Calendar Module not working with Google Calendar
22 Posts 6 Posters 12.1k Views 8 Watching
    jott0204
    Re: Default Modules
    Hello. I recently updated to the latest MagicMirror build and my Google Calendar (in ical format) stopped loading. I tried to reset the Private ical link. I also tried the public ical link, but it still will not load. Anyone have any suggestions? I can load the config.js file (redacted) if that will help
    S 1 Reply Last reply Jan 1, 2024, 10:26 PM Reply Quote 0
      sdetweil @redink
      @redink yes, new rrule is having trouble…
      lets go back to the prior parser
      cd  ~/MagicMirror
      npm install node-ical@0.16.1
      R F 2 Replies Last reply Jan 14, 2024, 5:29 PM Reply Quote 0
        sdetweil @jott0204
        @jott0204 yes config, url xxx out
        also please show the messages where you do npm start
          AnduriI
          I have a very similiar problem. I use two calendar modules, one with dates from the local waste pickup service and another one with multiple google calendars. The waste calendar works fine (so nothing with the module), but google gives errors. I copied out two of the google-calendars:
          [03.01.2024 11:05.10.477] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/XXXXX/basic.ics RangeError: Invalid time value
              at Date.toISOString (<anonymous>)
              at /home/pi/MagicMirror/modules/MMM-MyCalendar/calendarutils.js:314:28
              at Array.forEach (<anonymous>)
              at Object.filterEvents (/home/pi/MagicMirror/modules/MMM-MyCalendar/calendarutils.js:142:24)
              at /home/pi/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js:74:29
              at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
          [03.01.2024 11:05.11.076] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/XXXXX/basic.ics RangeError: Invalid time value
          I don’t know what invalid time value means, maybe someone can help
          S J 2 Replies Last reply Jan 3, 2024, 12:57 PM Reply Quote 0
            sdetweil @AnduriI
            @AnduriI you need the latest mm version which has a fix for the isostring problem
            A 1 Reply Last reply Jan 3, 2024, 7:51 PM Reply Quote 1
              AnduriI @sdetweil
              @sdetweil what do you mean with latest mm version? I did git pull && npm install, so I should have the latest…
              S 1 Reply Last reply Jan 3, 2024, 8:49 PM Reply Quote 0
                sdetweil @AnduriI
                @AnduriI can u chedck the actual version u have
                grep version package.json
                A 1 Reply Last reply Jan 4, 2024, 8:40 AM Reply Quote 0
                  AnduriI @sdetweil
                  /MagicMirror $ grep version package.json
                          "version": "2.26.0",
                  S 1 Reply Last reply Jan 4, 2024, 1:14 PM Reply Quote 0
                    sdetweil @AnduriI
                    @AnduriI bizarre.
                    can u turn on debug in config.js
                    add
                    ,"DEBUG"
                    to the loglevel: list
                    then let’s use non pm2 to capture the info
                    pm2 stop all
                    npm start >somefile.txt 2>&1
                    wait til u think the error occurs
                    ctrl-q
                    to top mm
                    then look at the somefile.txt
                    search for the isostring
                    you should see dates=
                    for each event
                    the problem was the rule.between function which calculates the repeating events would return junk
                    I put in a filter to remove the junk.
                    anyhow, then remove the DEBUG
                    thing from config.js
                    and you can use pm2 to restart mm til we figure it out
                    if u can, send the somefile.txt to me via email
                    my userid here at gmail
                    A R 2 Replies Last reply Jan 4, 2024, 8:42 PM Reply Quote 0
                      AnduriI @sdetweil
                      @sdetweil wow I was not aware of all old events also being sent and parsed… from 5+ years ago. That’s a lot of entries… (more than 1500 only for my main calendar)
                      I sent the log via eMail to you.
                      S 2 Replies Last reply Jan 4, 2024, 9:09 PM Reply Quote 1
                        sdetweil @AnduriI
                        @AnduriI yes, the ics holds all that junk
