    Notification Timer none dosent work
    18 Posts 2 Posters 6.4k Views 2 Watching
    • F Offline
      fischi87
      Hello guys I trigger a notification with a message but the timer dosend work. Here my simple code snippet:
          commandId: "Finish",
          notiID: "SHOW_ALERT",
          notiPayload: { type: 'notification', message: 'Der Monitor ist eingeschaltet.', timer: 'none'}
      the notification shows already fine but after 2 sek is not to see anymore. I want no timers the notification is always on. I hope u can understand me. I tried already with 0 but still doesn’t work.
      thanks
        sdetweil @fischi87
        @fischi87 notification has to time out, either the notification timer value or the display_time value
          sdetweil @fischi87
          @fischi87 the doc says do not specify timer
          the doc ‘none’ answer means not specified by default
          • F Offline
            fischi87 @sdetweil
            do u have a idea how can i set none timer so the notification will display until i cancel it by my self?
            with my code the notification is displayed just 3 sek.
              sdetweil @fischi87
              @fischi87 just don’t specify the timer value
              • F Offline
                fischi87 @sdetweil
                @sdetweil how is it possible the make a notification what will display without a timer? i want show a notification and want cancel this notification by my self where my next question is, how can i cancel a notification, is there a way for it? like the alert.
                  sdetweil @fischi87
                  @fischi87 just don’t add the timer: value in the notification you send
                  • F Offline
                    fischi87 @sdetweil
                    @sdetweil this dont work, it displaed just 3 sek wihout the timer.
                      sdetweil @fischi87
                      @fischi87 the doc says, if you don’t specify timer in a notification type, then the config option display_time will be used (and defaults to 3.5 seconds, 3500ms)
                      if you use an alert type , then no timer value will cause the message to be displayed til removed
                      note one has a type in the payload (notification type) and one does not (alert type)
                      so your notification should be
                          notiPayload: {  message: 'Der Monitor ist eingeschaltet.' }
                      • F Offline
                        fischi87 @sdetweil
                        ur are right for the alert but with the type notification (SHOW_ALERT with type = notification) are 2 different things. if i send a show alert without a type it displed me the alert with blur background and so on and with the type: notification it shows me a little box with my message and this notification canceled after 3 sek. i didnt set a timer or a display_time, the alert shows as long i want but the notification canceld alter 3 sek. this is my problem!
                          sdetweil @fischi87
                          @fischi87 yes, the doc says
                          display_time
                          so, add a new property to the alert module config:{} block
                          (if it doesn’t have a config:{} block, add one)
                           display_time: 7*24*60*60*1000  // 7 days in milliseconds
                          • F Offline
                            fischi87 @sdetweil
                            and how can i cancel before the timer (7days) finished?
                              sdetweil @fischi87
                              @fischi87 you have to send another notification, read the doc
                              • F Offline
                                fischi87 @sdetweil
                                I read it already 100 times but nothing will work. Sorry is there a issue with the Modul? I think i dont ger also no updatenotifications?
                                Greedings
                                  sdetweil @fischi87
                                  @fischi87 come on.
                                  send the HIDE_ALERT notifications
                                  • F Offline
                                    fischi87 @sdetweil
                                    Sorry i think we Talk for different things. With the alert it works but not with the notification. I will See that i can show u a picture later maybe u will understand what i mean!
                                    For now thanks for it time!
                                      sdetweil @fischi87
                                      • F Offline
                                        fischi87 @sdetweil
                                        That sucks
                                          sdetweil @fischi87
                                          @fischi87 one could always submit an enhancement request issue to the MM github page…
