    MagicMirror2 Default Calendar module does not display reoccuring Monthly, or Weekly events with in your GMT window.
    19 Posts 2 Posters 3.8k Views 2 Watching
      sdetweil @jbat66
      @jbat66 said in MagicMirror2 Default Calendar module does not display reoccuring Monthly, or Weekly events with in your GMT window.:
      171500
      yeh, 17+7=24 is a problem with the parser
      16+7=23…
        jbat66 @sdetweil
        @sdetweil Thanks for the info. Do you think there is fix coming on next release, for this issue?
          sdetweil @jbat66
          @jbat66 I think so, you can test it out
          npm install node-ical@0.17.0
          and restart MagicMirror
            jbat66 @sdetweil
            @sdetweil said in MagicMirror2 Default Calendar module does not display reoccuring Monthly, or Weekly events with in your GMT window.:
            I tried it, but it made no difference. :-(
              sdetweil @jbat66
              @jbat66 hm… i’ll test it tomorrow morning
                sdetweil @jbat66
                @jbat66 do this
                npm remove luxon
                then rerun the tests… I have them both in the same ics
                BEGIN:VCALENDAR
                BEGIN:VEVENT
                DTSTART;TZID=America/Denver:20231205T171500
                DTEND;TZID=America/Denver:20231205T181500
                RRULE:FREQ=WEEKLY;BYDAY=TU
                DTSTAMP:20231212T213725Z
                UID:ccccccc
                CREATED:20231212T213613Z
                LAST-MODIFIED:20231212T213613Z
                SEQUENCE:0
                STATUS:CONFIRMED
                SUMMARY:test weekly at 5:15pm
                TRANSP:OPAQUE
                END:VEVENT
                BEGIN:VEVENT
                DTSTART;TZID=America/Denver:20231205T164500
                DTEND;TZID=America/Denver:20231205T174500
                UID:ccccc
                CREATED:20231212T213523Z
                LAST-MODIFIED:20231212T213537Z
                SEQUENCE:2
                STATUS:CONFIRMED
                SUMMARY:test weekly at 4:45pm
                TRANSP:OPAQUE
                END:VEVENT
                END:VCALENDAR
                I put that in the calendar module folder as testing.ics
                set my TZ to denver
                calendar url
                url: “http://localhost:8080/modules/default/calendar/testing.ics”
                make sure to check the port on your config.js
                  jbat66 @sdetweil
                  npm remove luxon
                  Before removing luxon, I got the local ics working, but because it was for Tuesday and today is Wednesday it worked, any reoccuring in the future work, just today’s does not. So I added two entries in the local ics file for Wednesday as well as left in the Tuesday entries.
                  I also made a new google calendar and made Wednesday repeating as well. Both the local test and the google test do not show up anything after 5pm mst. I did the removal and there was no change. I did restart MM between the test. Here is the updated ICS
                  BEGIN:VCALENDAR
                  BEGIN:VEVENT
                  UID:ccccccc
                  SEQUENCE:0
                  STATUS:CONFIRMED
                  SUMMARY:Local test tue weekly at 5:15pm
                  TRANSP:OPAQUE
                  END:VEVENT
                  BEGIN:VEVENT
                  UID:ccccc
                  SEQUENCE:2
                  STATUS:CONFIRMED
                  SUMMARY:Local test tue weekly at 4:45pm
                  TRANSP:OPAQUE
                  END:VEVENT
                  BEGIN:VEVENT
                  DTSTART;TZID=America/Denver:20231206T171500
                  DTEND;TZID=America/Denver:20231206T181500
                  RRULE:FREQ=WEEKLY;BYDAY=WE
                  UID:ccccccc
                  SEQUENCE:0
                  STATUS:CONFIRMED
                  SUMMARY:Local test wed weekly at 5:15pm
                  TRANSP:OPAQUE
                  END:VEVENT
                  BEGIN:VEVENT
                  DTSTART;TZID=America/Denver:20231206T164500
                  DTEND;TZID=America/Denver:20231206T174500
                  UID:ccccc
                  SEQUENCE:2
                  STATUS:CONFIRMED
                  SUMMARY:Local test wed weekly at 4:45pm
                  TRANSP:OPAQUE
                  END:VEVENT
                  END:VCALENDAR
                  Here is my config.js
                  disabled: false,
                  module: “calendar”,
                  header: “Jim and Paula”,
                  position: “top_left”,
                  limitDays: 0, // Days to search into the future 0 is unlimited
                  maximumNumberOfDays: 30, // The maximum number of days in the future. You may have to restart MM for this to work.
                  maximumEntries: 10, // The maximum number of events shown.
                  timeFormat: “relative”, //Display event times as absolute dates, or relative time, or using absolute date headers with times for each event next to it (absolute, relative,)
                  getRelative: 0, // How much time (in hours) should be left until calendar events start getting relative? Possible values: 0 (events stay absolute) - 48 (48 hours before the event starts) Default value: 6
                  urgency: 7, // If timeFormat of absolute the urgency setting display events within a specific time frame as relative. a positive integer representing the number of days for which you want a relative date Default 6
                  nextDaysRelative: false, // If this is set to true, the appointments of today and tomorrow are displayed relatively, even if the timeformat is set to absolute.Default: false
                  fade: false,
                  fadePoint: 0.25,
                  maxTitleLength: 45, // The maximum title length.
                  wrapEvents: false, // Wrap event titles to multiple lines. Breaks lines at the length defined by maxTitleLength
                  maxTitleLines: 1, // The maximum number of lines a title will wrap vertically before being cut (Only enabled if wrapEvents is also enabled)
                  fetchInterval: 60000,
                  sliceMultiDayEvents: false, // If this is set to true, events exceeding at least one midnight will be sliced into separate events including a counter like (1/2). This is especially helpful in “dateheaders” mode.
                  tableClass: “small”, // Name of the classes issued from main.css. Possible values: xsmall, small, medium, large, xlarge.Default small.
                  customEvents: [{keyword: ‘Birthday’, symbol: ‘birthday-cake’, color: ‘Gold’}],
                  symbol: “building”,
                  url: “https://calendar.google.com/calendar/ical/bd007470089e22eace0d824caab026a2b1ef7290f6c51f166c166f7f47d551dd%40group.calendar.google.com/public/basic.ics” //testing via google public url
                  symbol: “house”,
                  url: “http://magicmirror-rv.rendezvous:8080/modules/default/calendar/testing.ics” //testing
                  2023-12-13 11_42_07-mRemoteNG - confCons.xml - magicmirror-rv.png 2023-12-13 11_41_02-Google Calendar - December 2023 — Mozilla Firefox.png 2023-12-13 11_40_04-MagicMirror² — Mozilla Firefox.png 2023-12-13 11_43_05-MagicMirror² — Mozilla Firefox.png
                    sdetweil @jbat66
                    @jbat66 I’ll look at that but the original events are for Tuesday, so can’t show today (Wednesday)
                      jbat66 @sdetweil
                      @sdetweil I appreciate you looking into this.
                      There should be a “Local test wed Weekly at 5:15pm” for today that doesn’t show up, and a “Google test weekly on Wed at 5:30pm” that doesn’t show up.
                        sdetweil @jbat66
                        @jbat66 ok, for the test file the UUID values have to be unique
                        UID:ccccccc
