    Calendar not updating
    95 Posts 4 Posters 88.6k Views 6 Watching
      matt216 @sdetweil
      @sdetweil Hi Sam.
      The before filter section is not showing the events that are missing. So not sent from the parser…?
      The events to process section reflects what is seen in the before filter section.
      Over the weekend the calendar looked good, but come Monday morning lots of events are missing. The mirror is currently showing events 10 days in the future even though there are plenty of events before then.
      I have had a play with module config maximumEntries and limitDays to see if anything improves, but with no luck.
      Thanks again,
      Matt
        sdetweil @matt216
        @matt216 ok, go back to the prior parser
        npm install node-ical@0.16.1
        restart MM
          matt216 @sdetweil
          @sdetweil said in Calendar not updating:
          node-ical@0.16.1
          Done. Different events shown on the mirror - events over the next few days rather than 10 days away! - but still events not displaying.
          Browser dev tools indicate they’re sitll not getting parsed.
          Server pm2 logs do show the events are being picked up from the calendar server e.g.
          0|MagicMirror  | {"type":"VEVENT","params":[],"created":"2024-01-16T10:33:48.000Z","end":"2024-01-19T15:00:00.000Z","dtstamp":"2024-01-16T10:33:49.000Z","start":"2024-01-19T14:00:00.000Z","datetype":"date-time","lastmodified":"2024-01-16T10:33:48.000Z","sequence":"0","summary":"Alex bike","transparency":"OPAQUE","uid":"66D38BB9-70EA-486B-A297-58C2E0F3642C","url":{"params":{"VALUE":"URI"},"val":""},"APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000"}
          is not showing on the display and is not showing in browser devtools.
            sdetweil @matt216
            @matt216 can u show the rest of the debug on that event?
              matt216 @sdetweil
              @sdetweil Hi Sam.
              For a test I created an event in my calendar called test111 and verified server sync across several devices. This event starts in a few hours time so should be at the top of the events displayed on the mirror. I then stopped and started pm2.
              Here are the magicmirror debug logs for the event:
              [19.01.2024 08:41.23.286] [DEBUG] Event:
              {"type":"VEVENT","params":[],"created":"2024-01-19T08:39:52.000Z","lastmodified":"2024-01-19T08:40:05.000Z","dtstamp":"2024-01-19T08:40:05.000Z","uid":"7383cead-3ce7-4a50-80d0-cf214e98caac","summary":"test111","start":"2024-01-19T11:00:00.000Z","datetype":"date-time","end":"2024-01-19T12:00:00.000Z","transparency":"OPAQUE"}
              [19.01.2024 08:41.23.287] [DEBUG] start: Fri Jan 19 2024 11:00:00 GMT+0000 (Greenwich Mean Time)
              [19.01.2024 08:41.23.287] [DEBUG] end:: Fri Jan 19 2024 12:00:00 GMT+0000 (Greenwich Mean Time)
              [19.01.2024 08:41.23.287] [DEBUG] duration: 3600000
              [19.01.2024 08:41.23.287] [DEBUG] title: test111
              [19.01.2024 08:41.23.288] [DEBUG] initial tz=Europe/London
              [19.01.2024 08:41.23.288] [DEBUG] corrected tz=Europe/London
              [19.01.2024 08:41.23.288] [DEBUG] start date/time=Fri Jan 19 2024 11:00:00 GMT+0000 (Greenwich Mean Time)
              [19.01.2024 08:41.23.288] [DEBUG] start offset=0
              [19.01.2024 08:41.23.289] [DEBUG] start date/time w tz =Fri Jan 19 2024 11:00:00 GMT+0000 (Greenwich Mean Time)
              [19.01.2024 08:41.23.289] [DEBUG] event date=Fri Jan 19 2024 11:00:00 GMT+0000 (Greenwich Mean Time)
              [19.01.2024 08:41.23.289] [DEBUG] event offset=0 hour=11 event date=Fri Jan 19 2024 11:00:00 GMT+0000 (Greenwich Mean Time)
              [19.01.2024 08:41.23.289] [DEBUG] adjustHours=0
              [19.01.2024 08:41.23.290] [DEBUG] Processing entry...
