    MagicMirror using the wrong time
    54 Posts 6 Posters 33.8k Views 6 Watching
      sdetweil @blissb
      @blissb no rush. when/if you have time
      B 2 Replies Last reply
        blissb @sdetweil
        I’m having some really odd problems with the raspbian install. Starting to wonder about the hardware. It’s a RPi 2B that’s been rock solid for years, but for whatever reason it won’t boot from any newly flashed SD card - though it boots fine from the original.
        I have another one in a box somewhere. I’ll pull it out and give it a try – I’d hate to think I’ve wasted your time over flakey hardware – but the fact that the other one is working as expected with the previous MM version makes me think (hope!) that’s not the case.
        I’ll definitely keep you posted!
          blissb @sdetweil
          I pulled out another Pi, flashed the OS and installed MM using the script you referenced earlier. It’s working perfectly. I’m still completely baffled. I’ve triple checked on the original SD image - it works as expected on the previous version of MM, but not on the current one… Ah well –
          Thank you for taking so much time to look into this, and I am sorry for having wasted so much of your time.
            sdetweil @blissb
            @blissb not wasted time, interesting problem.
            glad we’ve found something that resolves it.
            thank for your feedback
            J 1 Reply Last reply
              jasonumd @sdetweil
              @sdetweil I’m chiming in a bit late here. Has there been any more widespread report of calendar times being off? Mine worked flawless for years then the past few months times are off, presumably UTC as mentioned in this thread.
              I’m having a hard time seeing what the actual solution was?
              Thanks so much in advance!
                sdetweil @jasonumd
                @jasonumd so far, every time events have been off, the system timezone has not been set correctly…
                note that a docker container is its own system and needs ITS timezone set too…
                what changed since it worked to now?
                J 2 Replies Last reply
                  jasonumd @sdetweil
                  @sdetweil I changed absolutely nothing. Just applied regular MM updates. I will investigate those two settings ASAP.
                  N 1 Reply Last reply
                  • N
                    n1sni @jasonumd
                    @jasonumd Same - I have been running this for years… and just did “git pull” and “npm update” in two separate module directories and now I’m UTC. “date” from the console shows the correct date/time.
                    Raspberry pi…
                    Linux mm 5.15.90-v7+ #1623 SMP Mon Jan 30 14:59:14 GMT 2023 armv7l GNU/Linux
                    Running the MagicMirror docker.
                      sdetweil @n1sni
                      @n1sni edit the docker container parms to add
                      environment:
                             TZ:your_timezone
                      else it defaults to UTC
                      • N
                        n1sni @sdetweil
                        @sdetweil said in MagicMirror using the wrong time:
                        TZ=your_timezone
                        Wow, that was easy :)
                        Thank you!!
                        pi@mm:~/magicmirror/run $ pwd
                        /home/pi/magicmirror/run
                        pi@mm:~/magicmirror/run $ vi docker-compose.yml
                            devices:
                              - /dev/vchiq
                            environment:
                              DISPLAY: unix:0.0
                              TZ: America/New_York   # <- This line added
                            network_mode: host
                          jasonumd @sdetweil
                          @sdetweil I just confirmed my system timezone is accurate. I’m not running MM via docker. I set this up probably 4 years ago. Perhaps I should do a fresh install.
                            sdetweil @jasonumd
                            @jasonumd just for the sake of fun testing
                            in the script you use to start MM add
                            export TZ=????
                            where ??? is your timezone code
                            add this line before the
                            npm start
                            line
                            if you are using my install script with PM2, then the script located at
                            ~/MagicMirror/installers/mm.sh
                              jasonumd @sdetweil
                              @sdetweil I’m not a linux guru. Added and rebooted. but I’m operating via Putty. Am I supposed to reboot while watching the screen and check for something?
                              S 2 Replies Last reply
                                sdetweil @jasonumd
                                @jasonumd just seeing if MM reports correctly
                                  sdetweil @jasonumd
                                  @jasonumd didn’t need to reboot… if using pm2, then
                                  pm2 status
                                  pm2 restart xx
                                  where x is the number of the line of the MagicMirror app
                                  or the name shown on that same line (I set it up as MagicMirror, others get mm as they started mm.sh)
                                  • 3 / 3
