    MMM-CalDAV
    97 Posts 10 Posters 51.7k Views 9 Watching
    • G Offline
      GregoryWest @sdetweil
      @sdetweil really confused now. you need the /CALDAV/ folder removed. leathe the config.js as it is?
        sdetweil @GregoryWest
        @gregorywest yes, the module creates a server at /CALDAV, and when the calendar module uses that URL, this module returns an ICS file. live… (same as if you had been using a google calendar)
        this is different than the other converters that dump a file in a folder.
        • G Offline
          @sdetweil WOW its working!!! Thanks for your patience. Looking good. Something just occured to me. Can I do this with multiple users/calendars? The plan is for 5 calendars to be on the screen, they are all coming from the same SoGo server.
            @gregorywest that I do not know
            • G Offline
              @sdetweil I noticed a different issue now. I was updating my calendar in SoGo, but none of the updates are showing up on MMM. This is even the case after a reboot of MMM.
              The problem of the multiple calendars might be a show stopper. Will keep muddling through this.
              Greg
                @gregorywest ok, for multiple cals, u use another instance of the module in config.js
                his doc shows that…
                update? should be the updateInterval parm… default 15 mins it says
                  MMRIZE @GregoryWest
                  Thanks your kind help. I was absent for days. So I couldn’t support this issue.
                  @GregoryWest
                  When you want to get several calendars(or accounts), just add this module again in your config.
                  And to refresh calendar, wait updateInterval.
                  And with rebooting, usually last result will be shown after reboot.(CalDAV parsing is quite slow ). Generally it will take updateInterval after reboot, the change will be displayed.
                    MMRIZE @GregoryWest
                    @gregorywest said in MMM-CalDAV:
                    What you want is;
                    • 5 CalDAV calendars from one account (It has more than 5 calendars) as one iCal Calendar : Just use calendarFilter
                    • 5 CalDAV calendaras from one account as 5 iCal Calendars: Use this module 5 times with calendarFilter
                    • 5 CalDAV calendars from several accounts as one summarized iCal Calendar : Sorry, impossible with this module.
                    • 5 CalDav calendars from several accounts as 5 iCal Calendars : Use method 2.
                      MMRIZE
                      UPDATE 2.0.0
                      • Newly rebuilt from scratch
                      • OAUTH supported (For Google Calendar)
                      • Multi servers/calendars in one module.
                      • more secure and efficiently
                      Now, you can use Google Calendar in the default calendar module(and more).
                      https://github.com/MMRIZE/MMM-CalDAV
                        MMRIZE @Guest
                        @matt216
                        More details about your environment are needed to know what happens.
                        Let’s start with the concept.
                        Some CALDAV Providers don’t serve any public iCAL(.ics) URL to be consumed externally. You don’t need this module if your CALDAV service can host iCAL URLs. I have no idea about baikal, but I think you know whether that service would provide iCAL or not.
                        MMM-CALDAV can access the CALDAV server(which would not host any public iCAL URL) to get target calendar events. Then, this module converts the event data to a real iCAL file(.ics). And this module also hosts that file as a URL accessible from the default calendar module or some iCAL consuming modules with security. MMM-CALDAV will work like a private iCAL provider service.
                        So, to show your event on MM, you may need both MMM-CALDAV and calendar module together.
                        .env file is needed to connect/authenticate CALDAV server and some security features. Calendar events are very private so I want to block the security hole on working this module. You should put .env in MMM-CALDAV directory.
                        So, where are you stuck now? Tell me what happens.
                          matt216 @MMRIZE
                          @MMRIZE Thank you for your help, but I managed to figure out getting baikal to generate the ics file, so I don’t need this module anymore.
                          Thanks anyway
                            MMRIZE
                            Update 2.1.0
                            • Birthday calendar enabled. (CardDAV implementation)
                            • Some code refactoring.
                            • calendars: [], is changed to targets: []. you have to reconfigure your config.js
                            Now you can get Birthdays calendar from iCloud or Google Contacts. (Of course, other CardDAV supported contacts services.)
