    MagicMirror does not start in full screen
    42 Posts 2 Posters 28.5k Views 2 Watching
      sdetweil @drx1984
      @drx1984 ok, don’t see it yet
        drx1984 @sdetweil
        @sdetweil hmm, so I understood you correctly, your email address is “username” from this forum and ....@gmail.com >correct?
        Or check your spam folder?
          sdetweil @drx1984
          @drx1984 correct
            drx1984 @sdetweil
            @sdetweil OK then I did it right. received now?
              sdetweil @drx1984
              @drx1984 yes, just arrived…
                drx1984 @sdetweil
                @sdetweil OK, great
                  sdetweil @drx1984
                  @drx1984 sadly it looks perfect.
                  do this
                  edit
                  ~/MagicMirror/installers/mm.sh
                  insert a new line 2
                  sleep 10
                  then reboot
                    drx1984 @sdetweil
                    @sdetweil that’s what she means?
                      sdetweil @drx1984
                      @drx1984 yes it will sleep 10 seconds before starting MagicMirror
                        drx1984 @sdetweil
                        Hello, hey, it actually works with “sleep 10” Thank you very much. Can you explain to me what “sleep 10” does? Is it normal to make this entry?
                        Can I also add this entry for GPU (export ELECTRON_ENABLE_GPU=1) ?
                        Like in the picture:1.png
                          sdetweil @drx1984
                          @drx1984 great news. some timing problem.
                          yes you can add to the script like that
                          you can try reducing the sleep to 5 seconds as well
                            drx1984 @sdetweil
                            OK, I will do that, thank you very much for your help
                              drx1984
                              Good morning, you can now mark the topic as “solved”. Thank you
                                sdetweil @drx1984
                                @drx1984 you can do that too.
                                pick the message that you think provides the best solution, hit the 3 dots to the right and select
                                mark this post…
                                  drx1984 @sdetweil
                                  @sdetweil hi, ok, great, I just did it. Thanks
                                  • 2 / 3
