    node_helper.js is not working?
    49 Posts 3 Posters 27.0k Views 3 Watching
    • V Offline
      vandy2424
      Hello all,
      Background:
      I am writing this post today about the issues I have been having with all modules involving node_helper.js. To start from the beginning, I recently started a MM project as I had all the parts needed lying around. I flashed the SD to Raspbian GNU/Linux 11 (bullseye) on my Raspberry Pi 3B.
      I have successfully installed all default modules and they all work great with no issues. I have also installed MMM-JokeAPI (a module that doesn’t use node_helper.js) and it works fine. It just uses the main module js file and fetches the data in there.
      The issue:
      I have noticed a strange pattern that seems to be emerging with any modules using node_helper.js. As I speak of these issues, here are the modules that I have tested all having this issue: (MMM-Cocktails, MMM-Dad-Jokes, MMM-DynamicWeather, MMM-RandomQuotes).
      **Another note, I know these modules may be “depreciated”, but many of them are very simple. Its just an API request basically. I have looked diligently through all of these for hours and don’t see a reason for the following issues. I have tested all of these API endpoints and the way they parse them. (They all still work)
      First, no matter if I include const Log = require("logger"); at the top of a node_helper.js file, I am unable to recieve output from Log.info, Log.log, Log.error or even console.log. I have looked at many forums on this issue, for many looking in the right location fixed this. I have restarted my MM hundreds of times looking at developer tools, the console and using pm2 logs and haven’t seen 1 output from these files. (This really sucks because I cant debug!) For example:
          Log.info("Testing this helper");
          console.log("TESTING this helper");
          start: function() {
              console.log("Starting node_helper for: " + this.name);
              Log.info("Starting node helper")
      I have tried sending console output in all of these modules in every location you can think of. I first thought that somehow the logs aren’t reaching the terminal console or the dev tools console, but now, I think these files may not be running at all.
      So to test this, in every single one of these modules, I went to the main module class. I found where sendSocketNotification(notification, payload) was used and did a Log.info(“Sending notification for XYZ module”). (Note, Logging always worked in the main module classes). For every single one of these modules, I got a log showing this bit of code was run.
      Now, I went to the spot in the modules main js files where socketNotificationReceived: function(notification, payload) {} was ran, and put a Log.info(“Recieved notification”) inside the function. None of the modules outputted this log. This is now why I am writing this post, because I am completely lost on what could be going on.
      I even just recently tested MMM-RandomQuotes, which just had a github update 5 days ago (presumably works) but I had the same outcome here.
      If curious, what these modules look like when starting MM, is their “loading” icons or “loading” text that appears since the API data does not seem to be coming back.
      Even with my hours of studying these files and doing research, I will say I’m still very much a beginner to the MagicMirror ins and outs. I would really appreciate any help on this, as I am currently unable to add anything it seems containing a node_helper.js class. Please let me know anything I can provide to help if needed. Thanks! :)
        sdetweil @vandy2424
        @vandy2424 ok, got it…
        the last line of the model (sample) config.js is critical
        because it was NOT there in yours,
        when we loaded the config using require()
        it returned {} (nothing)
        and the default was used, this is why no error was shown…
        file existed, was loaded successfully, but had no data
        my install script copies the config.js.sample to config.js so users most likely woudn’t experience this
        see https://github.com/sdetweil/MagicMirror_scripts
        V 1 Reply Last reply Reply Quote 1
          sdetweil @vandy2424
          @vandy2424 what version of MagicMirror are you using?
          what version of nodejs and electron are you running
          if you do npm run server do you get messages?
          • V Offline
            vandy2424 @sdetweil
            @sdetweil Hi Sam, thank you for the quick reply!
            MagicMirror version: v2.26.0
            NodeJs version: v20.11.0
            Electron version: 27.2.0
            If I do npm run server I do not get the messages.
              MMRIZE @vandy2424
              @vandy2424
              Is there any suspicious log in your terminal and front dev-console both? What they said?
              • V Offline
                vandy2424 @MMRIZE
                @MMRIZE Hello. To simplify this output, I am just enabling the default clock and weather module and MMM-DynamicWeather for these outputs. First is the dev console output. There is a Electron Security Warning but I think thats just a security notice. At the bottom, there is also another warning regarding the WebSocket.
