    Calendar Not Displaying Recurring Events
    28 Posts 5 Posters 14.4k Views 5 Watching
      sdetweil @oldrocker
      @oldrocker said in Calendar Not Displaying Recurring Events:
      broadcastPastEvents: true,
      maximumEntries: 100,
      maximumNumberOfDays: 365,
      these parms are not calendar specific, they need to be above the calendars:[] list
      and the first/last are the same as their default value
      in the config options doc,
      the first section applies to ALL calendars
      the later section applies to each calendar entry. { url:…}
      also
      the master event with the start:/dtend is not present in the list you showed
      O 1 Reply Last reply
      • O
        oldrocker @sdetweil
        @sdetweil Sorry, I’ve made a mess out of my config file the past three days figuring this out. I used the CalDav 3rd party module to create ics file, so if it’s not correct, I suppose I should download the ics directly from my calendar to troubleshoot. Perhaps the problem is in CalDav and I’m asking the questions in the wrong forum.
        For a work-around, I can use the public subscription to the calendar just fine but the recurrences are shifted over one day like in a previous post in this forum you participated in. I looked at the calendarutils.js you mention in that posting for modification but I don’t see the lines that should be modified. I would rather use the ics method but will use this export method if I can get the events to be in the correct day. Can you help me with that?
          sdetweil @oldrocker
          @oldrocker point me to the post you reference…
          • O
            oldrocker @sdetweil
            Here it is. I’d rather not have a public subscription out there but it is what it is.
            https://forum.magicmirror.builders/topic/17087/recurring-calendar-events-are-off-by-a-day?_=1699724623475
              sdetweil @oldrocker
              @oldrocker yeh, I added that code already to attempt to fix this. but the rule lib keeps giving back junk. I haven’t found a way to fix this.
              • O
                oldrocker @sdetweil
                @sdetweil ok, then I’m stuck. Thanks for your help!
                  MMRIZE @oldrocker
                  @sdetweil here is some information:
        symbol: 'calendar-check',
        url: 'http://XXXXXXXXXXXXXXXXXX/Routine.ics',
        color: 'yellow',
        auth: {
        user: 'XXXXXXXXXXX',
        pass: 'XXXXXXXXXXX',
        method: 'basic'
                  event
                  BEGIN:VEVENT
                  CREATED:20231111T124003Z
                  DTSTAMP:20231111T124242Z
                  LAST-MODIFIED:20231111T124242Z
                  SEQUENCE:3
                  UID:02d62d6f-74ff-48c2-aa7d-2682cb7e688c
                  DTSTART;VALUE=DATE:20231111
                  DTEND;VALUE=DATE:20231112
                  STATUS:CONFIRMED
                  SUMMARY:Test Event 1
                  RECURRENCE-ID;VALUE=DATE:20231111
                  END:VEVENT
                  BEGIN:VEVENT
                  SEQUENCE:3
                  DTSTART;VALUE=DATE:20231118
                  DTEND;VALUE=DATE:20231119
                  STATUS:CONFIRMED
                  RECURRENCE-ID;VALUE=DATE:20231118
                  END:VEVENT
                  There should be RRULES in the file. Could you find?
                  • O
                    oldrocker @MMRIZE
                    @MMRIZE
                    RRULES is not in the file that I could find. I also downloaded the ics directly from my Nextcloud instance and tried a manual static load like BasicUser did found here:
                    https://forum.magicmirror.builders/topic/13488/default-calendar-and-nextcloud-caldav
                    Effectively, I am cutting out the use of any 3rd party module and the recurrences are the same. The recurrences on Saturdays are correct while my recurrences on Wednesday shift to Thursdays after the first event. The ics loads just like when I pull it directly from the export url; SOME of the recurrences are a day ahead. This appears to be an issue with the default calendar and not the ics or the third party modules because the third party modules mirror what the default calendar sees and the ics file displays correctly in other applications and programs.
                    Perhaps I will spend some time looking into learning more about JS this weekend so I can troubleshoot further.
                    S 2 Replies Last reply
                      sdetweil @oldrocker
                      @oldrocker its rrule
                      here is an event using it
                      DTSTART;TZID=America/Los_Angeles:20221013T173000
                      DTEND;TZID=America/Los_Angeles:20221013T203000
                      RRULE:FREQ=WEEKLY;BYDAY=TH
                      EXDATE;TZID=America/Los_Angeles:20230907T173000
                      DTSTAMP:20231106T004837Z
                      UID:11ksg3ucn63ndd1034ht8mf0jr@google.com
                      CREATED:20221012T065054Z
                      LAST-MODIFIED:20230704T014529Z
                      SEQUENCE:3
                      STATUS:CONFIRMED
                      SUMMARY:hucklebucks trivia
                      TRANSP:TRANSPARENT
                      END:VEVENT
                        sdetweil @oldrocker
                        see this post
                        https://forum.magicmirror.builders/topic/18148/calendar-shows-incorrect-time-for-a-single-changed-event-in-a-series/4?_=1699723461769
                        • O
                          oldrocker @sdetweil
                          When I concatenate the ics, I don’t find any “RULE” using grep. I’ve re-downloaded and it’s simply not there. Perhaps Nextcloud doesn’t generate it that way?
                            sdetweil @oldrocker
                            @oldrocker if RRULE isn’t there, then there are no repeating events
                            • O
                              oldrocker @sdetweil
                              That’s interesting and my issue is really strange still. One series of my recurrences shifts from Wednesday to Thursday after the first one that displays. So, the first occurrence is on Wednesday, the next three are on Thursday. The other series starts on the second week of the month on a Saturday, and the recurrences are also on Saturday and nothing is wrong in that series.
                                sdetweil @oldrocker
                                @oldrocker some may be corrected my the code I added and some may not, or may be corrected in the wrong direction…
                                read my other post, you’ll see the mess we have on our hands.
                                • O
                                  oldrocker @sdetweil
                                  @sdetweil there are repeating events, just not on the proper days of the week.
                                  I believe you when you say it’s messy. I don’t know JS but I know more about it now over the past three days than I ever thought I would. I’ve never really messed around with calendars and some of this stuff. Much of it is foreign to me.
                                    sdetweil @oldrocker
                                    @oldrocker I didn’t know anything about how calendar works til 3 or 4 years ago when I decided to fix a bug in this…
                                    been a constant battle since then…
                                    this one has me stumped… been looking at a reliable solution for nearly a year…
                                    garbage in, garbage out
                                    • O
                                      oldrocker @sdetweil
                                      I’m not sure if that’s a challenge or a warning. I guess I’m going to setup a new dev environment.
                                      • O
                                        oldrocker
                                        Here is something else. In my Nextcloud calendar, I created a weekly recurring event. Each time I created the event in the first week of November, the module shifted the subsequent events one day forward. If I create the event on the second week, there is no issue that I can see and all the events are on the correct days.
                                        The 1st week starts on Saturday, October 29 and ends on Sunday, November 4.
                                          sdetweil @oldrocker
                                          @oldrocker so much fun
                                            sdetweil @oldrocker
                                            @oldrocker node-ical has just release a new version (0.17.0) which removes the luxon library which causes all the localdate/time issues…
                                            want to give it a try ? do
                                            npm install node-ical@latest
                                            then start mm as usual
                                            B S 2 Replies Last reply
