    MMM-Todoist
    9 Posts 2 Posters 1.6k Views 2 Watching
      Syosse @sdetweil
      @sdetweil Thanks for the replay
      i have run the command: npm run config:check
      > magicmirror@2.25.0 config:check
      > node js/check_config.js
      [05.01.2024 14:11.43.042] [INFO] Checking file... /home/Admin/MagicMirror/conf ig/config.js
      [05.01.2024 14:11.43.116] [INFO] Your configuration file doesn't contain syntax errors :)
        sdetweil @Syosse
        @Syosse ok, that means its not a syntax error
        show me the output of npm start
        if you use pm2 to auto start, do this
        pm2 stop all
        npm start
        when done with tests
        pm2 status
        and use the number of the line(usually 0)
        pm2 start 0
          Syosse @sdetweil
          @sdetweil said in MMM-Todoist:
          pm2 stop all
          npm start
          pm2 status
          pm2 start 0
          Thanks for the Reply:
          i have run this command:
          pm2 stop all
          npm start
          > magicmirror@2.25.0 start
          [05.01.2024 14:32.28.026] [LOG]   Starting MagicMirror: v2.25.0
          [05.01.2024 14:32.28.032] [LOG]   Loading config ...
          [05.01.2024 14:32.28.035] [DEBUG] config template file not exists, no envsubst
          [05.01.2024 14:32.28.039] [LOG]   Loading module helpers ...
          [05.01.2024 14:32.28.040] [LOG]   No helper found for module: MMM-SimpleLogo.
          [05.01.2024 14:32.28.041] [LOG]   No helper found for module: compliments.
          [05.01.2024 14:32.28.042] [LOG]   No helper found for module: MMM-Globe.
          [05.01.2024 14:32.28.043] [LOG]   No helper found for module: clock.
          [05.01.2024 14:32.28.049] [ERROR] (node:2061) UnhandledPromiseRejectionWarning: Error: Cannot find module 'request'
          Require stack:
          - /home/Admin/MagicMirror/modules/MMM-Todoist/node_helper.js
          - /home/Admin/MagicMirror/js/app.js
          - /home/Admin/MagicMirror/js/electron.js
          - /home/Admin/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
              at node:internal/modules/cjs/loader:1084:15
              at Function.<anonymous> (node:electron/js2c/browser_init:2:117576)
              at Module._resolveFilename (/home/Admin/MagicMirror/node_modules/module-alias/index.js:49:29)
              at node:internal/modules/cjs/loader:929:27
              at Function._load (node:electron/js2c/asar_bundle:2:13327)
              at Module.require (node:internal/modules/cjs/loader:1150:19)
              at require (node:internal/modules/cjs/helpers:110:18)
              at Object.<anonymous> (/home/Admin/MagicMirror/modules/MMM-Todoist/node_helper.js:12:17)
              at Module._compile (node:internal/modules/cjs/loader:1271:14)
              at Object..js (node:internal/modules/cjs/loader:1326:10)
              at Module.load (node:internal/modules/cjs/loader:1126:32)
              at node:internal/modules/cjs/loader:967:12
              at loadModule (/home/Admin/MagicMirror/js/app.js:180:19)
          (Use `electron --trace-warnings ...` to show where the warning was created)
          [05.01.2024 14:32.28.051] [ERROR] (node:2061) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          [2093:0105/143229.076293:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2093:0105/143229.076702:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2093:0105/143229.077074:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2093:0105/143229.077350:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2093:0105/143229.077710:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2093:0105/143229.078018:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2093:0105/143229.078314:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2093:0105/143229.080174:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2093:0105/143229.080490:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2093:0105/143229.080861:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2093:0105/143229.081179:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2093:0105/143229.081474:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2093:0105/143229.081781:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2093:0105/143229.082085:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
          Then this command: pm2 status and finally this command: pm2 start 0
            sdetweil @Syosse
            @Syosse said in MMM-Todoist:
            [05.01.2024 14:32.28.049] [ERROR] (node:2061) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
            Require stack:
            • /home/Admin/MagicMirror/modules/MMM-Todoist/node_helper.js
            yep, missing library…
            do this…
            cd ~/MagicMirror/modules/MMM-Todoist
            npm install request
            note that there are 6 - 8 missing libraries. as we clean up MM from using old dead stuff to newer supported code, some of the older modules didn’t know they were using libs from our packaging… which are no longer there…
              Syosse @sdetweil
              do this…
              npm install request
              Perfect it works!! Thanks man
              Last thing how can i hidde the Projectname ?
              I have added showProject: false
              		module: 'MMM-Todoist',
              		position: 'bottom_right',	// This can be any of the regions. Best results in left or right regions.
              		header: 'Todoist', // This is optional
              		config: { // See 'Configuration options' for more information.
              			hideWhenEmpty: false,
              			accessToken: '5b1608a7747cccccc0162a553e',
              			maximumEntries: 60,
              			updateInterval: 10*60*1000, // Update every 10 minutes
              			fade: false,
              			showProject: false,
              			// projects and/or labels is mandatory:
              			projects: [2326180937],
                sdetweil @Syosse
                @Syosse I do not know…
                the code only displays the project name when showProject is set to true (the default)
