded!
                            [MMM-Facial-Recognition] --------------------
                            [MMM-Facial-Recognition] Webcam ausgewählt...
                            [MMM-Facial-Recognition] User undefined with confidence null logged in.
                            [MMM-Facial-Recognition] User undefined logged out.
                            ^C[MMM-Facial-Recognition] Shutdown: Cleaning up camera...
                            [MMM-Facial-Recognition] Terminating..
                            @YourhighnessLeender and the output of train.py:
                            [2] Fisherfaces
                            [3] Eigenfaces
                            --> 1
                            Assign label 1 to Jani
                            Read 3 positive images and 400 negative images.
                            3 images from subject Jani
                            Training model...
                            Please add or update (if you added new people not just new images) ['Jani'] inside config.js (mirror module) or config.py (model tester). You can change the names to whatever you want, just keep the same order and you'll be fine.
                            • Y Offline
                              YourhighnessLeender
                              @benkej same as me, but no luck :-(
                                @YourhighnessLeender unfortunately yes :angry:
                                I try to reinstall the whole system
                                • Y Offline
                                  @benkej oke, please update on your progress. Good luck. Im very close to giving up.
                                    paviro @PointPubMedia
                                    @PointPubMedia Well sure but you could also write your own module listening for the notifications from my module :)
                                    @bhepler said in Facial Recognition - customize your mirror for every user!:
                                    This does not make any difference :)
                                    @benkej said in Facial Recognition - customize your mirror for every user!:
                                    You should definitely use more than 3 pictures! I use around 200 :D
                                    – The Doctor
                                    Y B 2 Replies Last reply Reply Quote 0
                                    • Y Offline
                                      YourhighnessLeender @paviro
                                      @paviro 200 pictures - aha! Maybe my 13 isnt enough. I can’t use the capture script since i’m on webcam so I took em with my phone and transferred them to the pi. I’ll add more and cross my fingers.
                                        paviro
                                        Well that could also be a cause. You should use the same camera for best results!
                                        Why shouldn’t you be able to use a webcam with the capture script? I never used it with anything else to be honest :D
                                        – The Doctor
                                        • Y Offline
                                          @paviro hmm. Just can’t get it working for some reason… will try again. It complaind about no picam. Maybe I have to change something in the script? I’ll du another try.
                                            paviro
                                            Well the capture script does not have an enforce webcam option. Try to uninstall the picam python module, it will fallback to webcam then.
                                            To minimize recognition errors the MagicMirror module requires two identical recognitions to be accepted as current user. If your training data is not good enough it could happen that you are never recognized twice in two directly following images -> Always unknown user.
                                            – The Doctor
                                            • 10
                                            • 11
                                            • 6 / 11
