    Default calendar stuck on loading
    3 Posts 2 Posters 375 Views 2 Watching
      rk9
      The default calendar module is just stuck on loading. It worked for over a year but randomly stopped working without any config changes. Any suggestions on a fix?
        sdetweil @rk9
        @rk9 can you look where you do npm start and see what the message say
        if you use pm2 to auto start mm, then
        pm2 logs – lines=100
          sdetweil @rk9
          @rk9 from the logs you sent, it’s a down level version of nodejs ( calendar module is complaining about fetch not found)
          if you had used my script to upgrade, then the script would have fixed that.
          you can try still with the upgrade script and adding the parameter
          force
          at the end
