    Trouble with non-broken "broken" images
    12 Posts 2 Posters 4.0k Views 2 Watching
      jedilkeme @sdetweil
      @sdetweil ctrl-alt-i has no effect???
      S J 2 Replies Last reply
        sdetweil @jedilkeme
        @jedilkeme I’m sorry, brain fart, ctrl-shift-i
          jedilkeme @jedilkeme
          @jedilkeme what should I be looking for from there?
            sdetweil @jedilkeme
            @jedilkeme in the console tab, you might see a 404 error, not found
            in the elements tab you can see the actual html used.
            J 1 Reply Last reply
              jedilkeme @sdetweil
              @sdetweil no 404 errors or anything else that pops out at me…
                sdetweil @jedilkeme
                @jedilkeme and if you look at the html for the image, it is as you expected. and if you use that url.i a browser, the image is displayed?
                  jedilkeme @sdetweil
                  @sdetweil ah, it wasn’t showing errors because I had it written to load at 5am… I set it to run in one minute, and I did receive a 404 for the images, permissions are all groovy but I noticed I can’t view the images from localhost:8080/path-to-images in the browser, but if I just put in the file path in the address bar I can see the images… then I ran npm start dev and I found an EADDRINUSE error. Stumped. Thanks your you assistance so far!
                    sdetweil @jedilkeme
                    @jedilkeme said in Trouble with non-broken "broken" images:
                    pm2 already has an instance running… only one at a time please on the same port
                    pm2 status to see what pm2 manages
                    pm2 --help
                    to see all the things it CAN do
                    pm2 stop name or row number or all
                    pm2 stop all
                    then you can do the npm start …
                    when u are happy , then ctrl-q or ctrl-c to stop the npm start and pm2 start or restart row or name
                    then on reboot it will come back up…
                    pm2’s JOB is to keep its managed apps running…
                      @jedilkeme path to images
                      http://localhost:8080
                      is the MagicMirror folder
                      so files in a module would be
                      http://localhost:8080/modules/modulename/xxx.jpg  (or whatever)
                        jedilkeme @sdetweil
                        @sdetweil that was my issue, I had assumed :8080/ what my main directory… fixed it. Thanks a bunch!
