    Default Weather Module (Weathergov) stuck on loading
    7 Posts 2 Posters 1.4k Views 3 Watching
      angeliKITTYx
      I’ve tried looking at other forum posts and I can’t seem to get mine working.
      The city shows, but both my current and forecast are stuck at “Loading …”
      I even tried to add a 2m refresh interval, but that didn’t change anything.
      I also tried “forecast” instead of “daily”
      Here’s my code
      			module: "weather",
      				weatherProvider: "weathergov",
      				type: "daily",
       				apiBase: 'https://api.weather.gov/points/',
      				lat: "3xxxxx",
      				lon: "-7xxxxx",
      				showPrecipitationProbability: "true"
      			module: "weather",
      				type: "current",
      				lat: "3xxxxx",
      				lon: "-7xxxxx"
      • karsten13K Online
        karsten13 @angeliKITTYx
        @angeliKITTYx
        numeric and boolean values must be provided without " around them
          angeliKITTYx @karsten13
          @karsten13 is that just my lat/lon and the precipitation probability?
          • karsten13K Online
            @angeliKITTYx
            I think so
              @karsten13 I actually just found all of the errors… and I don’t really know what they mean
              2weathergov.js:133 Forecast location is Portsmouth, VA
              localhost/:1 Access to fetch at 'https://api.weather.gov/gridpoints/AKQ/88,50/stations' from origin 'http://localhost:8080' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.
              api.weather.gov/gridpoints/AKQ/88,50/stations:1
                     Failed to load resource: net::ERR_FAILED
              weathergov.js:149 TypeError: Failed to fetch
                  at performWebRequest (utils.js:19:25)
                  at Class.fetchData (weatherprovider.js:129:10)
                  at weathergov.js:139:17
              (anonymous) @ weathergov.js:149
              :8080/tbd:1
                     Failed to load resource: the server responded with a status of 404 (Not Found)
              weathergov.js:72 Could not load station obs data ...  SyntaxError: Unexpected token '<', "<!DOCTYPE "... is not valid JSON
                  at JSON.parse (<anonymous>)
                  at performWebRequest (utils.js:27:29)
              (anonymous) @ weathergov.js:72
              weather.js:166 New weather information available.
              :8080/tbd:1
              localhost/:1 Refused to apply style from 'http://localhost:8080/css/custom.css' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled.
              • karsten13K Online
                @angeliKITTYx said in Default Weather Module (Weathergov) stuck on loading:
                if I use the above url in the browser I get
                so you can wait or use another weather provider …
                A 1 Reply Last reply Reply Quote 1
                  @karsten13 oh! i didn’t know you could look at the URLs like that. Thanks!
