    Default calendar and Nextcloud CalDav
    13 Posts 5 Posters 8.8k Views 5 Watching
      BasicUser
      I am attempting to get my nextcloud caldav calendar to work with the default calendar module.
      I am trying to download my calendar locally as I don’t think I can get an ics link through nextcloud without addning “?export” to the end of the URI.
      I run curl -L https://nextcloud.mydomain.com/remote.php/dav/calendars/USER/personal/?export > . ~/MagicMirror/modules/cals/personal.ics
      In my config.js file I have
          symbol: "calendar",
          url: "http://localhost:8080/~/MagicMirror/modules/cals/personal.ics",
          user: "USERNAME",
          pass: "PASSWORD",
          method: "basic",
      I have put this together with some of the other forum posts on here but I seem to have gotten something wrong or something has changed.
      Anyone know how to get this working?
        sdetweil @BasicUser
        @BasicUser said in Default calendar and Nextcloud CalDav:
        url: “http://localhost:8080/~/MagicMirror/modules/cals/personal.ics”,
        put the file in the modules/calendar folder and then the url will be
        url:"modules/calendar/personal.ics
        as the MM file server is hosted to the MM folder.
          BasicUser @sdetweil
          @sdetweil okay, i didnt have a calendar folder in modules so i created one and changed my config file to
              symbol: "calendar",
              url: "modules/calendar/personal.ics",
              user: "USERNAME",
              pass: "PASSWORD",
              method: "basic",
          but it still didnt solve the issue
            sdetweil @BasicUser
            @BasicUser wherever u start mm, npm start, or pm2 start.
            u should see info in the console log about opening the ics file.
            if pm2, use the pm2 logs --lines=??? to display the last ??? lines of the logs
              sdetweil @BasicUser
              @BasicUser ok, i put my ics in the default/calendar folder and this works
              url:"http://localhost:8080/modules/default/calendar/foo.ics"
              so, you were more close than me
                BasicUser @sdetweil
                @sdetweil hmm
                symbol: "calendar",
                url: "http://localhost:8080/modules/default/calendar/personal.ics",
                user: "USER",
                pass: "PASSW",
                method: "basic",
                It is saying “No upcoming events” still. I put a test event for tomorrow so that I know there should be one.
                I ran pm2 logs --lines=150 | grep calendar
                0|mm       | [2020-08-19 17:47:12.740] [LOG]    Connecting socket for: calendar
                0|mm       | [2020-08-19 17:47:12.744] [LOG]    Starting node helper for: calendar
                0|mm       | [2020-08-19 17:47:23.028] [LOG]    Create new calendar fetcher for url: https://nextcloud.MYDOMAIN.xyz/remote.php/dav/calendars/USER/personal/ - Interval: 300000
                0|mm       | [2020-08-19 17:50:06.402] [LOG]    Module helper loaded: calendar
                0|mm       | [2020-08-19 17:50:08.524] [LOG]    Connecting socket for: calendar
                0|mm       | [2020-08-19 17:50:08.528] [LOG]    Starting node helper for: calendar
                0|mm       | [2020-08-19 17:50:19.043] [LOG]    Create new calendar fetcher for url: https://nextcloud.MYDOMAIN.xyz/remote.php/dav/calendars/USER/personal/ - Interval: 300000
                0|mm       | [2020-08-19 17:50:19.152] [LOG]    Create new calendar fetcher for url: http://localhost:8080/modules/calendar/personal.ics - Interval: 300000
                0|mm       | [2020-08-19 17:52:41.135] [LOG]    Module helper loaded: calendar
                0|mm       | [2020-08-19 17:52:43.207] [LOG]    Connecting socket for: calendar
                0|mm       | [2020-08-19 17:52:43.210] [LOG]    Starting node helper for: calendar
                0|mm       | [2020-08-19 17:52:53.215] [LOG]    Create new calendar fetcher for url: https://nextcloud.MYDOMAIN.xyz/remote.php/dav/calendars/USER/personal/ - Interval: 300000
                0|mm       | [2020-08-19 17:52:53.278] [LOG]    Create new calendar fetcher for url: http://localhost:8080/modules/calendar/personal.ics - Interval: 300000
                0|mm       | [2020-08-19 17:55:50.824] [LOG]    Module helper loaded: calendar
                0|mm       | [2020-08-19 17:55:53.057] [LOG]    Connecting socket for: calendar
