    MagicMirror using the wrong time
    54 Posts 6 Posters 31.9k Views 6 Watching
      sdetweil @blissb
      @blissb what is the locale above the tz?
        blissb @sdetweil
        On my second MagicMirror I restored the backup of the last version of MM, and made no other changes. The debug info shows no instances of the “lima” timezone, and all times are correct.
        I went back to the most recent version, reran with debug, and the “Lima” instance is back, as are the wrong times.
        I’ll be reverting to the previous version of MM for the moment, but please let me know if there’s anything else I can do to help with troubleshooting this really annoying issue!
          blissb @sdetweil
          Locale is:
            sdetweil @blissb
            @blissb great info!!! thanks.
            this sounds like a bad moment lib.
              @blissb can you show me the list of active modules, in the order in config.js
              thx
                blissb @sdetweil
                Is there an easier way to get them other than just scrolling through the config.js?
                Modules in order:
                alert
                clock (correct after adding the timezone: option)
                calendar
                weather (Sunrise time is also 5 hours off - sorry if I failed to mention that earlier)
                  sdetweil @blissb
                  @blissb you could grep for ‘module:’
                    blissb @sdetweil
                    Doh!
                      sdetweil @blissb
                      @blissb I can’t tell you how many times I do that in a week! 😆
                      how did you upgrade mm?
                        blissb @sdetweil
                        @sdetweil I have a script that moves the MM directory to backup, gets rid of the various package-lock.json files, then does a git pull && npm install --only=prod --omit=dev
                          sdetweil @blissb
                          @blissb ok. see these
                          and
                          https://github.com/sdetweil/MagicMirror-backup-restore
                          I’m wondering if the npm install in the vendor folder failed. that is where moment is loaded
                          the fact that clock and weather and calendar are all messed up., is pretty interesting
                            blissb @sdetweil
                            I renamed the MagicMirror directory, and re-installed using the install script – iirc that’s what I used initially.
                            Sadly, no change.
                            Giving up for now – may poke at it more tomorrow. Thanks again.
                              sdetweil @blissb
                              @blissb would you be willing to share your config.js, send to me as a text file
                              same userid as here, at gmail
                              B 3 Replies Last reply Reply Quote 0
                                blissb @sdetweil
                                I think I can do that. I’ll send it after work.
                                  blissb @sdetweil
                                  You’ve probably seen it by now - but I’ve sent you the config.js.
                                  Also, I saw some info about times being correct when viewed on a remote browser. I’ve tried setting the external browser in my “mm.sh” script to both midori and firefox (both are installed). Neither makes a difference.
                                    blissb @sdetweil
                                    If this is a red-herring / rabbit-hole, I apologize in advance. I haven’t done any javascript in 10+ years… all this is sorcery to me. :beaming_face_with_smiling_eyes:
                                    I configured it to allow remote access via a browser on my desktop machine. On the pi running the newer (wrong time) version of MM, the browser displays the correct time, while the pi displays the wrong time. That’s kind of fascinating to me… clearly the browser is calculating the times on its own.
                                      sdetweil @blissb
                                      @blissb yes, someone else reported similar issue
                                      the Midori/Firefox only work if the start line is changed in package.json
                                        sdetweil @blissb
                                        @blissb would you be willing to send me one of the extracted ics files
                                        curl -sL the cal_url >somefile.ics.txt
                                        because those are the ones causing the shift problem…
                                        I want to see how the ICS is coded
                                        same email ias the config
                                          blissb @sdetweil
                                          @sdetweil I sent the ics file – forgot to rename it with .txt. Let me know if I need to resend.
                                            sdetweil @blissb
                                            @blissb I have it. need to test.
                                            • 2 / 3
