    Need help building two modules that communicate with each other
    9 Posts 2 Posters 1.1k Views 2 Watching
      sdetweil @DarkwingBuilds
      @DarkwingBuilds to get two modules to talk, use this.sendNotifcation() from one with a topic that only the other will know about, and have the second this.sendNotification() back with the data you need(the checked items)
      notice this is NOT sendSocketNotification, which sends down to node_helper
      your modules control the format of the payload, so you can send/receive anything
      the receiver uses the notificationReceived(topic, data) function
        DarkwingBuilds @sdetweil
        @sdetweil thank you for the quick reply. I’ll give that a shot and let you know if that fixes it.
          @DarkwingBuilds said in Need help building two modules that communicate with each other:
          sendCheckedItems
          change this function to use this sendNotification
          this will broadcast this message to all the other modules
          they would listen w this.notificationReceived(topic , data, sender)
          (so you could check if the sending module is yours too)
          and in the list module change this
          socketNotificationReceived
          to
            @sdetweil after modifying the send/receive notifications, and checking the console logs, I verified that the Database is sending the correct information and the List is receiving the correct information. Which is much closer than I was before so Thank you! However, it doesn’t look like the List is doing anything with the information. The List module is only displaying a header and nothing else. Updated code is below.
            MMM-MealList.js
            Module.register("MMM-MealList", {
              defaults: {
                checkedItems: [],
                updateInterval: 5000, // Update every 5 seconds (adjust as needed)
              getStyles: function () {
                return ["MMM-MealList.css"];
              start: function () {
                console.log("MMM-MealList module started");
                this.loaded = false;
                this.sendNotification("MMM-MEALLIST-INIT");
                this.scheduleUpdate();
              notificationReceived: function (notification, payload) {
                console.log("Received notification:", notification);
                if (notification === "MMM-MEALDATABASE-CHECKED_ITEMS") {
                  this.config.checkedItems = payload;
                  this.updateDom();
              getDom: function () {
                wrapper.className = "MMM-MealList";
                var header = document.createElement("div");
                header.className = "list-header";
                header.appendChild(document.createTextNode("Checked Items"));
                wrapper.appendChild(header);
                var list = document.createElement("ul");
                list.className = "checked-list";
                this.config.checkedItems.forEach((item) => {
                  var listItem = document.createElement("li");
                  listItem.appendChild(document.createTextNode(item));
                  list.appendChild(listItem);
                wrapper.appendChild(list);
                return wrapper;
              scheduleUpdate: function () {
                var self = this;
                setInterval(function () {
                  console.log("MMM-MealList update requested");
                  self.sendNotification("MMM-MEALLIST-UPDATE_REQUEST");
                }, this.config.updateInterval);
              @DarkwingBuilds always fun!!.
              now that you are working in the browser side, you can use the developers window debugger and step thru the code
              ctrl-shift-i on the browser keyboard (you can use the PC browser if u enable mm config.js for outside system access)
              select to sources tab
              in the left nav, navigate to modules, your modules, select on the source file name
              I cropped this just to show you where the debugger tools are and where you would click to add a stop
              right pointing debugger tool arrow is run to next stop (if any)
              circle with arrow is step one instruction
              downward arrow is step into next routine, up arrow is step back out
              and if you use the elements tab, you can see the browser view of your content
                @DarkwingBuilds in database,m you are missing the function
                getCheckedState(meal) and
                updateCheckState(meal, checked)
                also, the ‘protocol’ for modules says you should wait til all the modules are loaded before sending them messages
                see https://docs.magicmirror.builders/development/notifications.html#system-notifications
                here is the updated database
                Module.register("MMM-MealDatabase", {
                  defaults: {
                    meals: {
                      chicken: ["Chicken Dish 1", "Chicken Dish 2"],
                      beef: ["Beef Dish 1", "Beef Dish 2"],
                      pork: ["Pork Dish 1", "Pork Dish 2"],
                    iconMapping: {
                      "Chicken Dish 1": "fa fa-drumstick-bite",
                      "Chicken Dish 2": "fa fa-drumstick-bite",
                      "Beef Dish 1": "fa fa-cloud-meatball",
                      "Beef Dish 2": "fa fa-cloud-meatball",
                      "Pork Dish 1": "fa fa-bacon",
                      "Pork Dish 2": "fa fa-bacon",
                    checkStates: {}, // Ensure that checkStates is initialized as an empty object
                  loaded: false,
                    return ["MMM-MealDatabase.css"];
                    console.log("MMM-MealDatabase module started");
                    //this.loadCheckStates(); // Load check states from local storage
                    // Send a socket notification to notify other modules about the current checked items
                  sendCheckedItems: function () {
                    console.log("Sending checked items");
                    const checkedItems = Object.keys(this.config.checkStates).filter(meal => this.config.checkStates[meal]);
                    this.sendNotification("MMM-MEALDATABASE-CHECKED_ITEMS", checkedItems);
                    if(this.loaded){
                      wrapper.className = "MMM-MealDatabase";
                      wrapper.appendChild(this.createColumn("Chicken", "chicken"));
                      wrapper.appendChild(this.createColumn("Beef", "beef"));
                      wrapper.appendChild(this.createColumn("Pork", "pork"));
                    return wrapper;
                  notificationReceived(code, payload){
                    if(code ==="MMM-MEALLIST-UPDATE_REQUEST"){
                      this.sendCheckedItems()
                    } else if( code ==="ALL_MODULES_STARTED"){
                    //this.sendNotification("MMM-MEALDATABASE-INIT", this.config.meals);
                    this.sendCheckedItems();
                    this.loaded=true;
                  createColumn: function (category, mealType) {
                    var column = document.createElement("div");
                    column.className = "category";
                    header.className = "column-header";
                    header.appendChild(document.createTextNode(category));
                    column.appendChild(header);
                    this.config.meals[mealType].forEach((meal) => {
                      var item = document.createElement("div");
                      item.className = "item";
                      var checkbox = document.createElement("input");
                      checkbox.type = "checkbox";
                      checkbox.id = meal; // Use a unique identifier for each checkbox
                      checkbox.className = "checkbox";
                      // Set the checked state based on the stored state
                      checkbox.checked = this.getCheckState(meal);
                      this.updateCheckState(meal, checkbox.checked);
                      var label = document.createElement("label");
                      label.appendChild(checkbox);
                      label.appendChild(document.createTextNode(meal));
                      item.appendChild(label);
                      // Add change event to update the checked state
                      checkbox.addEventListener("change", () => {
                      column.appendChild(item);
                    return column;
                  getCheckState(meal){
                    let checked=false
                    try {
                     checked = this.config.checkStates[meal].checked
                    catch(err){}
                    return checked
                  updateCheckState(meal, checked){
                    if(this.config.checkStates[meal] == undefined)
                      this.config.checkStates[meal]={}
                    this.config.checkStates[meal].checked=checked
                still looking at list
                  @DarkwingBuilds
                  and here is list
                    defaults: {
                      checkedItems: [],
                      updateInterval: 10000, // Update every 10 seconds (adjust as needed)
                        this.updateDom();
                      return wrapper;
                      var self = this;
                    @DarkwingBuilds both showing (checked needs to be looked at)
