    MagicMirror2 Default Calendar module does not display reoccuring Monthly, or Weekly events with in your GMT window.
    19 Posts 2 Posters 4.9k Views 2 Watching
      jbat66 @sdetweil
      Howdy from Wyoming, I’m MDT GMT -7
      This one works
      BEGIN:VEVENT
      DTSTART;TZID=America/Denver:20231205T164500
      DTEND;TZID=America/Denver:20231205T174500
      RRULE:FREQ=WEEKLY;BYDAY=TU
      DTSTAMP:20231212T213725Z
      UID:ccccc
      CREATED:20231212T213523Z
      LAST-MODIFIED:20231212T213537Z
      SEQUENCE:2
      STATUS:CONFIRMED
      SUMMARY:test weekly at 4:45pm
      TRANSP:OPAQUE
      END:VEVENT
      Below doesn’t work
      BEGIN:VEVENT
      DTSTART;TZID=America/Denver:20231205T171500
      DTEND;TZID=America/Denver:20231205T181500
      UID:ccccccc
      CREATED:20231212T213613Z
      LAST-MODIFIED:20231212T213613Z
      SEQUENCE:0
      STATUS:CONFIRMED
      SUMMARY:test weekly at 5:15pm
      TRANSP:OPAQUE
      END:VEVENT
        sdetweil @jbat66
        @jbat66 said in MagicMirror2 Default Calendar module does not display reoccuring Monthly, or Weekly events with in your GMT window.:
        171500
        yeh, 17+7=24 is a problem with the parser
        16+7=23…
        J 1 Reply Last reply
          jbat66 @sdetweil
          @sdetweil Thanks for the info. Do you think there is fix coming on next release, for this issue?
            sdetweil @jbat66
            @jbat66 I think so, you can test it out
            npm install node-ical@0.17.0
            and restart MagicMirror
              jbat66 @sdetweil
              @sdetweil said in MagicMirror2 Default Calendar module does not display reoccuring Monthly, or Weekly events with in your GMT window.:
              I tried it, but it made no difference. :-(
              S 2 Replies Last reply
                sdetweil @jbat66
                @jbat66 hm… i’ll test it tomorrow morning
                  sdetweil @jbat66
                  @jbat66 do this
                  npm remove luxon
                  then rerun the tests… I have them both in the same ics
                  BEGIN:VCALENDAR
                  BEGIN:VEVENT
                  UID:ccccccc
                  SEQUENCE:0
                  STATUS:CONFIRMED
                  TRANSP:OPAQUE
                  END:VEVENT
                  BEGIN:VEVENT
                  UID:ccccc
                  SEQUENCE:2
                  STATUS:CONFIRMED
                  TRANSP:OPAQUE
                  END:VEVENT
                  END:VCALENDAR
                  I put that in the calendar module folder as testing.ics
                  set my TZ to denver
                  calendar url
                  url: “http://localhost:8080/modules/default/calendar/testing.ics”
                  make sure to check the port on your config.js
                    jbat66 @sdetweil
                    npm remove luxon
                    Before removing luxon, I got the local ics working, but because it was for Tuesday and today is Wednesday it worked, any reoccuring in the future work, just today’s does not. So I added two entries in the local ics file for Wednesday as well as left in the Tuesday entries.
                    I also made a new google calendar and made Wednesday repeating as well. Both the local test and the google test do not show up anything after 5pm mst. I did the removal and there was no change. I did restart MM between the test. Here is the updated ICS
                    BEGIN:VCALENDAR
                    BEGIN:VEVENT
                    UID:ccccccc
                    SEQUENCE:0
                    STATUS:CONFIRMED
                    SUMMARY:Local test tue weekly at 5:15pm
                    TRANSP:OPAQUE
                    END:VEVENT
                    BEGIN:VEVENT
                    UID:ccccc
                    SEQUENCE:2
                    STATUS:CONFIRMED
                    SUMMARY:Local test tue weekly at 4:45pm
                    TRANSP:OPAQUE
                    END:VEVENT
                    BEGIN:VEVENT
                    DTSTART;TZID=America/Denver:20231206T171500
                    DTEND;TZID=America/Denver:20231206T181500
                    RRULE:FREQ=WEEKLY;BYDAY=WE
                    UID:ccccccc
                    SEQUENCE:0
                    STATUS:CONFIRMED
                    SUMMARY:Local test wed weekly at 5:15pm
                    TRANSP:OPAQUE
                    END:VEVENT
                    BEGIN:VEVENT
                    DTSTART;TZID=America/Denver:20231206T164500
                    DTEND;TZID=America/Denver:20231206T174500
                    UID:ccccc
                    SEQUENCE:2
                    STATUS:CONFIRMED
                    SUMMARY:Local test wed weekly at 4:45pm
                    TRANSP:OPAQUE
                    END:VEVENT
                    END:VCALENDAR
                    Here is my config.js
                    disabled: false,
                    module: “calendar”,
                    header: “Jim and Paula”,
                    position: “top_left”,
                    limitDays: 0, // Days to search into the future 0 is unlimited
                    maximumNumberOfDays: 30, // The maximum number of days in the future. You may have to restart MM for this to work.
