    Error trying to run: npm run install-mm
    18 Posts 2 Posters 9.5k Views 2 Watching
    • L
      lvolkjr @sdetweil
      lowell@raspberrypi:~/MagicMirror $ which node
      /usr/bin/node
      lowell@raspberrypi:~/MagicMirror $ n ls
      bash: n: command not found
        sdetweil @lvolkjr
        @lvolkjr ok, thx… but how did you get to node 18? it doesn’t come as default.
        • L
          lvolkjr @sdetweil
          @sdetweil I was looking for a solution prior to coming to this forum and following someone else’s answer to there own issue that I thought would work for me, but got me no where. they said to change to node 18 from here: https://github.com/nodesource/distributions
          Download and import the Nodesource GPG key
          sudo apt-get update
          sudo apt-get install -y ca-certificates curl gnupg
          sudo mkdir -p /etc/apt/keyrings
          curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
          Create deb repository
          NODE_MAJOR=20
          echo “deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_$NODE_MAJOR.x nodistro main” | sudo tee /etc/apt/sources.list.d/nodesource.list
          Optional: NODE_MAJOR can be changed depending on the version you need.
          NODE_MAJOR=16
          NODE_MAJOR=18
          NODE_MAJOR=20
          NODE_MAJOR=21
          Run Update and Install
          sudo apt-get update
          sudo apt-get install nodejs -y
          Did this screw me up?
            sdetweil @lvolkjr
            @lvolkjr said in Error trying to run: npm run install-mm:
            maybe…
            try this
            sudo apt-get remove nodejs -y
            then do
            node -v
            • L
              lvolkjr @sdetweil
              @sdetweil I didn’t see any errors after running sudo apt-get remove nodejs -y
              When I run node -v I get this:
              bash: /usr/bin/node: No such file or directory
                sdetweil @lvolkjr
                @lvolkjr ok, do
                ls /usr/bin/node
                should return file not found
                do
                hash -r
                node -v
                just to make sure…
                then run my install or upgrade script as appropriate…
                • L
                  lvolkjr @sdetweil
                  @sdetweil This is what I got:
                  lowell@raspberrypi:~ $ ls /usr/bin/node
                  ls: cannot access ‘/usr/bin/node’: No such file or directory
                  lowell@raspberrypi:~ $ hash -r
                  lowell@raspberrypi:~ $ node -v
                  bash: node: command not found
                  Do you still want me to run your script? I feel like node -v should have given me a different output, like the version number.
                    sdetweil @lvolkjr
                    @lvolkjr I expected something too
                    I’d rebuild the SD card, boot, skip updates
                    then use my script. this node install is such a mess, they changed the process…ugh
                    • L
                      lvolkjr @sdetweil
                      @sdetweil Yea, I figured. Thanks for all your help. Hopefully I could repay you in the future. I’ll keep you updated to what happens.
                      • L
                        lvolkjr @lvolkjr
                        @sdetweil Thanks!!! That worked! I’m running MagicMirror and getting ready to customize it. I should have started over a long time ago.
                          sdetweil @lvolkjr
                          @lvolkjr cool… yeh, its hard to tell when you’ve hit a real roadblock
                          glad you are working now… make sure to backup!!..
                          see https://github.com/sdetweil/MagicMirror-backup-restore
                          • L
                            lvolkjr @sdetweil
                            @sdetweil I will, thanks again.