                Dev-Console:
                main.js:589 Initializing MagicMirror².
                translator.js:122 Loading core translation file: translations/en.json
                VM4 sandbox_bundle:2 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                  Policy set or a policy with "unsafe-eval" enabled. This exposes users of
                  this app to unnecessary security risks.
                For more information and help, consult
                https://electronjs.org/docs/tutorial/security.
                This warning will not show up
                once the app is packaged.
                warnAboutInsecureCSP @ VM4 sandbox_bundle:2
                translator.js:138 Loading core translation fallback file: translations/en.json
                loader.js:165 Load script: modules/default/clock/clock.js
                module.js:484 Module registered: clock
                loader.js:138 Bootstrapping module: clock
                loader.js:165 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                loader.js:165 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                loader.js:165 Load script: vendor/node_modules/suncalc/suncalc.js
                loader.js:142 Scripts loaded for: clock
                loader.js:180 Load stylesheet: modules/default/clock/clock_styles.css
                loader.js:145 Styles loaded for: clock
                loader.js:148 Translations loaded for: clock
                loader.js:165 Load script: modules/default/weather/weather.js
                module.js:484 Module registered: weather
                loader.js:138 Bootstrapping module: weather
                loader.js:237 File already loaded: moment.js
                loader.js:165 Load script: modules/default/weather/weatherutils.js
                loader.js:165 Load script: modules/default/weather/weatherobject.js
                loader.js:165 Load script: modules/default/weather/providers/overrideWrapper.js
                loader.js:165 Load script: modules/default/weather/weatherprovider.js
                loader.js:237 File already loaded: suncalc.js
                loader.js:165 Load script: modules/default/weather/providers/openweathermap.js
                loader.js:142 Scripts loaded for: weather
                loader.js:180 Load stylesheet: vendor/css/font-awesome.css
                loader.js:180 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                loader.js:180 Load stylesheet: modules/default/weather/weather.css
                loader.js:145 Styles loaded for: weather
                loader.js:148 Translations loaded for: weather
                loader.js:237 File already loaded: weatherutils.js
                loader.js:237 File already loaded: weatherobject.js
                loader.js:237 File already loaded: modules/default/weather/providers/overrideWrapper.js
                loader.js:237 File already loaded: weatherprovider.js
                loader.js:237 File already loaded: modules/default/weather/providers/openweathermap.js
                loader.js:237 File already loaded: font-awesome.css
                loader.js:237 File already loaded: weather-icons.css
                loader.js:237 File already loaded: weather.css
                loader.js:165 Load script: modules/MMM-DynamicWeather/MMM-DynamicWeather.js
                module.js:484 Module registered: MMM-DynamicWeather
                loader.js:138 Bootstrapping module: MMM-DynamicWeather
                loader.js:142 Scripts loaded for: MMM-DynamicWeather
                loader.js:180 Load stylesheet: modules/MMM-DynamicWeather/MMM-DynamicWeather.css
                loader.js:145 Styles loaded for: MMM-DynamicWeather
                loader.js:148 Translations loaded for: MMM-DynamicWeather
                loader.js:180 Load stylesheet: css/custom.css
                clock.js:49 Starting module: clock
                weatherprovider.js:35 Weather provider: OpenWeatherMap initialized.
                weatherprovider.js:46 Weather provider: OpenWeatherMap started.
                MMM-DynamicWeather.js:94 Starting MMM-DynamicWeather
                MMM-DynamicWeather.js:111 https://api.openweathermap.org/data/3.0/onecall?appid=51acaf6aca47c36542b28b6342d4714a&lat=41.75&lon=-88.16
                MMM-DynamicWeather.js:227 Checked dates
                MMM-DynamicWeather.js:165 [MMM-DynamicWeather] Finished initialization
                main.js:608 All modules started!
                websocket.js:121 WebSocket connection to 'ws://localhost:8080/socket.io/?EIO=4&transport=websocket&sid=-Su8ujYWaq21RNXeAAAA' failed: WebSocket is closed before the connection is established.
                doClose @ websocket.js:121
                weather.js:166 New weather information available.
                clock.js:67 [Violation] 'setTimeout' handler took 147ms
                For the terminal, everything is good besides a warning regarding vkCreateInstance drivers. I didn’t think to mention these warnings as my default modules are still working perfectly fine and the ones with node_helper.js that aren’t working, are still displaying their DIV on the MagicMirror (“…loading”).
