    MagicMirror does not start in full screen
    42 Posts 2 Posters 29.9k Views 2 Watching
      sdetweil @drx1984
      @drx1984 yes…
      what OS is this
      show results of
      lsb_release -a
      uname -a
      also, stop MagicMirror and then delete the .config for Electron as before
      then restart MagicMirror
      D 1 Reply Last reply
        drx1984 @sdetweil
        @sdetweil Unfortunately I have to leave now sry, I’ll get back to you tomorrow.
        There is an Ubuntu 22.04.4 installed on an IntelNuc.
        I have another YouTube video >you can see how it is briefly in full screen at the start and then the full screen goes away again. Watch the video clip until the end: https://www.youtube.com/watch?v=5fRf2pJuET8
        thanks
          sdetweil @drx1984
          @drx1984 ok, how are u launching mm?
          show results of
          pm2 status
            drx1984 @sdetweil
            Good morning, MagicMirror actually starts when I restart, but I can also start MagicMirror in the terminal with pm2 start.
            If I start the MagicMirror myself via the terminal, everything is displayed in full screen, but not when I reboot.
            I installed MagicMirror with this script: bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
            Everything works, except the full screen doesn’t work when IntelNuc is restarted.
              sdetweil @drx1984
              @drx1984 thats my install script
              so, lets create the pm2 entry
              pm2 stop all
              pm2 delete 0
              pm2 save -f
              # run script from my list to setup pm2
              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                drx1984 @sdetweil
                @sdetweil I just tried, unfortunately still no full screen after restarting.
                  sdetweil @drx1984
                  @drx1984 hm…
                  can you do
                  pm2 info 0 >somefile.txt
                  and send me the somefile.txt at my same userid on gmail
                    drx1984 @sdetweil
                    @sdetweil OK, I created it. what is your email address?
                    or can I post it here too?
                      sdetweil @drx1984
                      @drx1984 don’t post here, too much stuff
                      I gave you my email
                      I protect myself against scrapers looking for email
                        drx1984 @sdetweil
                        @sdetweil OK, all right, I just sent you the file
                          sdetweil @drx1984
                          @drx1984 ok, don’t see it yet
                            drx1984 @sdetweil
                            @sdetweil hmm, so I understood you correctly, your email address is “username” from this forum and ....@gmail.com >correct?
                            Or check your spam folder?
                              sdetweil @drx1984
                              @drx1984 correct
                                drx1984 @sdetweil
                                @sdetweil OK then I did it right. received now?
                                  sdetweil @drx1984
                                  @drx1984 yes, just arrived…
                                    drx1984 @sdetweil
                                    @sdetweil OK, great
                                      sdetweil @drx1984
                                      @drx1984 sadly it looks perfect.
                                      do this
                                      edit
                                      ~/MagicMirror/installers/mm.sh
                                      insert a new line 2
                                      sleep 10
                                      then reboot
                                        drx1984 @sdetweil
                                        @sdetweil that’s what she means?
                                          sdetweil @drx1984
                                          @drx1984 yes it will sleep 10 seconds before starting MagicMirror
                                            drx1984 @sdetweil
                                            Hello, hey, it actually works with “sleep 10” Thank you very much. Can you explain to me what “sleep 10” does? Is it normal to make this entry?
                                            Can I also add this entry for GPU (export ELECTRON_ENABLE_GPU=1) ?
                                            Like in the picture:1.png
                                            • 2 / 3
