    MagicMirror does not start in full screen
    42 Posts 2 Posters 29.9k Views 2 Watching
      drx1984 @sdetweil
      @sdetweil OK then I did it right. received now?
        sdetweil @drx1984
        @drx1984 yes, just arrived…
        D 1 Reply Last reply
          drx1984 @sdetweil
          @sdetweil OK, great
            sdetweil @drx1984
            @drx1984 sadly it looks perfect.
            do this
            edit
            ~/MagicMirror/installers/mm.sh
            insert a new line 2
            sleep 10
            then reboot
              drx1984 @sdetweil
              @sdetweil that’s what she means?
                sdetweil @drx1984
                @drx1984 yes it will sleep 10 seconds before starting MagicMirror
                  drx1984 @sdetweil
                  Hello, hey, it actually works with “sleep 10” Thank you very much. Can you explain to me what “sleep 10” does? Is it normal to make this entry?
                  Can I also add this entry for GPU (export ELECTRON_ENABLE_GPU=1) ?
                  Like in the picture:1.png
                    sdetweil @drx1984
                    @drx1984 great news. some timing problem.
                    yes you can add to the script like that
                    you can try reducing the sleep to 5 seconds as well
                      drx1984 @sdetweil
                      OK, I will do that, thank you very much for your help
                        drx1984
                        Good morning, you can now mark the topic as “solved”. Thank you
                          sdetweil @drx1984
                          @drx1984 you can do that too.
                          pick the message that you think provides the best solution, hit the 3 dots to the right and select
                          mark this post…
                            drx1984 @sdetweil
                            @sdetweil hi, ok, great, I just did it. Thanks
                            • 2 / 3
