    MagicMirror does not start in full screen
    42 Posts 2 Posters 29.9k Views 2 Watching
      drx1984 @sdetweil
      Good morning,
      So even if I set physical landscape format and restart the system, the MagicMirror doesn’t appear in full screen >> look at the photo I took on my cell phone without Anydesk access.
      And I uploaded a video clip to YouTube: https://www.youtube.com/watch?v=gjiYQ21SoKI
      And I entered the entry with: electronOptions:{width:xxxx, height:yyyy}:
      Where else can the problem be?
      Thanks for your help.
        sdetweil @drx1984
        @drx1984 in the electronOptions add at the end
        ,fullScreen:true
        note the leading comma, as this will be after the height:1080
        D 1 Reply Last reply
          drx1984 @sdetweil
          @sdetweil Is that what you mean>> electronOptions:{width:1920, height:1080, fullScreen:true}, ?
          unfortunately nothing came of it
            sdetweil @drx1984
            @drx1984 yes…
            what OS is this
            show results of
            lsb_release -a
            uname -a
            also, stop MagicMirror and then delete the .config for Electron as before
            then restart MagicMirror
              drx1984 @sdetweil
              @sdetweil Unfortunately I have to leave now sry, I’ll get back to you tomorrow.
              There is an Ubuntu 22.04.4 installed on an IntelNuc.
              I have another YouTube video >you can see how it is briefly in full screen at the start and then the full screen goes away again. Watch the video clip until the end: https://www.youtube.com/watch?v=5fRf2pJuET8
              thanks
                sdetweil @drx1984
                @drx1984 ok, how are u launching mm?
                show results of
                pm2 status
                  drx1984 @sdetweil
                  Good morning, MagicMirror actually starts when I restart, but I can also start MagicMirror in the terminal with pm2 start.
                  If I start the MagicMirror myself via the terminal, everything is displayed in full screen, but not when I reboot.
                  I installed MagicMirror with this script: bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                  Everything works, except the full screen doesn’t work when IntelNuc is restarted.
                    sdetweil @drx1984
                    @drx1984 thats my install script
                    so, lets create the pm2 entry
                    pm2 stop all
                    pm2 delete 0
                    pm2 save -f
                    # run script from my list to setup pm2
                    bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                      drx1984 @sdetweil
                      @sdetweil I just tried, unfortunately still no full screen after restarting.
                        sdetweil @drx1984
                        @drx1984 hm…
                        can you do
                        pm2 info 0 >somefile.txt
                        and send me the somefile.txt at my same userid on gmail
                          drx1984 @sdetweil
                          @sdetweil OK, I created it. what is your email address?
                          or can I post it here too?
                            sdetweil @drx1984
                            @drx1984 don’t post here, too much stuff
                            I gave you my email
                            I protect myself against scrapers looking for email
                              drx1984 @sdetweil
                              @sdetweil OK, all right, I just sent you the file
                                sdetweil @drx1984
                                @drx1984 ok, don’t see it yet
                                  drx1984 @sdetweil
                                  @sdetweil hmm, so I understood you correctly, your email address is “username” from this forum and ....@gmail.com >correct?
                                  Or check your spam folder?
                                    sdetweil @drx1984
                                    @drx1984 correct
                                      drx1984 @sdetweil
                                      @sdetweil OK then I did it right. received now?
                                        sdetweil @drx1984
                                        @drx1984 yes, just arrived…
                                          drx1984 @sdetweil
                                          @sdetweil OK, great
                                            sdetweil @drx1984
                                            @drx1984 sadly it looks perfect.
                                            do this
                                            edit
                                            ~/MagicMirror/installers/mm.sh
                                            insert a new line 2
                                            sleep 10
                                            then reboot
                                            • 2 / 3
