    Calendar Not Displaying Recurring Events
    28 Posts 5 Posters 11.3k Views 5 Watching
    • O Offline
      oldrocker
      Hello, I’m new and I’ve been pulling my hair out for days trying to get the default calendar to display recurring events. The .ics is verified to contain recurring events but the calendar will only display the first event of the set and no more.
      This is a critical function for me as I intend to use this to display recurring family activities and will heavily rely upon it. I have searched the Internet and cannot fine a solution but have seen other complaints about it here and there.
      Is MM capable of displaying these events?
        sdetweil @oldrocker
        @oldrocker node-ical has just release a new version (0.17.0) which removes the luxon library which causes all the localdate/time issues…
        want to give it a try ? do
        npm install node-ical@latest
        then start mm as usual
        B S 2 Replies Last reply Reply Quote 0
          sdetweil @oldrocker
          @oldrocker said in Calendar Not Displaying Recurring Events:
          sure, as long as they are in the time and number of events limit…
          the default number of events is 10 events. (maximumEntries)
          https://docs.magicmirror.builders/modules/calendar.html#configuration-options
          • O Offline
            oldrocker @sdetweil
            @sdetweil Thanks for the reply.
            I have the maximumEntries: 100 but only the initial event displays and does not recur.
            Any other ideas?
              sdetweil @oldrocker
              @oldrocker can you show me the calendar config from config.js. just xxx out the url
              and can you show me the event from the ICS file
              to get the ICS file, open a terminal window and do
              curl -sL  the_url > somefile.txt
              the edit the somefile.txt and locate the event, and post it here
              change any text you are not willing to share
              BEGIN:VEVENT
              END:VEVENT
              • O Offline
                oldrocker @sdetweil
                @sdetweil here is some information:
                                                broadcastPastEvents: true,
        symbol: 'calendar-check',
        maximumEntries: 100,
        maximumNumberOfDays: 365,
        url: 'http://XXXXXXXXXXXXXXXXXX/Routine.ics',
        color: 'yellow',
        auth: {
        user: 'XXXXXXXXXXX',
        pass: 'XXXXXXXXXXX',
        method: 'basic'
                event
                BEGIN:VEVENT
                CREATED:20231111T124003Z
                DTSTAMP:20231111T124242Z
                LAST-MODIFIED:20231111T124242Z
                SEQUENCE:3
                UID:02d62d6f-74ff-48c2-aa7d-2682cb7e688c
                DTSTART;VALUE=DATE:20231111
                DTEND;VALUE=DATE:20231112
                STATUS:CONFIRMED
                SUMMARY:Test Event 1
                RECURRENCE-ID;VALUE=DATE:20231111
                END:VEVENT
                BEGIN:VEVENT
                SEQUENCE:3
                DTSTART;VALUE=DATE:20231118
                DTEND;VALUE=DATE:20231119
                STATUS:CONFIRMED
                RECURRENCE-ID;VALUE=DATE:20231118
                END:VEVENT
                  sdetweil @oldrocker
                  these parms are not calendar specific, they need to be above the calendars:[] list
                  and the first/last are the same as their default value
                  in the config options doc,
                  the first section applies to ALL calendars
                  the later section applies to each calendar entry. { url:…}
                  also
                  the master event with the start:/dtend is not present in the list you showed
                  • O Offline
                    oldrocker @sdetweil
                    @sdetweil Sorry, I’ve made a mess out of my config file the past three days figuring this out. I used the CalDav 3rd party module to create ics file, so if it’s not correct, I suppose I should download the ics directly from my calendar to troubleshoot. Perhaps the problem is in CalDav and I’m asking the questions in the wrong forum.
                    For a work-around, I can use the public subscription to the calendar just fine but the recurrences are shifted over one day like in a previous post in this forum you participated in. I looked at the calendarutils.js you mention in that posting for modification but I don’t see the lines that should be modified. I would rather use the ics method but will use this export method if I can get the events to be in the correct day. Can you help me with that?
                      sdetweil @oldrocker
                      @oldrocker point me to the post you reference…
                      • O Offline
                        oldrocker @sdetweil
                        Here it is. I’d rather not have a public subscription out there but it is what it is.
                        https://forum.magicmirror.builders/topic/17087/recurring-calendar-events-are-off-by-a-day?_=1699724623475
                          sdetweil @oldrocker
                          @oldrocker yeh, I added that code already to attempt to fix this. but the rule lib keeps giving back junk. I haven’t found a way to fix this.
