    MagicMirror does not start in full screen
    42 Posts 2 Posters 28.0k Views 2 Watching
      sdetweil @drx1984
      @drx1984 correct
        drx1984 @sdetweil
        @sdetweil OK then I did it right. received now?
          sdetweil @drx1984
          @drx1984 yes, just arrived…
            drx1984 @sdetweil
            @sdetweil OK, great
              sdetweil @drx1984
              @drx1984 sadly it looks perfect.
              do this
              edit
              ~/MagicMirror/installers/mm.sh
              insert a new line 2
              sleep 10
              then reboot
                drx1984 @sdetweil
                @sdetweil that’s what she means?
                  sdetweil @drx1984
                  @drx1984 yes it will sleep 10 seconds before starting MagicMirror
                    drx1984 @sdetweil
                    Hello, hey, it actually works with “sleep 10” Thank you very much. Can you explain to me what “sleep 10” does? Is it normal to make this entry?
                    Can I also add this entry for GPU (export ELECTRON_ENABLE_GPU=1) ?
                    Like in the picture:1.png
                      sdetweil @drx1984
                      @drx1984 great news. some timing problem.
                      yes you can add to the script like that
                      you can try reducing the sleep to 5 seconds as well
                        drx1984 @sdetweil
                        OK, I will do that, thank you very much for your help
                          drx1984
                          Good morning, you can now mark the topic as “solved”. Thank you
                            sdetweil @drx1984
                            @drx1984 you can do that too.
                            pick the message that you think provides the best solution, hit the 3 dots to the right and select
                            mark this post…
                              drx1984 @sdetweil
                              @sdetweil hi, ok, great, I just did it. Thanks
                              • 2 / 3