                Terminal:
                [09.02.2024 12:30.48.203] [LOG]   Starting MagicMirror: v2.26.0
                [09.02.2024 12:30.48.214] [LOG]   Loading config ...
                [09.02.2024 12:30.48.220] [DEBUG] config template file not exists, no envsubst
                [09.02.2024 12:30.48.227] [LOG]   Loading module helpers ...
                [09.02.2024 12:30.48.283] [LOG]   Initializing new module helper ...
                [09.02.2024 12:30.48.285] [LOG]   Module helper loaded: updatenotification
                [09.02.2024 12:30.48.287] [LOG]   No helper found for module: helloworld.
                [09.02.2024 12:30.48.289] [LOG]   All module helpers loaded.
                [09.02.2024 12:30.48.307] [LOG]   Starting server on port 8080 ...
                [09.02.2024 12:30.48.778] [LOG]   Server started ...
                [09.02.2024 12:30.48.781] [LOG]   Connecting socket for: updatenotification
                [09.02.2024 12:30.48.783] [LOG]   Starting module helper: updatenotification
                [09.02.2024 12:30.48.784] [LOG]   Sockets connected & modules started ...
                [09.02.2024 12:30.48.808] [LOG]   Launching application.
                Warning: vkCreateInstance: Found no drivers!
                Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                    at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                    at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                    at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                    at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                    at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                Again my knowledge of js and web applications is very limited so these warnings may have something to do with this node_helper issue that I’m unaware of. Please let me know if there is any other information that is useful.
                Thanks!
                S M 3 Replies Last reply Reply Quote 0
                  sdetweil @vandy2424
                  @vandy2424 we need to see the matching config.js please.
                  this run says only hello world and updatenotification are enabled
                    MMRIZE @vandy2424
                    @vandy2424
                    If websocket is closed, the path between module and node_helper might be broken. May that be the reason or clue. But very unusual thing. ATM I cannot guess what happened.
                      sdetweil @vandy2424
                      @vandy2424 said in node_helper.js is not working?:
                      nothing matches that. please show the config.js and the logs from both backend and front end
                      • V Offline
                        vandy2424 @sdetweil
                        @sdetweil Hi Sam, I am not sure what you mean by showing the logs from the backend and front end. I thought that is what I just showed you. (Terminal & dev console). You can see in the dev console, it loading clock, weather and MMM-DynamicWeather modules.
                        Please let me know what I am not understanding here and I will get you those logs. Thanks!
                        Here is the config.js file:
                        let config = {
                          address: "0.0.0.0",	// default is "localhost",
                          port: 8080,		// default,
                          ipWhitelist: [], // default -- need to add your IP here,
                              module: "clock",
                                    timeFormat:12,
                                    timezone:"America/Chicago",
                                    displaySeconds:"true",
                                    showPeriod:"true",
                                    showDate:"true",
                                    displayType:"both",
                              module: "weather",
                                type: "current",
                                units: "imperial",
                                tempUnits: "imperial",
                                windUnits: "imperial",
                                apiVersion: "3.0",
                                weatherEndpoint: "/onecall",
                                apiKey: "KEY",
                                lat:"50.75",
                                lon:"-88.16",
                                showUVindex:"true",
                              module: "weather",
                                type: "daily",
                                units: "imperial",
                                apiVersion: "3.0",
                                apiKey: "KEY",
                                lat:"50.75",
                                lon:"-88.16",
                             module: 'MMM-DynamicWeather',
                             position: 'fullscreen_above',
                             config: { // See https://github.com/scottcl88/MMM-DynamicWeather for more information.
                              api_key: "KEY",
                              lat:"50",
                              lon:"-88.16",
                        Again this is just with the DynamicWeather module. I can add others but this simplifies.
                          sdetweil @vandy2424
                          @vandy2424 backend , console output from npm start
                          front end, in the developers window
                          this config does not match the messages
                          • V Offline
                            vandy2424 @sdetweil
                            @sdetweil Hi Sam,
                            I am unsure how else I am supposed to respond other than to say, this is the exact config that produced those backend/front end logs. If this is unusual, maybe something is broken here? I am not sure what “working” logs are supposed to look like, since it sounds like mine may be broken.
                            To show proof, here are screenshots as I am unsure how else to provide feedback here.
