    MagicMirror does not start in full screen
    42 Posts 2 Posters 29.4k Views 2 Watching
      drx1984 @sdetweil
      Do you mean under the path execute this command?
      like on the picture?
      So:MM-3.png ??
        @sdetweil said in MagicMirror does not start in full screen:
        cd MagicMirror
        no…
        I said
        cd ~
        this means
        change to the users home folder
          drx1984 @sdetweil
          @sdetweil ah ok sry, now I’ve done it like this and when I restart the Intel Nuc, the MagicMirror still doesn’t start in full screen.
          why is this happening:-(
            sdetweil @drx1984
            @drx1984 because the title bar is showing, is this thru vnc?
            vnc sets its own screen size and doesn’t tell the truth …
            not you CAN override in the config.js
            in the same group as address add
            electronOptions:{width:xxxx, height:yyyy},
            where xxxx and yyyy are the width and height of the screen
              drx1984 @sdetweil
              The AnyDesk program is installed.
              Should I uninstall this?? I broke the tool to get to IntelNuc.
              can I fix the problem with this entry? and in which line do I add this “electronOptions:{width:xxxx, height:yyyy}” parameter in config.js
                sdetweil @drx1984
                @drx1984 said in MagicMirror does not start in full screen:
                as I said, in the same group of properties as the address: property
                  drx1984 @sdetweil
                  @sdetweil Sorry, I don’t fully understand you. can you enlighten me?
                    sdetweil @drx1984
                    @drx1984
                    anywhere in this group
                    	address: "0.0.0.0", 	// Address to listen on, can be:
                    	port: 8090,
                    	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                    	ipWhitelist: [], 	// Set [] to allow all IP addresses
                    	language: "en",
                    	locale: "en-US",
                    	timeFormat: 24,
                    	units: "metric",
                      drx1984 @sdetweil
                      @sdetweil Can’t you tell me exactly which line?
                      I have now entered it as shown in the picture but unfortunately it doesn’t work.
                        sdetweil @drx1984
                        @drx1984 in between ANY line in that group… js is a name/value pair, so it doesn’t matter the order…
                        BUT you have the wrong values in portrait mode…
                        height is 1920, width is 1080
                        is it correct on the physical screen?
                        from the eletron doc
                        https://www.electronjs.org/docs/latest/api/browser-window
                        new BrowserWindow([options])
                        options BrowserWindowConstructorOptions (optional)
                        width Integer (optional) - Window's width in pixels. Default is 800.
                        height Integer (optional) - Window's height in pixels. Default is 600.
                        x Integer (optional) - (required if y is used) Window's left offset from screen. Default is to center the window.
                        y Integer (optional) - (required if x is used) Window's top offset from screen. Default is to center the window.
                        useContentSize boolean (optional) - The width and height would be used as web page's size, which means the actual window's size will include window frame's size and be slightly larger. Default is false.
                        center boolean (optional) - Show window in the center of the screen. Default is false.
                        minWidth Integer (optional) - Window's minimum width. Default is 0.
                        minHeight Integer (optional) - Window's minimum height. Default is 0.
                          drx1984 @sdetweil
                          @sdetweil yes, the resolution is as follows under system settings:
                          The monitor is a 24 inch/full HD and is set to portrait format.
                          then the values should be correct 1920x1080 right?
                            sdetweil @drx1984
                            @drx1984 wider than taller (1920x1080) (w,h) is landscape mode
                            taller than wider (1080x1920) (w,h) is portrait mode
                            are you trying to do both at the same time?
                            landscape on physical screen and portrait over connection?
                            can’t do that, physical screen wins
                              drx1984 @sdetweil
                              Good morning,
                              So even if I set physical landscape format and restart the system, the MagicMirror doesn’t appear in full screen >> look at the photo I took on my cell phone without Anydesk access.
                              And I uploaded a video clip to YouTube: https://www.youtube.com/watch?v=gjiYQ21SoKI
                              And I entered the entry with: electronOptions:{width:xxxx, height:yyyy}:
                              Where else can the problem be?
                              Thanks for your help.
                                sdetweil @drx1984
                                @drx1984 in the electronOptions add at the end
                                ,fullScreen:true
                                note the leading comma, as this will be after the height:1080
                                  drx1984 @sdetweil
                                  @sdetweil Is that what you mean>> electronOptions:{width:1920, height:1080, fullScreen:true}, ?
                                  unfortunately nothing came of it
                                    sdetweil @drx1984
                                    @drx1984 yes…
                                    what OS is this
                                    show results of
                                    lsb_release -a
                                    uname -a
                                    also, stop MagicMirror and then delete the .config for Electron as before
                                    then restart MagicMirror
                                      drx1984 @sdetweil
                                      @sdetweil Unfortunately I have to leave now sry, I’ll get back to you tomorrow.
                                      There is an Ubuntu 22.04.4 installed on an IntelNuc.
                                      I have another YouTube video >you can see how it is briefly in full screen at the start and then the full screen goes away again. Watch the video clip until the end: https://www.youtube.com/watch?v=5fRf2pJuET8
                                      thanks
                                        sdetweil @drx1984
                                        @drx1984 ok, how are u launching mm?
                                        show results of
                                        pm2 status
                                          drx1984 @sdetweil
                                          Good morning, MagicMirror actually starts when I restart, but I can also start MagicMirror in the terminal with pm2 start.
                                          If I start the MagicMirror myself via the terminal, everything is displayed in full screen, but not when I reboot.
                                          I installed MagicMirror with this script: bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                                          Everything works, except the full screen doesn’t work when IntelNuc is restarted.
                                            sdetweil @drx1984
                                            @drx1984 thats my install script
                                            so, lets create the pm2 entry
                                            pm2 stop all
                                            pm2 delete 0
                                            pm2 save -f
                                            # run script from my list to setup pm2
                                            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
