    MagicMirror does not start in full screen
    42 Posts 2 Posters 28.5k Views 2 Watching
      sdetweil @drx1984
      @drx1984 hm…
      can you do
      pm2 info 0 >somefile.txt
      and send me the somefile.txt at my same userid on gmail
        drx1984 @sdetweil
        @sdetweil OK, I created it. what is your email address?
        or can I post it here too?
          sdetweil @drx1984
          @drx1984 don’t post here, too much stuff
          I gave you my email
          I protect myself against scrapers looking for email
            drx1984 @sdetweil
            @sdetweil OK, all right, I just sent you the file
              sdetweil @drx1984
              @drx1984 ok, don’t see it yet
                drx1984 @sdetweil
                @sdetweil hmm, so I understood you correctly, your email address is “username” from this forum and ....@gmail.com >correct?
                Or check your spam folder?
                  sdetweil @drx1984
                  @drx1984 correct
                    drx1984 @sdetweil
                    @sdetweil OK then I did it right. received now?
                      sdetweil @drx1984
                      @drx1984 yes, just arrived…
                        drx1984 @sdetweil
                        @sdetweil OK, great
                          sdetweil @drx1984
                          @drx1984 sadly it looks perfect.
                          do this
                          edit
                          ~/MagicMirror/installers/mm.sh
                          insert a new line 2
                          sleep 10
                          then reboot
                            drx1984 @sdetweil
                            @sdetweil that’s what she means?
                              sdetweil @drx1984
                              @drx1984 yes it will sleep 10 seconds before starting MagicMirror
                                drx1984 @sdetweil
                                Hello, hey, it actually works with “sleep 10” Thank you very much. Can you explain to me what “sleep 10” does? Is it normal to make this entry?
                                Can I also add this entry for GPU (export ELECTRON_ENABLE_GPU=1) ?
                                Like in the picture:1.png
                                  sdetweil @drx1984
                                  @drx1984 great news. some timing problem.
                                  yes you can add to the script like that
                                  you can try reducing the sleep to 5 seconds as well
                                    drx1984 @sdetweil
                                    OK, I will do that, thank you very much for your help
                                      drx1984
                                      Good morning, you can now mark the topic as “solved”. Thank you
                                        sdetweil @drx1984
                                        @drx1984 you can do that too.
                                        pick the message that you think provides the best solution, hit the 3 dots to the right and select
                                        mark this post…
                                          drx1984 @sdetweil
                                          @sdetweil hi, ok, great, I just did it. Thanks
                                          • 2 / 3
