    birthdaylist dont show up
    5 Posts 2 Posters 871 Views 2 Watching
      svoe88
      I have tried to install BirthdayList, but it’s not appearing. I followed the guide and used the following commands:
      cd ~/MagicMirror/modules
      git clone https://github.com/sdetweil/birthdaylist
      cd birthdaylist
      npm install
      However, nothing is showing up on my Magic Mirror.
      However, my other modules are showing up on my Magic Mirror.
        sdetweil @svoe88
        @svoe88 said in birthdaylist dont show up:
        currentMonthOnly: true,
        change that to false
        only showing birthdays for October, and that means ONLY for TODAY (as its the last day)
          sdetweil @svoe88
          @svoe88 what did you put in config.js?
            svoe88 @sdetweil
            I’ve try both
            			module: "birthdaylist",
            			position: "bottom_left",
                    position:'top_left',
            		language: "de",
            		dimmEntries: false,  // true: dims entries and the associated
            				     //       symbol when the date has expired.
            			             // false: dont display entries and the associated
            		initialLoadDelay: 0, // How many seconds to wait on a fresh start up.
            				     // This is to prevent collision with all other modules also
            				     // loading all at the same time. This only happens once,
            				     // when the mirror first starts up.
            		updateDelay: 5,      // How many seconds after midnight before a refresh
            				     // This is to prevent collision with other
            				     // modules refreshing at the same time.
            		currentMonthOnly: true,  // will show birthdays for the current month only if true
            		maxEntries: 0,	     // maximum entries to show, default is all
            		dateFormat: '',	     // date format for birthday (default is none), could be 'Do' for 'Sep 12th'
            		ageFormat:'',	     // some format string for the persons age, '[ n ]'  n will be replace by age value
            		debug:false
              sdetweil @svoe88
                svoe88 @sdetweil
                i works new Thanks
