    MagicMirror using the wrong time
    54 Posts 6 Posters 31.9k Views 6 Watching
      blissb @sdetweil
      You’ve probably seen it by now - but I’ve sent you the config.js.
      Also, I saw some info about times being correct when viewed on a remote browser. I’ve tried setting the external browser in my “mm.sh” script to both midori and firefox (both are installed). Neither makes a difference.
        blissb @sdetweil
        If this is a red-herring / rabbit-hole, I apologize in advance. I haven’t done any javascript in 10+ years… all this is sorcery to me. :beaming_face_with_smiling_eyes:
        I configured it to allow remote access via a browser on my desktop machine. On the pi running the newer (wrong time) version of MM, the browser displays the correct time, while the pi displays the wrong time. That’s kind of fascinating to me… clearly the browser is calculating the times on its own.
          sdetweil @blissb
          @blissb yes, someone else reported similar issue
          the Midori/Firefox only work if the start line is changed in package.json
            sdetweil @blissb
            @blissb would you be willing to send me one of the extracted ics files
            curl -sL the cal_url >somefile.ics.txt
            because those are the ones causing the shift problem…
            I want to see how the ICS is coded
            same email ias the config
              blissb @sdetweil
              @sdetweil I sent the ics file – forgot to rename it with .txt. Let me know if I need to resend.
                sdetweil @blissb
                @blissb I have it. need to test.
                  sdetweil @blissb
                  @blissb i can’t recreate it on any system…
                  if you’ve got time, could you make another sde card and reinstall mm using my script?
                  and use your config.js
                    blissb @sdetweil
                    @sdetweil Just wanted to let you know, I’m working on this between other tasks. I’m also prepping for the Thanksgiving holiday tomorrow, so if I don’t get it finished tonight, it may be Friday before I get back with you.
                      sdetweil @blissb
                      @blissb no rush. when/if you have time
                        blissb @sdetweil
                        I’m having some really odd problems with the raspbian install. Starting to wonder about the hardware. It’s a RPi 2B that’s been rock solid for years, but for whatever reason it won’t boot from any newly flashed SD card - though it boots fine from the original.
                        I have another one in a box somewhere. I’ll pull it out and give it a try – I’d hate to think I’ve wasted your time over flakey hardware – but the fact that the other one is working as expected with the previous MM version makes me think (hope!) that’s not the case.
                        I’ll definitely keep you posted!
                          blissb @sdetweil
                          I pulled out another Pi, flashed the OS and installed MM using the script you referenced earlier. It’s working perfectly. I’m still completely baffled. I’ve triple checked on the original SD image - it works as expected on the previous version of MM, but not on the current one… Ah well –
                          Thank you for taking so much time to look into this, and I am sorry for having wasted so much of your time.
                            sdetweil @blissb
                            @blissb not wasted time, interesting problem.
                            glad we’ve found something that resolves it.
                            thank for your feedback
                              jasonumd @sdetweil
                              @sdetweil I’m chiming in a bit late here. Has there been any more widespread report of calendar times being off? Mine worked flawless for years then the past few months times are off, presumably UTC as mentioned in this thread.
                              I’m having a hard time seeing what the actual solution was?
                              Thanks so much in advance!
                                sdetweil @jasonumd
                                @jasonumd so far, every time events have been off, the system timezone has not been set correctly…
                                note that a docker container is its own system and needs ITS timezone set too…
                                what changed since it worked to now?
                                  jasonumd @sdetweil
                                  @sdetweil I changed absolutely nothing. Just applied regular MM updates. I will investigate those two settings ASAP.
                                  • N Offline
                                    n1sni @jasonumd
                                    @jasonumd Same - I have been running this for years… and just did “git pull” and “npm update” in two separate module directories and now I’m UTC. “date” from the console shows the correct date/time.
                                    Raspberry pi…
                                    Linux mm 5.15.90-v7+ #1623 SMP Mon Jan 30 14:59:14 GMT 2023 armv7l GNU/Linux
                                    Running the MagicMirror docker.
                                      sdetweil @n1sni
                                      @n1sni edit the docker container parms to add
                                      environment:
                                             TZ:your_timezone
                                      else it defaults to UTC
                                      • N Offline
                                        n1sni @sdetweil
                                        @sdetweil said in MagicMirror using the wrong time:
                                        TZ=your_timezone
                                        Wow, that was easy :)
                                        Thank you!!
                                        pi@mm:~/magicmirror/run $ pwd
                                        /home/pi/magicmirror/run
                                        pi@mm:~/magicmirror/run $ vi docker-compose.yml
                                            devices:
                                              - /dev/vchiq
                                            environment:
                                              DISPLAY: unix:0.0
                                              TZ: America/New_York   # <- This line added
                                            network_mode: host
                                          jasonumd @sdetweil
                                          @sdetweil I just confirmed my system timezone is accurate. I’m not running MM via docker. I set this up probably 4 years ago. Perhaps I should do a fresh install.
                                            sdetweil @jasonumd
                                            @jasonumd just for the sake of fun testing
                                            in the script you use to start MM add
                                            export TZ=????
                                            where ??? is your timezone code
                                            add this line before the
                                            npm start
                                            line
                                            if you are using my install script with PM2, then the script located at
                                            ~/MagicMirror/installers/mm.sh
                                            • 3 / 3