                0|mm       | [2020-08-19 17:55:53.060] [LOG]    Starting node helper for: calendar
                0|mm       | [2020-08-19 17:56:03.286] [LOG]    Create new calendar fetcher for url: https://nextcloud.MYDOMAIN.xyz/remote.php/dav/calendars/USER/personal/ - Interval: 300000
                0|mm       | [2020-08-19 17:56:03.364] [LOG]    Create new calendar fetcher for url: http://localhost:8080/modules/default/calendar/personal.ics - Interval: 300000
                edit:
                more recent logs
                0|mm  | Use existing calendar fetcher for url: http://localhost:8080/modules/default/calendar/personal.ics
                0|mm  | [2020-08-19 18:06:02.407] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
                0|mm  | [2020-08-19 18:06:02.559] [INFO]
                0|mm  | Calendar-Fetcher: Broadcasting 0 events.
                0|mm  | [2020-08-19 18:06:02.608] [INFO]
                0|mm  | [2020-08-19 18:06:14.339] [INFO]
                EDIT2: It is working now, my downloaded ics file was bad apparently. I redownloaded it and now it is working as expected, I think.
                  sdetweil @BasicUser
                  @BasicUser cool… thx for the feedback
                    BasicUser @sdetweil
                    @sdetweil This might just be my ignorance but I have added an item to my calendar after it was working to see if it would pull the new event. To my dismay it has not pulled the newest item. Are ICS files static or do they update dynamically?
                    edit: final edit.
                    symbol: "calendar",
                    url: "https://nextcloud.MYDOMAIN.xyz/remote.php/dav/calendars/USER/personal/?export",
                    user: "USER",
                    pass: "PASSW",
                    method: "basic",
                    updated my config file to this and it is now working as expected. no idea why it wasnt before but i probably had something typed out incorrectly. thanks for the help
                      sdetweil @BasicUser
                      @BasicUser are you ok? can’t quite tell.
                      different cal.providers push updates at different times, and mm polls the calendar per the config
                        BasicUser @sdetweil
                        @sdetweil lol yes, all is working. it wasn’t updating when I downloaded the ics file and moved it to /default/calendar. I changed it to what I have in my most recent comment and that is working without issue.
                        • V Offline
                          vicarcmir
                            bdream
                            @BasicUser I use calendar also with nextcloud.
                            I have not found a solution without writing my credantials in plain text but as here (only the calendars-part) it works:
                            		symbol: "grin",
                            		color: "#FFAA00",
                            		url: "https://USER:PASSWORD@DOMAIN.TLD/nextcloud/remote.php/dav/calendars/CALENDAR-NAME/pers%c3%b6nlich?export"
                            Change the capital into your needs
                            The link without the credentials you will get in nextcloud in Calendar-app behind the related calendar, pressing 3 dots and copy privat link.
                            Hope that will help.
                            cheers, bdream
                            • C Offline
                              codac
                              I’m still struggeling. I have tried several versions of the url and with credentials in the url or as a parameter, nothing works and the MagicMirror shows: loading calendar…
                              The weird thing is that the URL itself works like a charm as long as I post it in a web browser. I do get an .ics file immediately.
                              So maybe if the url is correct, I do need to change some settings in nextcloud?
                              For example has the calendar to be public?
                              My current working (in browser only) version is:
                                                   symbol: "calendar-check",
                                                   url: "https://USERNAME:PASSWORD@DOMAIN/remote.php/dav/calendars/USERNAME/persoenlich/?export",
                              Any help?
                              • O oldrocker referenced this topic on
