    MagicMirror does not start in full screen
    42 Posts 2 Posters 29.9k Views 2 Watching
      drx1984 @sdetweil
      @sdetweil yes, the resolution is as follows under system settings:
      The monitor is a 24 inch/full HD and is set to portrait format.
      then the values should be correct 1920x1080 right?
        sdetweil @drx1984
        @drx1984 wider than taller (1920x1080) (w,h) is landscape mode
        taller than wider (1080x1920) (w,h) is portrait mode
        are you trying to do both at the same time?
        landscape on physical screen and portrait over connection?
        can’t do that, physical screen wins
        D 1 Reply Last reply
          drx1984 @sdetweil
          Good morning,
          So even if I set physical landscape format and restart the system, the MagicMirror doesn’t appear in full screen >> look at the photo I took on my cell phone without Anydesk access.
          And I uploaded a video clip to YouTube: https://www.youtube.com/watch?v=gjiYQ21SoKI
          And I entered the entry with: electronOptions:{width:xxxx, height:yyyy}:
          Where else can the problem be?
          Thanks for your help.
            sdetweil @drx1984
            @drx1984 in the electronOptions add at the end
            ,fullScreen:true
            note the leading comma, as this will be after the height:1080
              drx1984 @sdetweil
              @sdetweil Is that what you mean>> electronOptions:{width:1920, height:1080, fullScreen:true}, ?
              unfortunately nothing came of it
                sdetweil @drx1984
                @drx1984 yes…
                what OS is this
                show results of
                lsb_release -a
                uname -a
                also, stop MagicMirror and then delete the .config for Electron as before
                then restart MagicMirror
                  drx1984 @sdetweil
                  @sdetweil Unfortunately I have to leave now sry, I’ll get back to you tomorrow.
                  There is an Ubuntu 22.04.4 installed on an IntelNuc.
                  I have another YouTube video >you can see how it is briefly in full screen at the start and then the full screen goes away again. Watch the video clip until the end: https://www.youtube.com/watch?v=5fRf2pJuET8
                  thanks
                    sdetweil @drx1984
                    @drx1984 ok, how are u launching mm?
                    show results of
                    pm2 status
                      drx1984 @sdetweil
                      Good morning, MagicMirror actually starts when I restart, but I can also start MagicMirror in the terminal with pm2 start.
                      If I start the MagicMirror myself via the terminal, everything is displayed in full screen, but not when I reboot.
                      I installed MagicMirror with this script: bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                      Everything works, except the full screen doesn’t work when IntelNuc is restarted.
                        sdetweil @drx1984
                        @drx1984 thats my install script
                        so, lets create the pm2 entry
                        pm2 stop all
                        pm2 delete 0
                        pm2 save -f
                        # run script from my list to setup pm2
                        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                          drx1984 @sdetweil
                          @sdetweil I just tried, unfortunately still no full screen after restarting.
                            sdetweil @drx1984
                            @drx1984 hm…
                            can you do
                            pm2 info 0 >somefile.txt
                            and send me the somefile.txt at my same userid on gmail
                              drx1984 @sdetweil
                              @sdetweil OK, I created it. what is your email address?
                              or can I post it here too?
                                sdetweil @drx1984
                                @drx1984 don’t post here, too much stuff
                                I gave you my email
                                I protect myself against scrapers looking for email
                                  drx1984 @sdetweil
                                  @sdetweil OK, all right, I just sent you the file
                                    sdetweil @drx1984
                                    @drx1984 ok, don’t see it yet
                                      drx1984 @sdetweil
                                      @sdetweil hmm, so I understood you correctly, your email address is “username” from this forum and ....@gmail.com >correct?
                                      Or check your spam folder?
                                        sdetweil @drx1984
                                        @drx1984 correct
                                          drx1984 @sdetweil
                                          @sdetweil OK then I did it right. received now?
                                            sdetweil @drx1984
                                            @drx1984 yes, just arrived…
                                            • 2 / 3
