    module update
    7 Posts 2 Posters 1.1k Views 2 Watching
      pat59
      Thanks for your feedback but it won’t restart.
      pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-GooglePhotos
      pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ npm instal
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios
      npm ERR! dest /home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/.axios-r4bdKtOS
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename ‘/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios’ -> ‘/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/.axios-r4bdKtOS’
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-03-13T15_20_28_109Z-debug-0.log
      pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ pm2 restart MagicMirror
      [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 1 ])
      [PM2] MagicMirror ✓
      │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
      │ 1 │ MagicMirror │ fork │ 2 │ online │ 0% │ 2.4mb │
      │ 0 │ mm │ fork │ 0 │ stopped │ 0% │ 0b │
        sdetweil @pat59
        @pat59 ok, back to the module folder again, and do
        sudo rm -rf node_modules
        npm install
        and restart mm
          pat59
          sorry it doesn’t restart
          pi@raspberrypi:~/MagicMirror/modules $ sudo rm -rf node_modules
          pi@raspberrypi:~/MagicMirror/modules $ npm install
          magicmirror@2.26.0 postinstall
          npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
          magicmirror@2.26.0 install-vendor
          echo "Installing vendor files …
          " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          up to date in 3s
          magicmirror@2.26.0 install-fonts
          echo "Installing fonts …
          " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          Installing fonts …
          up to date in 2s
          magicmirror@2.26.0 prepare
          [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
          husky - Git hooks installed
          up to date in 33s
          196 packages are looking for funding
          run npm fund for details
          pi@raspberrypi:~/MagicMirror/modules $ pm2 start mm
          [PM2] Applying action restartProcessId on app [mm](ids: [ 0 ])
          [PM2] mm ✓
          [PM2] Process successfully started
          │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
          │ 1 │ MagicMirror │ default │ 2.26.0 │ fork │ 911 │ 3m │ 0 │ online │ 0% │ 2.5mb │ pi │ enabled │
          │ 0 │ mm │ default │ N/A │ fork │ 1697 │ 0s │ 0 │ online │ 0% │ 2.4mb │ pi │ disabled │
            sdetweil @pat59
            @pat59 no, the MODULE folder.
            npm install
              pat59
              yes great it works very well thanking you for your sympathy and your patience
              Sincerely
