    MagicMirror2 Default Calendar module does not display reoccuring Monthly, or Weekly events with in your GMT window.
    19 Posts 2 Posters 4.7k Views 2 Watching
      jbat66 @sdetweil
      @sdetweil Thanks for the info. Do you think there is fix coming on next release, for this issue?
        sdetweil @jbat66
        @jbat66 I think so, you can test it out
        npm install node-ical@0.17.0
        and restart MagicMirror
          jbat66 @sdetweil
          @sdetweil said in MagicMirror2 Default Calendar module does not display reoccuring Monthly, or Weekly events with in your GMT window.:
          I tried it, but it made no difference. :-(
            sdetweil @jbat66
            @jbat66 hm… i’ll test it tomorrow morning
              sdetweil @jbat66
              @jbat66 do this
              npm remove luxon
              then rerun the tests… I have them both in the same ics
              BEGIN:VCALENDAR
              BEGIN:VEVENT
              DTSTART;TZID=America/Denver:20231205T171500
              DTEND;TZID=America/Denver:20231205T181500
              RRULE:FREQ=WEEKLY;BYDAY=TU
              DTSTAMP:20231212T213725Z
              UID:ccccccc
              CREATED:20231212T213613Z
              LAST-MODIFIED:20231212T213613Z
              SEQUENCE:0
              STATUS:CONFIRMED
              SUMMARY:test weekly at 5:15pm
              TRANSP:OPAQUE
              END:VEVENT
              BEGIN:VEVENT
              DTSTART;TZID=America/Denver:20231205T164500
              DTEND;TZID=America/Denver:20231205T174500
              UID:ccccc
              CREATED:20231212T213523Z
              LAST-MODIFIED:20231212T213537Z
              SEQUENCE:2
              STATUS:CONFIRMED
              SUMMARY:test weekly at 4:45pm
              TRANSP:OPAQUE
              END:VEVENT
              END:VCALENDAR
              I put that in the calendar module folder as testing.ics
              set my TZ to denver
              calendar url
              url: “http://localhost:8080/modules/default/calendar/testing.ics”
              make sure to check the port on your config.js
                jbat66 @sdetweil
                npm remove luxon
                Before removing luxon, I got the local ics working, but because it was for Tuesday and today is Wednesday it worked, any reoccuring in the future work, just today’s does not. So I added two entries in the local ics file for Wednesday as well as left in the Tuesday entries.
                I also made a new google calendar and made Wednesday repeating as well. Both the local test and the google test do not show up anything after 5pm mst. I did the removal and there was no change. I did restart MM between the test. Here is the updated ICS
                BEGIN:VCALENDAR
                BEGIN:VEVENT
                UID:ccccccc
                SEQUENCE:0
                STATUS:CONFIRMED
                SUMMARY:Local test tue weekly at 5:15pm
                TRANSP:OPAQUE
                END:VEVENT
                BEGIN:VEVENT
                UID:ccccc
                SEQUENCE:2
                STATUS:CONFIRMED
                SUMMARY:Local test tue weekly at 4:45pm
                TRANSP:OPAQUE
                END:VEVENT
                BEGIN:VEVENT
                DTSTART;TZID=America/Denver:20231206T171500
                DTEND;TZID=America/Denver:20231206T181500
                RRULE:FREQ=WEEKLY;BYDAY=WE
                UID:ccccccc
                SEQUENCE:0
                STATUS:CONFIRMED
                SUMMARY:Local test wed weekly at 5:15pm
                TRANSP:OPAQUE
                END:VEVENT
                BEGIN:VEVENT
                DTSTART;TZID=America/Denver:20231206T164500
                DTEND;TZID=America/Denver:20231206T174500
                UID:ccccc
                SEQUENCE:2
                STATUS:CONFIRMED
                SUMMARY:Local test wed weekly at 4:45pm
                TRANSP:OPAQUE
                END:VEVENT
                END:VCALENDAR
                Here is my config.js
                disabled: false,
                module: “calendar”,
                header: “Jim and Paula”,
                position: “top_left”,
                limitDays: 0, // Days to search into the future 0 is unlimited
                maximumNumberOfDays: 30, // The maximum number of days in the future. You may have to restart MM for this to work.
                maximumEntries: 10, // The maximum number of events shown.
