    Black screen with cursor issue.
    black screen
    12 Posts 2 Posters 4.5k Views 2 Watching
    • N Offline
      nx3xo @sdetweil
      System browser launches no problem.
      Disabled the blocker rues for pfblocker on my iot vlan so its a straight shot to internet.
      Whats the best way to dump logs? I am on pm2. Your auto install script.
        sdetweil @nx3xo
        @nx3xo the files are in the
        ~/.pm2/logs
        folder
        notice the dot (.) I’m front of pm2
        in Linux there is no hidden attribute so by convention anything with a leading dot I not shown by normal file list commands
        • N Offline
          nx3xo @sdetweil
          Hopefully this is enough to narrow it down.
          Out>
          [18.12.2023 19:51.10.942] [LOG] Starting MagicMirror: v2.25.0
          [18.12.2023 19:51.10.959] [LOG] Loading config …
          [18.12.2023 19:51.10.966] [DEBUG] config template file not exists, no envsubst
          [18.12.2023 19:51.10.982] [LOG] Loading module helpers …
          [18.12.2023 19:51.10.988] [LOG] No helper found for module: clock.
          [18.12.2023 19:51.10.992] [LOG] No helper found for module: weather.
          [18.12.2023 19:51.14.346] [LOG] Initializing new module helper …
          [18.12.2023 19:51.14.349] [LOG] Module helper loaded: MMM-MyCommute
          [18.12.2023 19:51.16.298] [LOG] Initializing new module helper …
          [18.12.2023 19:51.16.302] [LOG] Module helper loaded: MMM-Tesla
          [18.12.2023 19:51.19.071] [LOG] Module helper loaded: MMM-Nightscout
          [18.12.2023 19:51.19.072] [LOG] All module helpers loaded.
          [18.12.2023 19:51.19.094] [LOG] Starting server on port 8080 …
          [18.12.2023 19:51.19.204] [LOG] Server started …
          [18.12.2023 19:51.19.209] [LOG] Connecting socket for: MMM-MyCommute
          [18.12.2023 19:51.19.210] [LOG] ====================== Starting node_helper for module [MMM-MyCommute]
          [18.12.2023 19:51.19.211] [LOG] Connecting socket for: MMM-Tesla
          [18.12.2023 19:51.19.215] [LOG] Connecting socket for: MMM-Nightscout
          [18.12.2023 19:51.20.516] [LOG] 19:51:19 MMM-Nightscout: Starting helper: MMM-Nightscout
          [18.12.2023 19:51.20.520] [LOG] Sockets connected & modules started …
          [18.12.2023 19:51.24.269] [LOG] Launching application.
          Error>
          …/…/buildtools/third_party/libc++/trunk/include/vector:1473: assertion __n < size() failed: vector[] index out of bounds[1874:1217/085550.258949:ERROR:gpu_process_host.cc(957)] GPU process exited unexpected>
          [1919:1217/085552.538276:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
          /home/magicmirror/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
          [1305:1217/143752.436510:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The n>
          [2710:1218/061416.667391:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The n>
          [7631:1218/180141.222415:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The n>
          [1302:1218/182932.524821:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The n>
          [1560:1218/184240.402360:ERROR:connection.cc(46)] X connection error received.
          [1560:1218/184240.402357:ERROR:connection.cc(46)] X connection error received.
          [1302:1218/184240.770157:FATAL:bus.cc(1226)] D-Bus connection was disconnected. Aborting.
          /home/magicmirror/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP
          [1298:1218/184436.702381:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The n>
          [1382:1218/191642.613559:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The n>
          [1943:1218/195126.584825:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The n>
            sdetweil @nx3xo
            @nx3xo in the script that does npm start
            add
            export ELECTRON_DISABLE_GPU=1
            before the npm start line
            with my install script, that is
            ~/MagicMirror/installers/mm.sh
            N 2 Replies Last reply Reply Quote 0
            • N Offline
              nx3xo @sdetweil
              So one of my installs is mm.sh and the other is run-start.sh.
              The mm.sh one only shows this error in start.
              [2883:1218/201556.298300:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
              I think this has been covered and is insignificant, correct?
              The run-start.sh one I’m going to reinstall.
              Not sure how I ended up with 2 different installs, pretty I used your script.
              So heres a question for ease of troubleshooting.
              What if I do a couple dedicated proxmox lxc for servers and run the raspi displays as clients? I haven’t tried this method yet.
              • N Offline
                nx3xo @sdetweil
                Made change. No dice on my original MM device 4x4 pixelsquare. Black screen plus cursor. Startup out looks clean.
                  sdetweil @nx3xo
                  @nx3xo run-start is done when I cannot find electron or it’s armv6l
                  then I just launch chromium over the mm server
                  • N Offline
                    nx3xo @sdetweil
                    I would like to sort this self hosted mm instance. It runs perfect in the web browser. Just blank screen with cursor. Is it possible a module can prevent everything from launching if it is too large and overlaps others?
                      sdetweil @nx3xo
                      @nx3xo how about the browser on the host looking at http://localhost:mm_port