              [19.01.2024 08:41.23.297] [INFO]  Calendar-Fetcher: Broadcasting 621 events from https://my.cal.url
              But in dev tools the event does not appear in the before filter events or events to process console sections which, i think, would indicate it’s not being parsed through to the UI…?
              For comparison, if it helps, an event that is being parsed through looks like this in the logs (with a couple of bits redacted for privacy):
              [19.01.2024 08:41.45.109] [DEBUG] Event:
              {"type":"VEVENT","params":[],"created":"2024-01-05T14:17:41.000Z","end":"2024-01-20T21:00:00.000Z","dtstamp":"2024-01-16T18:42:50.000Z","start":"2024-01-20T17:00:00.000Z","datetype":"date-time","lastmodified":"2024-01-16T18:42:49.000Z","location":"redacted","sequence":"2","summary":"Jarv birthday beers","transparency":"OPAQUE","uid":"7DF90CA7-D3BA-4519-96F7-944D027F79DE","url":{"params":{"VALUE":"URI"},"val":""},"APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000","APPLE-STRUCTURED-LOCATION":{"params":{"VALUE":"URI","X-ADDRESS":"redacted","X-APPLE-MAPKIT-HANDLE":"redacted","X-APPLE-RADIUS":141.1751152233582,"X-APPLE-REFERENCEFRAME":1,"X-TITLE":"redacted"},"val":"geo:redacted"}}
              [19.01.2024 08:41.45.109] [DEBUG] start: Sat Jan 20 2024 17:00:00 GMT+0000 (Greenwich Mean Time)
              [19.01.2024 08:41.45.110] [DEBUG] end:: Sat Jan 20 2024 21:00:00 GMT+0000 (Greenwich Mean Time)
              [19.01.2024 08:41.45.110] [DEBUG] duration: 14400000
              [19.01.2024 08:41.45.110] [DEBUG] title: Jarv birthday beers
              [19.01.2024 08:41.45.110] [DEBUG] initial tz=Europe/London
              [19.01.2024 08:41.45.110] [DEBUG] corrected tz=Europe/London
              [19.01.2024 08:41.45.111] [DEBUG] start date/time=Sat Jan 20 2024 17:00:00 GMT+0000 (Greenwich Mean Time)
              [19.01.2024 08:41.45.111] [DEBUG] start offset=0
              [19.01.2024 08:41.45.111] [DEBUG] start date/time w tz =Sat Jan 20 2024 17:00:00 GMT+0000 (Greenwich Mean Time)
              [19.01.2024 08:41.45.112] [DEBUG] event date=Sat Jan 20 2024 17:00:00 GMT+0000 (Greenwich Mean Time)
              [19.01.2024 08:41.45.112] [DEBUG] event offset=0 hour=17 event date=Sat Jan 20 2024 17:00:00 GMT+0000 (Greenwich Mean Time)
              [19.01.2024 08:41.45.112] [DEBUG] adjustHours=0
              [19.01.2024 08:41.45.113] [DEBUG] Processing entry...
              Thanks again.
                sdetweil @matt216
                @matt216 interesting
                time to fall back to the prior parser
                  matt216 @sdetweil
                  pi@magicmirror:~/MagicMirror $ npm install node-ical@0.16.1
                  up to date in 11s
                  196 packages are looking for funding
                    run `npm fund` for details
                  Done. Same result - event which should display is seen in the pm2 logs, but not in the UI events.
                    sdetweil @matt216
                    @matt216 I sent you a message here in chat with a link to another test version of the calendar parser file…
                      matt216 @sdetweil
                      @sdetweil Hi Sam. Thank you. Still no joy.
                      Here is what is displayed on my mirror:
                      Yet here is what is in my calendar (as shown on my iphone):
                      You can see multiple events missing, but I can’t figure out any pattern as to what shows and what does not.
                      I added in your calendarfetcherutils.js and restarted. Same behavior. The logs show the mirror is seeing the ‘house viewing PB’ events, for example, but it’s not showing up at all in dev tools or on the display.
