Module Update Question
7 Posts 2 Posters 1.2k Views 2 Watching
  • O Offline
    oldrocker
    I apologize in advance for the ignorance.
    When building a module, how do I periodically update a variable? For example, let’s say I have a variable that is an array or list of files found on a share. I have to fetch the list on start, how do I tell it to do it again in 10 minutes in case there has been a change?
    S 1 Reply Last reply Nov 16, 2023, 5:41 PM Reply Quote 0
      sdetweil @oldrocker
      @oldrocker In JavaScript there are two timing functions
      setTimeout
      and
      setInterval
      both take a function to call
      and numbers of milliseconds before calling the function
      timeout calls once
      interval calls over and over
      each returns an if that can be used to cancel the time function
      O 2 Replies Last reply Nov 16, 2023, 6:59 PM Reply Quote 0
      • O Offline
        oldrocker @sdetweil
        Ok, that helps a little. I’ll try some things with setInterval and come back again when I’m stuck. I see a lot of examples where updateDom is included in the setInterval. That just updates the config if necessary, correct?
        S 1 Reply Last reply Nov 17, 2023, 2:40 PM Reply Quote 0
        • O Offline
          oldrocker @sdetweil
          @sdetweil I did it.
          Thanks for the help!
            sdetweil @oldrocker
            @oldrocker the call to updateDom() tells MM runtime that your module has new/updated content, and the MM runtime will call your getDom() method to get that ‘new’ content to replace what is already displayed.
            O 1 Reply Last reply Nov 17, 2023, 2:47 PM Reply Quote 0
            • O Offline
              oldrocker @sdetweil
              @sdetweil If I understand you correctly, the call to the Dom is for the visual content update and not necessary after updating data the running module relies on unless that data is to be immediately displayed.
              S 1 Reply Last reply Nov 17, 2023, 2:52 PM Reply Quote 0
                sdetweil @oldrocker
                @oldrocker correct,… only for visual content change… MM doesn’t know anything else the modules does…
