    MagicMirror does not start in full screen
    42 Posts 2 Posters 28.9k Views 2 Watching
      sdetweil @drx1984
      @drx1984 because the title bar is showing, is this thru vnc?
      vnc sets its own screen size and doesn’t tell the truth …
      not you CAN override in the config.js
      in the same group as address add
      electronOptions:{width:xxxx, height:yyyy},
      where xxxx and yyyy are the width and height of the screen
        drx1984 @sdetweil
        @sdetweil said in MagicMirror does not start in full screen:
        The AnyDesk program is installed.
        Should I uninstall this?? I broke the tool to get to IntelNuc.
        can I fix the problem with this entry? and in which line do I add this “electronOptions:{width:xxxx, height:yyyy}” parameter in config.js
          sdetweil @drx1984
          @drx1984 said in MagicMirror does not start in full screen:
          as I said, in the same group of properties as the address: property
            drx1984 @sdetweil
            @sdetweil Sorry, I don’t fully understand you. can you enlighten me?
              sdetweil @drx1984
              @drx1984
              anywhere in this group
              	address: "0.0.0.0", 	// Address to listen on, can be:
              	port: 8090,
              	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
              	ipWhitelist: [], 	// Set [] to allow all IP addresses
              	language: "en",
              	locale: "en-US",
              	timeFormat: 24,
              	units: "metric",
                drx1984 @sdetweil
                @sdetweil Can’t you tell me exactly which line?
                I have now entered it as shown in the picture but unfortunately it doesn’t work.
                  sdetweil @drx1984
                  @drx1984 in between ANY line in that group… js is a name/value pair, so it doesn’t matter the order…
                  BUT you have the wrong values in portrait mode…
                  height is 1920, width is 1080
                  is it correct on the physical screen?
                  from the eletron doc
                  https://www.electronjs.org/docs/latest/api/browser-window
                  new BrowserWindow([options])
                  options BrowserWindowConstructorOptions (optional)
                  width Integer (optional) - Window's width in pixels. Default is 800.
                  height Integer (optional) - Window's height in pixels. Default is 600.
                  x Integer (optional) - (required if y is used) Window's left offset from screen. Default is to center the window.
                  y Integer (optional) - (required if x is used) Window's top offset from screen. Default is to center the window.
                  useContentSize boolean (optional) - The width and height would be used as web page's size, which means the actual window's size will include window frame's size and be slightly larger. Default is false.
                  center boolean (optional) - Show window in the center of the screen. Default is false.
                  minWidth Integer (optional) - Window's minimum width. Default is 0.
                  minHeight Integer (optional) - Window's minimum height. Default is 0.
                    drx1984 @sdetweil
                    @sdetweil yes, the resolution is as follows under system settings:
                    The monitor is a 24 inch/full HD and is set to portrait format.
                    then the values should be correct 1920x1080 right?
                      sdetweil @drx1984
                      @drx1984 wider than taller (1920x1080) (w,h) is landscape mode
                      taller than wider (1080x1920) (w,h) is portrait mode
                      are you trying to do both at the same time?
                      landscape on physical screen and portrait over connection?
                      can’t do that, physical screen wins
                        drx1984 @sdetweil
                        Good morning,
                        So even if I set physical landscape format and restart the system, the MagicMirror doesn’t appear in full screen >> look at the photo I took on my cell phone without Anydesk access.
                        And I uploaded a video clip to YouTube: https://www.youtube.com/watch?v=gjiYQ21SoKI
                        And I entered the entry with: electronOptions:{width:xxxx, height:yyyy}:
                        Where else can the problem be?
                        Thanks for your help.
                          sdetweil @drx1984
                          @drx1984 in the electronOptions add at the end
                          ,fullScreen:true
                          note the leading comma, as this will be after the height:1080
                            drx1984 @sdetweil
                            @sdetweil Is that what you mean>> electronOptions:{width:1920, height:1080, fullScreen:true}, ?
                            unfortunately nothing came of it
                              sdetweil @drx1984
                              @drx1984 yes…
                              what OS is this
                              show results of
                              lsb_release -a
                              uname -a
                              also, stop MagicMirror and then delete the .config for Electron as before
                              then restart MagicMirror
                                drx1984 @sdetweil
                                @sdetweil Unfortunately I have to leave now sry, I’ll get back to you tomorrow.
                                There is an Ubuntu 22.04.4 installed on an IntelNuc.
                                I have another YouTube video >you can see how it is briefly in full screen at the start and then the full screen goes away again. Watch the video clip until the end: https://www.youtube.com/watch?v=5fRf2pJuET8
                                thanks
                                  sdetweil @drx1984
                                  @drx1984 ok, how are u launching mm?
                                  show results of
                                  pm2 status
                                    drx1984 @sdetweil
                                    Good morning, MagicMirror actually starts when I restart, but I can also start MagicMirror in the terminal with pm2 start.
                                    If I start the MagicMirror myself via the terminal, everything is displayed in full screen, but not when I reboot.
                                    I installed MagicMirror with this script: bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                                    Everything works, except the full screen doesn’t work when IntelNuc is restarted.
                                      sdetweil @drx1984
                                      @drx1984 thats my install script
                                      so, lets create the pm2 entry
                                      pm2 stop all
                                      pm2 delete 0
                                      pm2 save -f
                                      # run script from my list to setup pm2
                                      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                                        drx1984 @sdetweil
                                        @sdetweil I just tried, unfortunately still no full screen after restarting.
                                          sdetweil @drx1984
                                          @drx1984 hm…
                                          can you do
                                          pm2 info 0 >somefile.txt
                                          and send me the somefile.txt at my same userid on gmail
                                            drx1984 @sdetweil
                                            @sdetweil OK, I created it. what is your email address?
                                            or can I post it here too?
