    MagicMirror using the wrong time
    54 Posts 6 Posters 33.8k Views 6 Watching
      blissb @sdetweil
      @sdetweil I have a script that moves the MM directory to backup, gets rid of the various package-lock.json files, then does a git pull && npm install --only=prod --omit=dev
        sdetweil @blissb
        @blissb ok. see these
        and
        https://github.com/sdetweil/MagicMirror-backup-restore
        I’m wondering if the npm install in the vendor folder failed. that is where moment is loaded
        the fact that clock and weather and calendar are all messed up., is pretty interesting
        B 1 Reply Last reply
          blissb @sdetweil
          I renamed the MagicMirror directory, and re-installed using the install script – iirc that’s what I used initially.
          Sadly, no change.
          Giving up for now – may poke at it more tomorrow. Thanks again.
            sdetweil @blissb
            @blissb would you be willing to share your config.js, send to me as a text file
            same userid as here, at gmail
            B 3 Replies Last reply
              blissb @sdetweil
              I think I can do that. I’ll send it after work.
                blissb @sdetweil
                You’ve probably seen it by now - but I’ve sent you the config.js.
                Also, I saw some info about times being correct when viewed on a remote browser. I’ve tried setting the external browser in my “mm.sh” script to both midori and firefox (both are installed). Neither makes a difference.
                  blissb @sdetweil
                  If this is a red-herring / rabbit-hole, I apologize in advance. I haven’t done any javascript in 10+ years… all this is sorcery to me. :beaming_face_with_smiling_eyes:
                  I configured it to allow remote access via a browser on my desktop machine. On the pi running the newer (wrong time) version of MM, the browser displays the correct time, while the pi displays the wrong time. That’s kind of fascinating to me… clearly the browser is calculating the times on its own.
                    sdetweil @blissb
                    @blissb yes, someone else reported similar issue
                    the Midori/Firefox only work if the start line is changed in package.json
                      sdetweil @blissb
                      @blissb would you be willing to send me one of the extracted ics files
                      curl -sL the cal_url >somefile.ics.txt
                      because those are the ones causing the shift problem…
                      I want to see how the ICS is coded
                      same email ias the config
                        blissb @sdetweil
                        @sdetweil I sent the ics file – forgot to rename it with .txt. Let me know if I need to resend.
                        S 2 Replies Last reply
                          sdetweil @blissb
                          @blissb I have it. need to test.
                            sdetweil @blissb
                            @blissb i can’t recreate it on any system…
                            if you’ve got time, could you make another sde card and reinstall mm using my script?
                            and use your config.js
                              blissb @sdetweil
                              @sdetweil Just wanted to let you know, I’m working on this between other tasks. I’m also prepping for the Thanksgiving holiday tomorrow, so if I don’t get it finished tonight, it may be Friday before I get back with you.
                                sdetweil @blissb
                                @blissb no rush. when/if you have time
                                B 2 Replies Last reply
                                  blissb @sdetweil
                                  I’m having some really odd problems with the raspbian install. Starting to wonder about the hardware. It’s a RPi 2B that’s been rock solid for years, but for whatever reason it won’t boot from any newly flashed SD card - though it boots fine from the original.
                                  I have another one in a box somewhere. I’ll pull it out and give it a try – I’d hate to think I’ve wasted your time over flakey hardware – but the fact that the other one is working as expected with the previous MM version makes me think (hope!) that’s not the case.
                                  I’ll definitely keep you posted!
                                    blissb @sdetweil
                                    I pulled out another Pi, flashed the OS and installed MM using the script you referenced earlier. It’s working perfectly. I’m still completely baffled. I’ve triple checked on the original SD image - it works as expected on the previous version of MM, but not on the current one… Ah well –
                                    Thank you for taking so much time to look into this, and I am sorry for having wasted so much of your time.
                                      sdetweil @blissb
                                      @blissb not wasted time, interesting problem.
                                      glad we’ve found something that resolves it.
                                      thank for your feedback
                                      J 1 Reply Last reply
                                        jasonumd @sdetweil
                                        @sdetweil I’m chiming in a bit late here. Has there been any more widespread report of calendar times being off? Mine worked flawless for years then the past few months times are off, presumably UTC as mentioned in this thread.
                                        I’m having a hard time seeing what the actual solution was?
                                        Thanks so much in advance!
                                          sdetweil @jasonumd
                                          @jasonumd so far, every time events have been off, the system timezone has not been set correctly…
                                          note that a docker container is its own system and needs ITS timezone set too…
                                          what changed since it worked to now?
                                          J 2 Replies Last reply
                                            jasonumd @sdetweil
                                            @sdetweil I changed absolutely nothing. Just applied regular MM updates. I will investigate those two settings ASAP.
                                            N 1 Reply Last reply
                                            • 2 / 3