                timeFormat: “relative”, //Display event times as absolute dates, or relative time, or using absolute date headers with times for each event next to it (absolute, relative,)
                getRelative: 0, // How much time (in hours) should be left until calendar events start getting relative? Possible values: 0 (events stay absolute) - 48 (48 hours before the event starts) Default value: 6
                urgency: 7, // If timeFormat of absolute the urgency setting display events within a specific time frame as relative. a positive integer representing the number of days for which you want a relative date Default 6
                nextDaysRelative: false, // If this is set to true, the appointments of today and tomorrow are displayed relatively, even if the timeformat is set to absolute.Default: false
                fade: false,
                fadePoint: 0.25,
                maxTitleLength: 45, // The maximum title length.
                wrapEvents: false, // Wrap event titles to multiple lines. Breaks lines at the length defined by maxTitleLength
                maxTitleLines: 1, // The maximum number of lines a title will wrap vertically before being cut (Only enabled if wrapEvents is also enabled)
                fetchInterval: 60000,
                sliceMultiDayEvents: false, // If this is set to true, events exceeding at least one midnight will be sliced into separate events including a counter like (1/2). This is especially helpful in “dateheaders” mode.
                tableClass: “small”, // Name of the classes issued from main.css. Possible values: xsmall, small, medium, large, xlarge.Default small.
                customEvents: [{keyword: ‘Birthday’, symbol: ‘birthday-cake’, color: ‘Gold’}],
                symbol: “building”,
                url: “https://calendar.google.com/calendar/ical/bd007470089e22eace0d824caab026a2b1ef7290f6c51f166c166f7f47d551dd%40group.calendar.google.com/public/basic.ics” //testing via google public url
                symbol: “house”,
                url: “http://magicmirror-rv.rendezvous:8080/modules/default/calendar/testing.ics” //testing
                2023-12-13 11_42_07-mRemoteNG - confCons.xml - magicmirror-rv.png 2023-12-13 11_41_02-Google Calendar - December 2023 — Mozilla Firefox.png 2023-12-13 11_40_04-MagicMirror² — Mozilla Firefox.png 2023-12-13 11_43_05-MagicMirror² — Mozilla Firefox.png
                  sdetweil @jbat66
                  @jbat66 I’ll look at that but the original events are for Tuesday, so can’t show today (Wednesday)
                    jbat66 @sdetweil
                    @sdetweil I appreciate you looking into this.
                    There should be a “Local test wed Weekly at 5:15pm” for today that doesn’t show up, and a “Google test weekly on Wed at 5:30pm” that doesn’t show up.
                      sdetweil @jbat66
                      @jbat66 ok, for the test file the UUID values have to be unique
                      UID:ccccccc
                        jbat66 @sdetweil
                        Thanks for the UID info. I have not manualy edited an ICS file before and didn’t know that.
                        I updated the UID: to unique values, same results tho. Still missing the google and local after 5pm events.
                        BEGIN:VCALENDAR
                        BEGIN:VEVENT
                        UID:cccccc
                        END:VEVENT
                        BEGIN:VEVENT
                        UID:ccccc
                        END:VEVENT
                        BEGIN:VEVENT
                        UID:cccc
                        END:VEVENT
                        BEGIN:VEVENT
                        UID:ccc
                        END:VEVENT
                        END:VCALENDAR
                          jbat66 @sdetweil
                          UID:ccccccc
                          On your screen shot, you should have a "Local test wed weekly at… 13th Dec, 17:15 entry, but it is missing.
                            sdetweil @jbat66
                            @jbat66 yes, the rrule between is confused
                            search for recurring events between: Wed Dec 13 2023 12:41:01 GMT-0700 (Mountain Standard Time) and Wed Dec 11 2024 23:59:59 GMT-0700 (Mountain Standard Time)
                            [13.12.2023 12:41.01.677] [DEBUG] Title: Local test wed weekly at 5:15pm, with
                            dates: ["2023-12-20T00:15:00.000Z","2023-12-27T00:15:00.000Z","2024-01-
                            2023-12-20T00:15:00.000Z this is 2023-12-19T17:15:00
                            but he clipped of
                            2023-12-14T00:15:00.000Z, which would have been 2023-12-13T17:15:00
                            when the start was
                            Wed Dec 13 2023 12:41:01 but he was looking at 2023-12-13T00:15:00, which has passed… got the time rollover on TZ change wrong…
                            not in our code… will followup w the rrule owners
                              jbat66 @sdetweil
                              Thank you so much.
                                sdetweil @jbat66
                                @jbat66 I opened this issue, with a sample testcase
                                returned date incorrect caused by TZ rollover #610
