    Builtin calendar module: dateformat, timeformat
    3 Posts 2 Posters 450 Views 2 Watching
      DomRep
      Hey folks,
      I’m on the last mile setting up my MM as smart display for the kitchen. May layout is almost finished, but I have a minor configuration problem with the calendar:
      In the config-excerpt below there are 3 CalDAV-Calendars (URL truncated for privacy) that are working and displayed correctly.
      configuration options are identical to the sample config, except symbol and color and of course the URL.
      But when I tried to change the format for the SECOND calendar, nothing changes.
      What I wanted:
      The second calendar should show absolute dates (Mo. 01.01.) and start and end time in 24h format.
      What I get:
      Entries are displayed with relative dates (tomorrow at) and only start times in 24h-Format, just like the other two calendars where I kept the default format.
      I’ve tried to follow the documentation and I’m a little bit disappointed that I didn’t even manage to produce an error, but that MM just ignores my effort ;)
      Do you know where I took the wrong turn?
      Thanx, Markus
                                      maximumEntries: "20",
                                      coloredSymbol: "true",
                                                      symbol: "calendar",
                                                      color: "#0000ff",
                                                      url: "https://posteo.de/calendars/ics/6yjd...>
                                                      dateFormat: "ddd HH:mm",
                                                      timeFormat: "absolute",
                                                      showEnd: true,
                                                      symbol: "calendar",
                                                      color: "#ff0000",
                                                      url: "https://posteo.de/calendars/ics/muj1cn...>
                                                      symbol: "calendar",
                                                      color: "#ffff00",
                                                      url: "https://posteo.de/calendars/ics/6cehmh4...>
        sdetweil @DomRep
        @DomRep unfortunately the dateFormat/timeFormat/showEnd options apply to ALL calendars, so they would have to be above the calendars:[] list
        in the doc,
        • the first section of parameters are for ALL calendars…
        • the second section is for individual calendars…
        you can create another module: calendar for that one in the same position
        but the entries will not be merged with the others.
        I would suggest opening an issue on the github repo asking for an enhancement here.
        and post your config… (as u have here)
          DomRep @sdetweil
          @sdetweil said in Builtin calendar module: dateformat, timeformat:
          in the doc,
          So there’s my misunderstanding: It’s a global setting :)
          Actually, having to set these config values for all calendars alike is fine for me…
          I just started to test the effect for “calendar two” because I wanted to compare the effect against the others two.
          In my original post I emphasized this (the SECOND calendar) just to make following my pursuit easier for forum readers.
          Thank you @sdetweil for the clarification :)