                            • T Offline
                              Tiller @MMRIZE
                              @MMRIZE
                              Hello I’m trying to sync my synology calendar to the MagicMirror calendar with the MMM_CalDAV module. Sadly it’s not working and I don’t know why. I tried different settings and everything I could find online.
                              My config.js (without the standard stuff) looks like this:
                                module: "MMM-CalDAV",
                                  timeRangeStart: -30,
                                  servers: [
                                      envPrefix: "SYOLOGY_",
                                      serverUrl: "http://192.168.xxx/caldav/",
                                      targets: ["family" ],
                                  servers: [
                                      symbol: "calendar-check",
                                      url: "http://localhost:8080/CALDAV/SYNOLOGY_family.ics",
                                      auth: {
                                        user: 'username1',
                                        pass: 'password1',
                                        method: 'basic'
                              The .env looks like this:
                              CALDAV_SERVICE_USERNAME=
                              ### For SYNOLOGY
                              SYNOLOGY_username=username1
                              SYNOLOGY_password=password1
                              Do you have any idea what I could try to do, to sync it?
                              Thank you
                              Tillmann
                                sdetweil @Tiller
                                @Tiller can you show any of the output from
                                npm start
                                if using pm2 to autolaunch, then
                                pm2 logs --lines=xxxx
                                xxxx is the number of the most recent lines in the logs, default 15
                                note that the log data will have full urls for calendar , so this could expose info
                                  MMRIZE @Tiller
                                  @Tiller said in MMM-CalDAV:
                                  For SYNOLOGY
                                  I think you may have confusing the username and password for the server and the module.
                                  This is for your Synology Caldav Server, usually it is your account id/password to login Synology Server (Or Synology calendar account)
                                  CALDAV_SERVICE_USERNAME=username2
                                  CALDAV_SERVICE_PASSWORD=password2
                                  This is a different thing. It is used for your MM calendar module. This module provide a secure calendar ics host by itself with this auth information. You should need to set your calendar config like this;
                                  // default calendar module.
                                          url: "http://localhost:8080/CALDAV/SYNOLOGY_Family.ics",
                                          auth: { // REQUIRED
                                            user: 'username2', // <= used here (CALDAV_SERVICE_USERNAME)
                                            pass: 'password2', // <= used here (CALDAV_SERVICE_PASSWORD)
                                            method: 'basic'
                                  • T Offline
                                    Tiller @MMRIZE
                                    Thank you for your quick reply.
                                    @sdetweil I’m not using pm2 at the moment, but I could try to do it and check the logs.
                                    @MMRIZE sorry, my bad. I changed the password for the post, it’s correct in my .env but not working.
                                    I’m not exactly sure about the Synology url
                                    synology.com says I should use
                                    http://192.168.x.x:5000/caldav
                                    and than log in with my username and password
                                    But an older link is (seems there was an update)
                                    http://192.168.x.x:5000/caldav/username/ejialfjl/
                                    If I’m using the last one in the browser, it is downloading an .ics file.
                                    But it’s not working with both urls.
                                    Maybe I should try to reinstall everything?
                                    S M 3 Replies Last reply Reply Quote 0
                                      sdetweil @Tiller
                                      @Tiller if you are not using pm2 then the errors would be shown where you do npm start
                                        sdetweil @Tiller
                                        @Tiller no reinstall
                                        can you show us the new url(#2) in config.js,
                                        assume you are still using the env variables
                                          MMRIZE @Tiller
                                          @Tiller
                                          CalDAV is different to general ics hosting.
                                          Usually, the URL of Synology CalDAV accessing would be;
                                          https://IP_OR_URL:5001/caldav/
                                          http://IP_OR_URL:5000/caldav/
                                          Anyway, there would be some log to diagnosis. Can you show the frontend and backend logs?
                                          C T 2 Replies Last reply Reply Quote 0
                                            caw @MMRIZE
                                            @MMRIZE
                                            i´ve got the same problem. I´m completly new to magicmirror but the integration of my Synology CalDAV should be the main part of it.
                                            i´ve tried several combinations and addresses but no one worked for me.
                                            maybe its possible to get a “step - by - step” Tutorial.
                                            hopefully you can help :)
                                            • 1 / 5
