    Need help building two modules that communicate with each other
    9 Posts 2 Posters 1.1k Views 2 Watching
      sdetweil @DarkwingBuilds
      @DarkwingBuilds said in Need help building two modules that communicate with each other:
      sendCheckedItems
      change this function to use this sendNotification
      this will broadcast this message to all the other modules
      they would listen w this.notificationReceived(topic , data, sender)
      (so you could check if the sending module is yours too)
      and in the list module change this
      socketNotificationReceived
      to
        DarkwingBuilds @sdetweil
        @sdetweil after modifying the send/receive notifications, and checking the console logs, I verified that the Database is sending the correct information and the List is receiving the correct information. Which is much closer than I was before so Thank you! However, it doesn’t look like the List is doing anything with the information. The List module is only displaying a header and nothing else. Updated code is below.
        MMM-MealList.js
        Module.register("MMM-MealList", {
          defaults: {
            checkedItems: [],
            updateInterval: 5000, // Update every 5 seconds (adjust as needed)
          getStyles: function () {
            return ["MMM-MealList.css"];
          start: function () {
            console.log("MMM-MealList module started");
            this.loaded = false;
            this.sendNotification("MMM-MEALLIST-INIT");
            this.scheduleUpdate();
          notificationReceived: function (notification, payload) {
            console.log("Received notification:", notification);
            if (notification === "MMM-MEALDATABASE-CHECKED_ITEMS") {
              this.config.checkedItems = payload;
              this.updateDom();
          getDom: function () {
            wrapper.className = "MMM-MealList";
            var header = document.createElement("div");
            header.className = "list-header";
            header.appendChild(document.createTextNode("Checked Items"));
            wrapper.appendChild(header);
            var list = document.createElement("ul");
            list.className = "checked-list";
            this.config.checkedItems.forEach((item) => {
              var listItem = document.createElement("li");
              listItem.appendChild(document.createTextNode(item));
              list.appendChild(listItem);
            wrapper.appendChild(list);
            return wrapper;
          scheduleUpdate: function () {
            var self = this;
            setInterval(function () {
              console.log("MMM-MealList update requested");
              self.sendNotification("MMM-MEALLIST-UPDATE_REQUEST");
            }, this.config.updateInterval);
          @DarkwingBuilds always fun!!.
          now that you are working in the browser side, you can use the developers window debugger and step thru the code
          ctrl-shift-i on the browser keyboard (you can use the PC browser if u enable mm config.js for outside system access)
          select to sources tab
          in the left nav, navigate to modules, your modules, select on the source file name
          I cropped this just to show you where the debugger tools are and where you would click to add a stop
          right pointing debugger tool arrow is run to next stop (if any)
          circle with arrow is step one instruction
          downward arrow is step into next routine, up arrow is step back out
          and if you use the elements tab, you can see the browser view of your content
            @DarkwingBuilds in database,m you are missing the function
            getCheckedState(meal) and
            updateCheckState(meal, checked)
            also, the ‘protocol’ for modules says you should wait til all the modules are loaded before sending them messages
            see https://docs.magicmirror.builders/development/notifications.html#system-notifications
            here is the updated database
            Module.register("MMM-MealDatabase", {
              defaults: {
                meals: {
                  chicken: ["Chicken Dish 1", "Chicken Dish 2"],
                  beef: ["Beef Dish 1", "Beef Dish 2"],
                  pork: ["Pork Dish 1", "Pork Dish 2"],
                iconMapping: {
                  "Chicken Dish 1": "fa fa-drumstick-bite",
                  "Chicken Dish 2": "fa fa-drumstick-bite",
                  "Beef Dish 1": "fa fa-cloud-meatball",
                  "Beef Dish 2": "fa fa-cloud-meatball",
                  "Pork Dish 1": "fa fa-bacon",
                  "Pork Dish 2": "fa fa-bacon",
                checkStates: {}, // Ensure that checkStates is initialized as an empty object
              loaded: false,
                return ["MMM-MealDatabase.css"];
                console.log("MMM-MealDatabase module started");
                //this.loadCheckStates(); // Load check states from local storage
                // Send a socket notification to notify other modules about the current checked items
              sendCheckedItems: function () {
                console.log("Sending checked items");
                const checkedItems = Object.keys(this.config.checkStates).filter(meal => this.config.checkStates[meal]);
                this.sendNotification("MMM-MEALDATABASE-CHECKED_ITEMS", checkedItems);
                if(this.loaded){
                  wrapper.className = "MMM-MealDatabase";
                  wrapper.appendChild(this.createColumn("Chicken", "chicken"));
                  wrapper.appendChild(this.createColumn("Beef", "beef"));
                  wrapper.appendChild(this.createColumn("Pork", "pork"));
                return wrapper;
              notificationReceived(code, payload){
                if(code ==="MMM-MEALLIST-UPDATE_REQUEST"){
                  this.sendCheckedItems()
                } else if( code ==="ALL_MODULES_STARTED"){
                //this.sendNotification("MMM-MEALDATABASE-INIT", this.config.meals);
                this.sendCheckedItems();
                this.loaded=true;
              createColumn: function (category, mealType) {
                var column = document.createElement("div");
                column.className = "category";
                header.className = "column-header";
                header.appendChild(document.createTextNode(category));
                column.appendChild(header);
                this.config.meals[mealType].forEach((meal) => {
                  var item = document.createElement("div");
                  item.className = "item";
                  var checkbox = document.createElement("input");
                  checkbox.type = "checkbox";
                  checkbox.id = meal; // Use a unique identifier for each checkbox
                  checkbox.className = "checkbox";
                  // Set the checked state based on the stored state
                  checkbox.checked = this.getCheckState(meal);
                  this.updateCheckState(meal, checkbox.checked);
                  var label = document.createElement("label");
                  label.appendChild(checkbox);
                  label.appendChild(document.createTextNode(meal));
                  item.appendChild(label);
                  // Add change event to update the checked state
                  checkbox.addEventListener("change", () => {
                  column.appendChild(item);
                return column;
              getCheckState(meal){
                let checked=false
                try {
                 checked = this.config.checkStates[meal].checked
                catch(err){}
                return checked
              updateCheckState(meal, checked){
                if(this.config.checkStates[meal] == undefined)
                  this.config.checkStates[meal]={}
                this.config.checkStates[meal].checked=checked
            still looking at list
              @DarkwingBuilds
              and here is list
                defaults: {
                  checkedItems: [],
                  updateInterval: 10000, // Update every 10 seconds (adjust as needed)
                    this.updateDom();
                  return wrapper;
                  var self = this;
                @DarkwingBuilds both showing (checked needs to be looked at)
