    MagicMirror does not start in full screen
    42 Posts 2 Posters 25.6k Views 2 Watching
      drx1984
      Hello everyone, can someone tell me why the MagicMirror only shows half of the screen after a restart and not the full screen?
      If I close MagicMirror manually and start it again via the terminal, it doesn’t appear correctly in full screen, but when I restart the PC (IntelNuc).
      The image orientation would be portrait format, I set everything to portrait format under Ubuntu screen settings.
      MagicMirror in portrait format:
      and this is what it looks like in landscape format > the MagicMirror is not in full screen either:
      Can someone help me with that?
        sdetweil @drx1984
        @drx1984 sadly it looks perfect.
        do this
        edit
        ~/MagicMirror/installers/mm.sh
        insert a new line 2
        sleep 10
        then reboot
          sdetweil @drx1984
          @drx1984 try this
          stop MagicMirror
          pm2 stop all
          then
           cd ~
          rm  -rf .config/Electron
          note the dot in front of config
          then restart MagicMirror
          D S 2 Replies Last reply Reply Quote 0
            drx1984 @sdetweil
            Do you mean under the path execute this command?
            like on the picture?
            So:MM-3.png ??
              @sdetweil said in MagicMirror does not start in full screen:
              cd MagicMirror
              no…
              I said
              cd ~
              this means
              change to the users home folder
                drx1984 @sdetweil
                @sdetweil ah ok sry, now I’ve done it like this and when I restart the Intel Nuc, the MagicMirror still doesn’t start in full screen.
                why is this happening:-(
                  sdetweil @drx1984
                  @drx1984 because the title bar is showing, is this thru vnc?
                  vnc sets its own screen size and doesn’t tell the truth …
                  not you CAN override in the config.js
                  in the same group as address add
                  electronOptions:{width:xxxx, height:yyyy},
                  where xxxx and yyyy are the width and height of the screen
                    drx1984 @sdetweil
                    The AnyDesk program is installed.
                    Should I uninstall this?? I broke the tool to get to IntelNuc.
                    can I fix the problem with this entry? and in which line do I add this “electronOptions:{width:xxxx, height:yyyy}” parameter in config.js
                      sdetweil @drx1984
                      @drx1984 said in MagicMirror does not start in full screen:
                      as I said, in the same group of properties as the address: property
                        drx1984 @sdetweil
                        @sdetweil Sorry, I don’t fully understand you. can you enlighten me?
                          sdetweil @drx1984
                          @drx1984
                          anywhere in this group
                          	address: "0.0.0.0", 	// Address to listen on, can be:
                          	port: 8090,
                          	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                          	ipWhitelist: [], 	// Set [] to allow all IP addresses
                          	language: "en",
                          	locale: "en-US",
                          	timeFormat: 24,
                          	units: "metric",
                          • 1 / 5
