    Crashing after "Starting Server"
    13 Posts 3 Posters 2.4k Views 4 Watching
      sdetweil @BEGreen87
      @BEGreen87 what is all that junk at the end?
        sdetweil @BEGreen87
        @BEGreen87 move the mm folder out of the way
        and run my install script
        you may want to backup your mirror setup and restore after
        https://github.com/sdetweil/MagicMirror-backup-restore
          MMRIZE @BEGreen87
          @BEGreen87
          [20.11.2023 15:43.16.453] [ERROR] Error: Cannot find module 'fetch'
          Require stack:
          - /magicmirror2/modules/default/calendar/calendarfetcher.js
          This is very weird log, because calendarfetcer.js doesn’t call require("fetch") in the source, so there is no reason of that error. Is the source modified? Can you check the source is the same with original?
            BEGreen87 @MMRIZE
            @MMRIZE Looks like I match the 2.23.0 Release.
              BEGreen87 @MMRIZE
              @MMRIZE @sdetweil
              Thanks for all the help, was able to resolve the issue by replacing all the files in /modules/default/calendar with the ones for the latest release.
              Not sure why this didn’t occur during the update, but looks like I’m back in business!
                sdetweil @BEGreen87
                @BEGreen87 weird
                from the MagicMirror folder do
                git status
                and report the results if you can
                  BEGreen87 @sdetweil
                  fatal: not a git repository (or any parent up to mount point /)
                  Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
                  Guessing this is because I’m using using it in Docker?
                    sdetweil @BEGreen87
                    @BEGreen87 yeh, maybe
