    Calendar Module not working with Google Calendar
    22 Posts 6 Posters 18.7k Views 8 Watching
      sdetweil @AnduriI
      @AnduriI bizarre.
      can u turn on debug in config.js
      add
      ,"DEBUG"
      to the loglevel: list
      then let’s use non pm2 to capture the info
      pm2 stop all
      npm start >somefile.txt 2>&1
      wait til u think the error occurs
      ctrl-q
      to top mm
      then look at the somefile.txt
      search for the isostring
      you should see dates=
      for each event
      the problem was the rule.between function which calculates the repeating events would return junk
      I put in a filter to remove the junk.
      anyhow, then remove the DEBUG
      thing from config.js
      and you can use pm2 to restart mm til we figure it out
      if u can, send the somefile.txt to me via email
      my userid here at gmail
      A R 2 Replies Last reply
      • A
        AnduriI @sdetweil
        @sdetweil wow I was not aware of all old events also being sent and parsed… from 5+ years ago. That’s a lot of entries… (more than 1500 only for my main calendar)
        I sent the log via eMail to you.
        S 2 Replies Last reply
          sdetweil @AnduriI
          @AnduriI yes, the ics holds all that junk
            sdetweil @AnduriI
            @AnduriI are u willing to share one of the trouble cal urls so I can debug?
            send in a private chat. not via mail. after use I will delete the data and the chat.
              @AnduriI also try this
              npm install electron@28.1.1
                redink @sdetweil
                @sdetweil, would you mind sharing how you set up a filter for the events? I have a suspicion that too many events are causing some items to now show up on calendar.
                  sdetweil @redink
                  @redink there are no backend (at the ICS parser) filters
                  on the front end (browser display) there are the following config options that affect event display
                  maximumEntries,
                  maximumNumberOfDays,
                  hidePrivate,
                  hideOngoing and
                  hideDuplicates
                  the default calendar module NEVER displays events before today. but it will broadcast them for other modules to use ( MMM-CalendarExt3* uses them)
                  sadly the parser does NOT indicate where today is in the stream of events parsed (the ICS has EVERYTHING in it). the only way to fix this is to make a breaking change, and send two lists, old and future
                  because of the single list , maximumEntries , CAN/DOES cause the event list to get clipped before any current events can be processed.
                  R 1 Reply Last reply
                    redink @sdetweil
                    @sdetweil ok, that makes sense.
                    My issue is really strange where my two recurring weekly events only show up during the first two weeks of the month, and are ignored the rest of the time until the next month. I even tested installed thunderbird to open the ICS file to check that the issue isn’t with google calendar. Thunderbird displays the recurring events just fine.
                    It’s making me think if I should hack together some kind a pre-processor to only return events that are relevant to the view.
                      sdetweil @redink
                      @redink yes, new rrule is having trouble…
                      lets go back to the prior parser
                      cd  ~/MagicMirror
                      npm install node-ical@0.16.1
                      R F 2 Replies Last reply
                        redink @sdetweil
                        @sdetweil That did it. Thank you so much. I spent two hours this morning trying to fix this.
                        How did you know that this was an issue? I need to get better at learning how to troubleshoot this mirror myself.
                          sdetweil @redink
                          @redink we’ve been working it for the last couple weeks. this was a major change for calendar this release. I pushed it cause of all the other recurring events time problems.
                          I do most of the calendar module parsing support
                            redink @sdetweil
                            @sdetweil really appreciate your support on this!
                              jer9189 @AnduriI
                              @AnduriI, I had a similar issue I spent a few hours troubleshooting. MMM-Calendar (connected to private Google calendar ics link), MMM-Wallpaper, and MMM-quote-of-the-day all were black or showing errors. It started with a clean install of Raspberry Pi and MagicMirror 2.26.0 (installed via sdetweil raspberry.sh script) in early January 2024. Installing electron@28.1.1 and node-ical@0.16.1 did not fix the issue.
                              What fixed this issue for me was disabling IPv6 in the Raspberry Pi by adding 3 lines to the sysctl.conf file. Now all three of these modules work correctly.
                              sudo nano /etc/sysctl.conf
                              Add these three lines:
                              net.ipv6.conf.all.disable_ipv6 = 1
                              net.ipv6.conf.default.disable_ipv6 = 1
                              net.ipv6.conf.lo.disable_ipv6 = 1
                              Save (Ctrl + x, y) and reboot sudo reboot to apply setting.
                                sdetweil @jer9189
                                @jer9189 great feedback, thank you!!!
                                I pinned a new (locked) post with a link to your post in the troubleshooting section
                                • F
                                  Fuen @sdetweil
                                  @sdetweil yeap thx that does it to on my side!
                                  Regards,
                                  • T theaddies referenced this topic on
