    MagicMirror using the wrong time
    54 Posts 6 Posters 32.6k Views 6 Watching
      blissb @sdetweil
      And yet it is not according to everything I can see.
        sdetweil @blissb
        @blissb how about thru the preferences, in the menu, top left on the desktop
        this is a pi, yes?
          blissb @sdetweil
          I know I haven’t said it, but I really appreciate you looking at this… it’s been driving me nuts since the last update messed things up.
          I just tested hard-coding the timezone in calendarfetcherutils.js – replaced “moment.tz.guess()” with “America/New_York” on line 29. That has removed the “Lima” entries in the debug log, but it has not corrected the time issue.
          Yes, I’m running on a Pi. Here’s what’s in preferences:
            sdetweil @blissb
            @blissb what is the locale above the tz?
              blissb @sdetweil
              On my second MagicMirror I restored the backup of the last version of MM, and made no other changes. The debug info shows no instances of the “lima” timezone, and all times are correct.
              I went back to the most recent version, reran with debug, and the “Lima” instance is back, as are the wrong times.
              I’ll be reverting to the previous version of MM for the moment, but please let me know if there’s anything else I can do to help with troubleshooting this really annoying issue!
                blissb @sdetweil
                Locale is:
                  sdetweil @blissb
                  @blissb great info!!! thanks.
                  this sounds like a bad moment lib.
                    @blissb can you show me the list of active modules, in the order in config.js
                    thx
                      blissb @sdetweil
                      Is there an easier way to get them other than just scrolling through the config.js?
                      Modules in order:
                      alert
                      clock (correct after adding the timezone: option)
                      calendar
                      weather (Sunrise time is also 5 hours off - sorry if I failed to mention that earlier)
                        sdetweil @blissb
                        @blissb you could grep for ‘module:’
                          blissb @sdetweil
                          Doh!
                            sdetweil @blissb
                            @blissb I can’t tell you how many times I do that in a week! 😆
                            how did you upgrade mm?
                              blissb @sdetweil
                              @sdetweil I have a script that moves the MM directory to backup, gets rid of the various package-lock.json files, then does a git pull && npm install --only=prod --omit=dev
                                sdetweil @blissb
                                @blissb ok. see these
                                and
                                https://github.com/sdetweil/MagicMirror-backup-restore
                                I’m wondering if the npm install in the vendor folder failed. that is where moment is loaded
                                the fact that clock and weather and calendar are all messed up., is pretty interesting
                                  blissb @sdetweil
                                  I renamed the MagicMirror directory, and re-installed using the install script – iirc that’s what I used initially.
                                  Sadly, no change.
                                  Giving up for now – may poke at it more tomorrow. Thanks again.
                                    sdetweil @blissb
                                    @blissb would you be willing to share your config.js, send to me as a text file
                                    same userid as here, at gmail
                                    B 3 Replies Last reply Reply Quote 0
                                      blissb @sdetweil
                                      I think I can do that. I’ll send it after work.
                                        blissb @sdetweil
                                        You’ve probably seen it by now - but I’ve sent you the config.js.
                                        Also, I saw some info about times being correct when viewed on a remote browser. I’ve tried setting the external browser in my “mm.sh” script to both midori and firefox (both are installed). Neither makes a difference.
                                          blissb @sdetweil
                                          If this is a red-herring / rabbit-hole, I apologize in advance. I haven’t done any javascript in 10+ years… all this is sorcery to me. :beaming_face_with_smiling_eyes:
                                          I configured it to allow remote access via a browser on my desktop machine. On the pi running the newer (wrong time) version of MM, the browser displays the correct time, while the pi displays the wrong time. That’s kind of fascinating to me… clearly the browser is calculating the times on its own.
                                            sdetweil @blissb
                                            @blissb yes, someone else reported similar issue
                                            the Midori/Firefox only work if the start line is changed in package.json
                                            • 2 / 3