                    maximumEntries: 10, // The maximum number of events shown.
                    timeFormat: “relative”, //Display event times as absolute dates, or relative time, or using absolute date headers with times for each event next to it (absolute, relative,)
                    getRelative: 0, // How much time (in hours) should be left until calendar events start getting relative? Possible values: 0 (events stay absolute) - 48 (48 hours before the event starts) Default value: 6
                    urgency: 7, // If timeFormat of absolute the urgency setting display events within a specific time frame as relative. a positive integer representing the number of days for which you want a relative date Default 6
                    nextDaysRelative: false, // If this is set to true, the appointments of today and tomorrow are displayed relatively, even if the timeformat is set to absolute.Default: false
                    fade: false,
                    fadePoint: 0.25,
                    maxTitleLength: 45, // The maximum title length.
                    wrapEvents: false, // Wrap event titles to multiple lines. Breaks lines at the length defined by maxTitleLength
                    maxTitleLines: 1, // The maximum number of lines a title will wrap vertically before being cut (Only enabled if wrapEvents is also enabled)
                    fetchInterval: 60000,
                    sliceMultiDayEvents: false, // If this is set to true, events exceeding at least one midnight will be sliced into separate events including a counter like (1/2). This is especially helpful in “dateheaders” mode.
                    tableClass: “small”, // Name of the classes issued from main.css. Possible values: xsmall, small, medium, large, xlarge.Default small.
                    customEvents: [{keyword: ‘Birthday’, symbol: ‘birthday-cake’, color: ‘Gold’}],
                    symbol: “building”,
                    url: “https://calendar.google.com/calendar/ical/bd007470089e22eace0d824caab026a2b1ef7290f6c51f166c166f7f47d551dd%40group.calendar.google.com/public/basic.ics” //testing via google public url
                    symbol: “house”,
                    url: “http://magicmirror-rv.rendezvous:8080/modules/default/calendar/testing.ics” //testing
                    2023-12-13 11_42_07-mRemoteNG - confCons.xml - magicmirror-rv.png 2023-12-13 11_41_02-Google Calendar - December 2023 — Mozilla Firefox.png 2023-12-13 11_40_04-MagicMirror² — Mozilla Firefox.png 2023-12-13 11_43_05-MagicMirror² — Mozilla Firefox.png
                      sdetweil @jbat66
                      @jbat66 I’ll look at that but the original events are for Tuesday, so can’t show today (Wednesday)
                        jbat66 @sdetweil
                        @sdetweil I appreciate you looking into this.
                        There should be a “Local test wed Weekly at 5:15pm” for today that doesn’t show up, and a “Google test weekly on Wed at 5:30pm” that doesn’t show up.
                          sdetweil @jbat66
                          @jbat66 ok, for the test file the UUID values have to be unique
                          UID:ccccccc
                          J 2 Replies Last reply
                            jbat66 @sdetweil
                            Thanks for the UID info. I have not manualy edited an ICS file before and didn’t know that.
                            I updated the UID: to unique values, same results tho. Still missing the google and local after 5pm events.
                            BEGIN:VCALENDAR
                            BEGIN:VEVENT
                            UID:cccccc
                            END:VEVENT
                            BEGIN:VEVENT
                            UID:ccccc
                            END:VEVENT
                            BEGIN:VEVENT
                            UID:cccc
                            END:VEVENT
                            BEGIN:VEVENT
                            UID:ccc
                            END:VEVENT
                            END:VCALENDAR
                              jbat66 @sdetweil
                              UID:ccccccc
                              On your screen shot, you should have a "Local test wed weekly at… 13th Dec, 17:15 entry, but it is missing.
                                sdetweil @jbat66
                                @jbat66 yes, the rrule between is confused
                                search for recurring events between: Wed Dec 13 2023 12:41:01 GMT-0700 (Mountain Standard Time) and Wed Dec 11 2024 23:59:59 GMT-0700 (Mountain Standard Time)
                                [13.12.2023 12:41.01.677] [DEBUG] Title: Local test wed weekly at 5:15pm, with
                                dates: ["2023-12-20T00:15:00.000Z","2023-12-27T00:15:00.000Z","2024-01-
                                2023-12-20T00:15:00.000Z this is 2023-12-19T17:15:00
                                but he clipped of
                                2023-12-14T00:15:00.000Z, which would have been 2023-12-13T17:15:00
                                when the start was
                                Wed Dec 13 2023 12:41:01 but he was looking at 2023-12-13T00:15:00, which has passed… got the time rollover on TZ change wrong…
                                not in our code… will followup w the rrule owners
                                  jbat66 @sdetweil
                                  Thank you so much.
                                    sdetweil @jbat66
                                    @jbat66 I opened this issue, with a sample testcase
                                    returned date incorrect caused by TZ rollover #610
