    dist/electron: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directory
    23 Posts 2 Posters 15.5k Views 2 Watching
    • T Offline
      the_2winz @sdetweil
      @sdetweil i was able to add it to the electron/dist/ directory but when i run npm run start, now i get this error /home/rob/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libnss3.so: wrong ELF class: ELFCLASS32
        sdetweil @the_2winz
        @the_2winz yes this
        uname -a
        file /bin/bash
        I think you have a hybrid system… 64 bit kernel, 32 bit runtime
        • T Offline
          the_2winz @sdetweil
          @sdetweil looks like it.
          rob@raspberry:~/MagicMirror $ uname -a
          Linux raspberry 5.10.0-15-amd64 #1 SMP Debian 5.10.120-1 (2022-06-09) x86_64 GNU/Linux
          rob@raspberry:~/MagicMirror $ file /bin/bash
          /bin/bash: ELF 32-bit LSB pie executable, Intel 80386, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux.so.2, BuildID[sha1]=56307740a4c93a51d04f9511eae7897e52a4ddb5, for GNU/Linux 3.2.0, stripped
            sdetweil @the_2winz
            @the_2winz hm can you do the
            file command on the libnss3.so
            • T Offline
              the_2winz @sdetweil
              @sdetweil like libnss3.so bin/bash/ ? i’m not sure i follow
                sdetweil @the_2winz
                @the_2winz
                file /usr/lib/x86_64-linux-gnu/libnss3.so
                mine says
                /usr/lib/x86_64-linux-gnu/libnss3.so: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=53f5a8a185db3abf260b77ea560179a395b892e0, stripped
                my /bin/bash says
                /bin/bash: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=2a9f157890930ced4c3ad0e74fc1b1b84aad71e6, for GNU/Linux 3.2.0, stripped
                • T Offline
                  the_2winz @sdetweil
                  @sdetweil rob@raspberry:~/MagicMirror $ file /usr/lib/i386-linux-gnu/libnss3.so
                  /usr/lib/i386-linux-gnu/libnss3.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=f3a5e41927cedc2024ae8cdc9a00bd699cd14278, stripped
                    sdetweil @the_2winz
                    @the_2winz aha! you showed the 386 mode, not x64… SOOOOO that means electron is wrong… looking for the 64 bit library…
                      I would install Ubuntu instead of the raspian x86 image, which is a mess.
                      • T Offline
                        the_2winz @sdetweil
                        @sdetweil i think i will just lean on the browser feature - npm run server seems to work. thanks for all your help!