                      [23.01.2024 09:17.06.900] [DEBUG] Event:
                      {"type":"VEVENT","params":[],"created":"2024-01-19T11:31:14.000Z","end":"2024-01-26T18:00:00.000Z","dtstamp":"2024-01-22T15:11:06.000Z","start":"2024-01-26T17:30:00.000Z","datetype":"date-time","lastmodified":"2024-01-22T15:11:05.000Z","sequence":"0","summary":"House viewing PB","transparency":"OPAQUE","uid":"92DD34B0-0226-4928-B476-EF1A5AC18471","url":{"params":{"VALUE":"URI"},"val":""},"APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000"}
                      [23.01.2024 09:17.06.901] [DEBUG] start: Fri Jan 26 2024 17:30:00 GMT+0000 (Greenwich Mean Time)
                      [23.01.2024 09:17.06.901] [DEBUG] end:: Fri Jan 26 2024 18:00:00 GMT+0000 (Greenwich Mean Time)
                      [23.01.2024 09:17.06.901] [DEBUG] duration: 1800000
                      [23.01.2024 09:17.06.901] [DEBUG] title: House viewing PB
                      [23.01.2024 09:17.06.902] [DEBUG] full day event =false
                      [23.01.2024 09:17.06.902] [DEBUG] initial tz=Europe/London
                      [23.01.2024 09:17.06.902] [DEBUG] corrected tz=Europe/London
                      [23.01.2024 09:17.06.902] [DEBUG] start date/time=Fri Jan 26 2024 17:30:00 GMT+0000 (Greenwich Mean Time)
                      [23.01.2024 09:17.06.903] [DEBUG] start offset=0
                      [23.01.2024 09:17.06.903] [DEBUG] start date/time w tz =Fri Jan 26 2024 17:30:00 GMT+0000 (Greenwich Mean Time)
                      [23.01.2024 09:17.06.903] [DEBUG] event date=Fri Jan 26 2024 17:30:00 GMT+0000 (Greenwich Mean Time)
                      [23.01.2024 09:17.06.904] [DEBUG] event offset=0 hour=17 event date=Fri Jan 26 2024 17:30:00 GMT+0000 (Greenwich Mean Time)
                      [23.01.2024 09:17.06.904] [DEBUG] adjustHours=0
                      [23.01.2024 09:17.06.904] [DEBUG] saving event: House viewing PB
                      [23.01.2024 09:17.06.904] [DEBUG] Processing entry...
                      Dev tools:
                      before filter events=[{"title":"Danielle clean","startDate":"1706004000000","endDate":"1706014800000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2023,"location":false,"geo":false,"description":false},{"title":"Matt Hoxton monthly social?","startDate":"1706198400000","endDate":"1706209200000","fullDayEvent":false,"class":"","location":false,"geo":false,"description":false},
                        sdetweil @matt216
                        @matt216 I sent you a link to a new utils file in chat here. it adds some more debug, including dumping the list of events just before send, which would show in the same place as the normal debug
                          matt216 @sdetweil
                          @sdetweil hi Sam. I can’t see the chat message with the utils file. Just the parser file. Would you send again please?
                            sdetweil @matt216
                            @matt216 hm. I just checked the chat message and the link is to the utils file
                            and I checked the file and it’s the utils file
                              matt216
                              For anyone following…
                              Issue still persists. https://github.com/MagicMirrorOrg/MagicMirror/issues/3380 has been opened.
                              Symptoms:
                              Calendar events that would be expected to be displayed on the calendar module are not. pm2 restart and full OS reboot does not resolve. I am using a baikal caldav server, FYI, which other devices have no trouble.
                              Troubleshooting:
                              We can see in the magicmirror logs that the events from the ics file are being received by the calendarfetcher but they are not being shown in events to process in the UI. I cannot see any pattern as to which events are affected.
                              I’ve tried this with a fresh install of magicmirror and I’ve also tried my main magicmirror with a fresh nextcloud calendar. Same behavior.
                              I’ll update if we find a solution.
                              Cheers.
                                sdetweil @matt216
                                @matt216 and I thought we confirmed the events WERE parsed and part of the collection ‘sent’ to the front end. but apparently not received…
                                  matt216 @sdetweil
                                  @sdetweil sorry that will be my bad use of language… will update
                                    sdetweil @matt216
                                    @matt216 no problem
                                    • 5 / 5