                            (I pulled up the dev window as far as I could while still exposing working default modules). This output is the same as listed above:
                            I also did a CTRL-ALT-DELETE to allow me to access my text editor and pull up the MagicMirror/config.js file live while the magic mirror is still running. This is the exact config I posted previously:
                            The front & backend logs remain completely the same as posted earlier. Hopefully I am not completely misunderstanding you here. Thanks for the help!
                              MMRIZE @vandy2424
                              @vandy2424
                              I think websocket issue would be the reason. Can you confirm whether other node_helper dependent module(e.g. default calendar module) works other than MMM-DynamicWeather?
                              Usually, websocket could be broken by firewall setting, port problem, network quality or by old library, oand many various reasons. Anyway when websocket is broken once, socketNotification will not work.
                                sdetweil @vandy2424
                                @vandy2424 can you please show the contents of the config folder
                                S V 2 Replies Last reply Reply Quote 0
                                • V Offline
                                  vandy2424 @MMRIZE
                                  @MMRIZE Hey MMRize,
                                  Yeah I went ahead and setup the calendar module. The first thing I tried was running this module with the default config:
                                      position: "top_left", // This can be any of the regions. Best results in left or right regions.
                                        // If no config is set, an example calendar is shown.
                                  This returned loading… on the magic mirror. (I assumed based on the documentation it would at least show an example calendar).
                                  I then tried to add a very basic calendar in the config.js just to see if the result would change:
                                  						symbol: "calendar-check",
                                  						url: "https://www.calendarlabs.com/ical-calendar/ics/39/Canada_Holidays.ics"
                                  And i still got the same result (Loading…).
                                    @vandy2424
                                    when you start mm,do
                                     npm start >somefile.txt 2>&1
                                    that will capture all the backend output
                                    the front end said it started the modules listed in that config.js
                                    • V Offline
                                      vandy2424 @sdetweil
                                      @sdetweil yes here are the contents of the config folder:
                                      • V Offline
                                        vandy2424 @sdetweil
                                        @sdetweil I did this and exported a file out. I then went ahead and ran the MagicMirror for 2 minutes.
                                        Here is the output (same as before):
                                        [09.02.2024 17:44.28.817] [LOG]   Starting MagicMirror: v2.26.0
                                        [09.02.2024 17:44.28.835] [LOG]   Loading config ...
                                        [09.02.2024 17:44.28.841] [DEBUG] config template file not exists, no envsubst
                                        [09.02.2024 17:44.28.848] [LOG]   Loading module helpers ...
                                        [09.02.2024 17:44.28.905] [LOG]   Initializing new module helper ...
                                        [09.02.2024 17:44.28.907] [LOG]   Module helper loaded: updatenotification
                                        [09.02.2024 17:44.28.909] [LOG]   No helper found for module: helloworld.
                                        [09.02.2024 17:44.28.910] [LOG]   All module helpers loaded.
                                        [09.02.2024 17:44.28.928] [LOG]   Starting server on port 8080 ...
                                        [09.02.2024 17:44.29.399] [LOG]   Server started ...
                                        [09.02.2024 17:44.29.402] [LOG]   Connecting socket for: updatenotification
                                        [09.02.2024 17:44.29.404] [LOG]   Starting module helper: updatenotification
                                        [09.02.2024 17:44.29.405] [LOG]   Sockets connected & modules started ...
                                        [09.02.2024 17:44.29.429] [LOG]   Launching application.
                                        [09.02.2024 17:46.45.217] [LOG]   Shutting down server...
                                        [09.02.2024 17:46.45.219] [LOG]   Stopping module helper: updatenotification
                                        [09.02.2024 17:46.45.221] [LOG]   Node_helpers stopped ...
                                          sdetweil @vandy2424
                                          @vandy2424 bizarre, ok try this
                                          cd ~
                                          find . -type f -name config.js
                                          there was a path resolve fix for config.js in this release
                                          • V Offline
                                            vandy2424 @sdetweil
                                            @sdetweil it returned the same location:
                                            jackson@raspberrypi:~ $ find . -type f -name config.js
                                            ./Documents/MagicMirror/config/config.js
                                              sdetweil @vandy2424
                                              @vandy2424 weird. the console output doesn’t match…
                                              ok, another thing, MagicMirror not running
                                              ps -ef | grep -i magic
