    How difficult would it be to change the data an existing module receives?
    13 Posts 2 Posters 4.6k Views 2 Watching
      sdetweil @Tippon
      @Tippon you can clone (fork) the module and add on what you want…
      there are two parts of the module… the browser/ui part MMM-Fitbit2.js
      and the helper, node_helper.js
      the MMM-Fitbit2.js cannot access hardware or files directly, so it has to call the helper
      so, you could add on access to the spreadsheet (csv)
      and send that data back as part of the response… the front end would never know
      one of my modules uses a csv
      in the node_helper
      (you have to npm install csvtojson in the module folder to be able to use it)
      const cvt = require("csvtojson");
      and then
                                     cvt().fromFile(payload.tmpfile) // input xls  // changed to tmpfile
           				.subscribe((jsonObj, index) => {
                                             // handle each row
      TipponT 2 Replies Last reply
      Reply Quote 2
      • TipponT
        Tippon @sdetweil
        @sdetweil said in How difficult would it be to change the data an existing module receives?:
        Sorry, I should have clarified - I know that I can fork the module, but I don’t have the skills or knowledge to keep up with any changes that might be made to the original. If there was a security update, for example, I wouldn’t know how to integrate that into my fork. Considering the dates of the last changes though, that might not be an issue in this case.
        in the node_helper
        and then
                                               // handle each row
        So, ignoring any possible updates for now, I could edit the node_helper.js and basically trick the rest of the module into using my chosen data instead? That sounds great, thanks :)
        I’ve found some apps that share data between Fitbit and Google Fit, so depending on how well they all work together, this might be a bit easier than I thought.
        I’ve just discovered a problem with the Fitbit data though. Until recently, MMM-Fitbit2 would pull a lot of my data and display it on my mirror. Today though it’s not displaying my calories in figure. Google has taken over Fitbit, and recently forced a change of login, from Fitbit’s old system to a Google login. I’m not sure if this problem started at the same time, or if there’s been a change in the API. I’m pottering around trying to figure it out, but it might take me a while to figure out what I’m doing, never mind what Fitbit / Google are doing >.<
        Thanks as always for your help :)
        Please forgive me if I’m slow to reply, I’m currently experiencing memory issues, and sometimes forget that I’ve asked a question >.<
          sdetweil @Tippon
          @Tippon you don’t have to contribute back, or take any other changes…
          so don’t worry about those
          yes changes keep rolling along, non stop
          TipponT 1 Reply Last reply
          • TipponT
            Tippon @sdetweil
            I found a post by @greenza21 on Reddit that suggested Health Sync for Android
            https://play.google.com/store/apps/details?id=nl.appyhapps.healthsync
            I’ve tested Health Sync over the last few days, and it’s successfully transferred my Steps, Activities, Sleep, and Weight data from Google Fit in to Fitbit. It can also transfer Nutrition and Water Intake directly, but I already input those directly into Fitbit. It can export some other data too, but Fitbit doesn’t accept those inputs.
            I’ve got everything I want other than my blood sugar / glucose readings showing up in the MMM-Fitbit2 module just from using Health Sync, so when I get a bit more time over the next few days, I’m going to try to replace the floors entry with my blood glucose data, then maybe look at exporting my heart rate or oxygen levels from my smartwatch, depending on whether they can be pulled from the watch app. Not everything gets pulled to Google Fit, so they may be a dead end.
              sdetweil @Tippon
              @Tippon so, summary
              you use the app to push data to fitbit,
              where the existing Fitbit2 module can get the data from the existing fitbit api…
              • TipponT
                Tippon @sdetweil
                @sdetweil That’s right, yes :)
                It’s ideal for me, and I have suspected ADHD, and don’t always remember to do things. I can just put the shortcut to this app next to my other health apps, and it acts as a reminder.
                I’ve decided to remove one of the MMM-fitbit2 default categories and replace it with a modified copy of the calorie goal category instead. The default shows the calories remaining until your calorie goal, but I also want to see how many calories I’ve consumed. I just had a quick play and it seems easy enough, but I need to make sure that it doesn’t break the existing categories too.
                Time for a break though, my kid’s about to get home from school, so any chance of peace and quiet is gone for the next few hours :D
                • TipponT
                  Tippon
                  Just to double check before I break anything, if I forked the repo and replaced the installed version of MMM-Fitbit2 with my own, would I need to change anything in my config.js? I’m assuming that if I kept the same repo name it would just work, but I want to make sure.
                    sdetweil @Tippon
                    @Tippon no changes to config unless you added something
                    • TipponT
                      Tippon @sdetweil
                      @sdetweil Brilliant, thank you :)
                      • TipponT
                        Tippon @sdetweil
                        and then
                                                               // handle each row
                        Sorry, I forgot to ask, where does this go? Does it go into the node_helper.js with the other line?
                          sdetweil @Tippon
                          @Tippon it goes in the node_helper.
                          this is one way to process the csv file
                          • TipponT
                            Tippon @sdetweil
                            @sdetweil Thank you :)
